Question about Nautilus E514 Elliptical Trainer
Nautilus 514 e7 error
E7 error
    Top Expert:
  • 10,875 Answers
My sharp copier AR-5316, is showing error message E7. How do I clear it and solve the problem. Please I need urgent assistance.
For proper understanding of the error meainig it is necessary to obtain a Subcode of the error by pressing START at the moment of displaying error. E7-02 and E7-16 means Laser unit problems, E7-01 problem with memory, E7-10,11,12 Scanner problems Posted on Aug 16, 2016 -2017
Jul 29, 2016 | Sharp Ar 5316
What's your question? My Sharp photocopier AR-161 display E7. and can't make copies what is the problem?
Here is a list of error code meanings for your device. You need to find out the sub code should be E7-?? To find the root cause. Sharp AR 161 Error Codes Trouble Codes
E7
E7 03 LSU trouble
E7 04 CCD white level trouble
E7 05 CCD black level trouble
Sep 25, 2015 | Sharp Office Equipment & Supplies
I have E7 and machine won't work????
E7 sounds like an error code. First step is to look it up in your owner's manual.
Aug 26, 2014 | Singer Sewing Machines
I have an E7 on my treadmill its brand new whats wrong lubricated it
1= this errro means 2 alternatives:
a= display board is erratic: adjust the reed switch see the diagram attached, tight the wires connector, +ribbon cables from keypads and clean it, unplugged the mahine
b) the elevation motor : lube the elevation motor gear+shift adjust the POT for better improve, test the motor voltage for defective.
see the diagram
God bless you
7_20_2012_9_42_10_am.gif7_20_2012_9_42_28_am.gif7_20_2012_9_42_46_am.jpg7_20_2012_9_43_07_am.jpg
Jul 19, 2012 | Nautilus Exercise & Fitness
Toshiba washing machine AW-1160SM error E7-1
my washing maction have a priblem E7 err
Jan 11, 2012 | Washing Machines
Toshiba washing machine with error code e7-4
Toshiba top washer machine with error code e7-4. What the problem and how to solve.
Oct 08, 2011 | Washing Machines
Display error code E7
Sharp copier AR5516 not working. Error code E 7 kindly help.
Jul 27, 2011 | Sharp AR-5316 Advanced Digital Imager...
Purchasing a 514 currently have a rt1000
514 is definite upgrade to Nr 1000 with walk thru feature and adjustable lumbar support instead of magnetic boot resistance it is using eddy current resistance.
May 03, 2010 | Nautilus Nr Recumbent Exercise Bike
E7 problem
E7 codes deal with the optical scanner unit and or the laser unit. It could also be the lamp in the scanner unit. The E7 is the main code. There is a sub code associated with it. To view the sub code hold down the start button. Below is a list of specific codes and their meanings:
E7-02: LSU trouble
E7-10: Shading trouble (Black Correction)
E7-11: Shading trouble (White Correction)
E7-12: Shading Trouble
E7-16: Abnormal laser output
If it is a laser (LSU) issue then the LSU may need replacing.
If it is a shading error the first step is to remove the platen glass carefully (with the power off because the inverter board). There is a thin white strip on the bottom side of the platen next to the slit glass. Clean this white strip with a soft cloth and a small amout of isopropyl alcohol.
Dust on the optics can also cause shading reference errors so gently blow off the mirrors with canned air.
Perform the following key procedure to reset error:
"#" key, Interrupt key, "C" key, Interrupt key
"1" key, "4"key
Start key, "CA" key.
See if unit cycles and comes back up. If not turn off and then back on the main power.
If error reappears on site technical service may be required.
Jan 06, 2008 | Sharp AR-5316 Advanced Digital Imager...
Nautilus E514 Elliptical Trainer Logo
151 people viewed this question
Top Nautilus Exercise & Fitness Experts
David Payne
David Payne
Electro Med Services...
Techmotionusa.com
Techmotionusa.com
Are you a Nautilus Exercise and Fitnes Expert? Answer questions, earn points and help others
