Question about Canon iR 1600 Laser Photo Printer
I have error E354 on copier IR1600 what can i do to get rid of it?
    Top Expert:
  • Canon Master
  • 10,875 Answers
Hoo.comi want to solve the problem in my copier canon ir 2016, error code e354
this is error code that isn't stated in service manual and doesn't have description. When this error occures the procedure is to report to Canon service center. The same errors were on ir1600/2000 series, but without some good explanations.
So, call authorised CANON service partner!
Sep 13, 2011 | Canon iR 2016i Black and White Copier
IR 1600 printing problem
These are the features u need for the connectivity of your printer.........
Parallel ( IEEE1284)
USB
10 Base-T, 100 Base-TX (RJ45)
Full Duplex/Half Duplex
CPU - 200MHz RISC Processor
RAM - Std, 8MByte (upgradeable with 32MByte DIMMs to max 72MByte)
Storage - Optional 10GByte Hard Disk
Is your printer satisfying all these options?
Or
Reason is different IC ROM (IC4,IC5 on control board).
You can reprogram for this IC.
All the best
Oct 03, 2007 | Canon ImageRunner 1600 Copier
Error E354-0002 ir 8500
Error E354 in Canon iR 2016
error e354 code appear when you replace PCB controller board.
Please note. Before replace your PCB board with other one.
Pull out a small (FRAM COUNTER) chip from your old PCB board you can found it right side of the PCB board near a battery cell the chip attached with screw open screw and pull it out and attached it with your new PCB board .install your PCB board in the machine and turn on power error e354 will go off.
Aug 27, 2011 | Canon imageRUNNER 8500 Copier
Code erreur system E246 E354 canon IR1600 problem:
CANON IR 1600 ERR CODE 354 IT CAME AFTER REPLACING
MAIN BOARD HOW CAN I CORRECT THIS PROBLEM
Dec 27, 2010 | Office Equipment & Supplies
Ir1600 copier displayed system error E000, therefore the copier couldn't operate
E000
The main thermistor reading does not reach 40°C 14 sec after the fixing
heater goes ON. (fixing low temperature error)
Nov 13, 2010 | Canon iR1600-2000 PS
Error 354
E354
•When turning ON the power, inconsistency of the serial No. of
the serial number PCB and that of the controller PCB
(SRAM)/counter memory is detected.
•When turning ON the power, it is detected that no serial
numbers are assigned to the serial number PCB and the
controller PCB (SRAM)/ counter memory , if you are try to change the counter pcb to get rid of high meter reading this error is possible, this a security measure of canon to prevent meter tampering
Jul 15, 2009 | Canon Office Equipment & Supplies
Canon IR-3300, error 354
E354
Jul 14, 2009 | Canon Office Equipment & Supplies
SYSTEM ERROR 354
That code generally shows up when the main board id does not match up with the other controller boards. They cannot be interchanged between machines. They write to each other to check id's You will most likely have to replace all the primary boards, VERY costly.
Apr 18, 2009 | Office Equipment & Supplies
Technical suport
Try checking the fuser section,
1- bad thermistor
2-bad thermofuse
3-bad fuser lamp
Aug 07, 2008 | Office Equipment & Supplies
Error E354 in copier ir2016
We have a Canon IR 2016 J and in a beginning in the dispaly appears the message "Download Stanby" then after we replaced the PCB board appeared the message "System Error E354" what should we do to solve this problem, and if it is possible to send us the Service Manual with error codes for Canon IR 2016
Mar 26, 2008 | Kyocera KM-1505 Copier
Canon iR 1600 Laser Photo Printer Logo
153 people viewed this question
old marine
old marine
