Question about Karcher Garden
The inlet elbow on my Karcher b402 is Broken but I can't work out how to get the Broken part out of its housing
  • 125 Answers
Posted on Apr 10, 2015
How do I remove casing
there are 2 more screws below the snap on base plate if you have further problems go to espares site look up karcher spares put in inlet elbow and there is a video showing how to split casing it is quite easy when youve seen this good luck
Jan 16, 2015 | Karcher Garden
Hi i have a karcher k4.91 and it is lossing pressure and leaking from inside the casing..what would be the likely cause.. many thanks
This could be a problem in the pump, the seals may have been damaged if it is an older machine through age. You could check a local karcher supplier/dealer and they should be able to replace that for you. Another problem maybe that an inlet elbow could be loose and does not seal correctly so it may need replacing.
These solutions depend on what area inside the machine the water is leaking from.
Jan 11, 2011 | Karcher Garden
My Karcher 330 M has blown two water inlet ( Garden hose inlet ) elbows. Replaced one and then after about 5 min operation shut off the valve on the wand and immediately the new elbow split the same as the...
I have a larger gas powered karcher, just make sure the water going to your karcher is not obstructed from its path. on mine i bought a goodyear hose that can be purchased at northern tools or any hardware store. and use it just for pressure washing. good luck!
Dec 23, 2010 | Karcher PSI Electric Pressure Washer
I have a Karcher 395 and want to replace the broken inlet elbow, but I cannot figure out how to get the plastic valve assebly free from the cast metal cover to change it. Seems as thought the valve...
Take a socket that is the same size as the black plastic and tap it down through the hole until it comes out. I have done several of these this way.
Dec 04, 2009 | Karcher 2500 PSI Pressure Washer
Hello i have a karcher b402 i have had it for a few years it is stating to leak water from underneath allthough not a problem what can i do with this please edwin read
hi, it sounds like the seals in the pump have gone,
you can repair this your self with some seals, www.karcher.com then click on europe,then international the screen will change.
go to services the spare parts, in put your model.
it will help if you can also find the 8 digit number starting with a 1.something something something dash something something something dot nort.
or ring me on 01729825656
Jun 29, 2009 | Garden
Karcher B402 pressure washer Motor runs as soon as power supply connected, on/off switch does not seem to make a difference and no pressure at outlet? Was working fine, stopped for half an hour, came back...
bob I had this happen to my Karcher, the pressure seals have blown. $Au200 for service and replacement from karcher dealer. tyhey would not sell the parts for a DFY
Jun 22, 2009 | Garden
Water spraying out of the front vent of unit.
Dear zenith 10deg,
The outlet elbow attached to the head inside must have cracked. Leakage from selas do not that much spraying. Spraying are almost always caused by the cracking of the outlet elbow or the cracking of the head itself. The inlet elbow also makes a lot of spraying wheb broken, especialy if inlet water pressure is high. To see exactly from where the spraying is coming out, one must for sure remove the cover. Removing the cover must be done, because just the same one has to fix the problem.
Regards,
fulltech.
Apr 08, 2009 | Karcher Garden
Water coming out of washer
Depending on the model of the machine, it is most likley a cracked control head or split outlet elbow. Remove the covers and run the machine to locate the source of the leak. Ifit is the control head it will spray water from the top just behind the chemical inlet elbow.
Feb 06, 2009 | Karcher K2.26 Electric Power Washer
Karcher 395
I found that by putting the housing in the freezer for a couple of hours, i was able to tap the metal and plastic body apart and install the new inlet elbow.
Aug 17, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
350 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
