Fuel components are onthe "Engine Assembly" & "Handle, Chassis, & BarAssembly" detail pages. Replacement fuel lines can be found at yourlocal chainsaw seller/mechanic. They are different diameters.
Fuel Line Replacement
The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as it inflates).
The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Line from fuel filter goes directly into the inlet of the carburetor and the line from the snap in bulb that is marked "in" attaches to the other outlet connector on the carb. Last is the long side of the bulb goes to the return on the gas tank. The snap in bulb sucks the gas but not directly from the filter hose, it does this through the carb as if it were trying to not only **** in the fuel but also removing the air trapped in the carb. You'll notice that the bulb has a **** side and a discharge side, and the **** side goes directly to the carb outlet connector. I tried to make this a clear as possible, and I hope it helps.
If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
Take lots of notes and a few digital photographs to help with reassembly.
The line with the filter needs to be long enough to reach all parts of the tank as the saw is moved, a little to long is probably better than to short. The line returning from the primer is not critical so long as it cannot fall out (mid tank). All the primer line does is return excess fuel to the tank. Does this answer your question? HTH Lou
If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
Take lots of notes and a few digital photographs to help with reassembly. HTH Lou
What little fuel system system detail there is can be found here: Poulan.com http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html If it is a 2375 WildThing find 2375LE Gas Saw Type ?. The last digit of your serial number should be a -1 or -2, the type.
The filtered hose from the fuel tank connects directly to the carburetor input connection.
If the saw is equipped with a primer, the output line from the carburetor connects to the suction side of the primer bulb (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as the bulb reinflates).
The pressure side of the primer returns any excess fuel to the tank as it is depressed.
Hi this is the way it should go: 1 from the filter in the tank to the bottom of the carby,2 from the top of the carby to the inlet on the primer,3 from the outlet on the primer back to the tank as this is the return line nothing goes onto it.
