I need the konka tv model kp2107hsn service code.
My konka tv kp 2107hsn screen vertically large I need service code for solve this problem . /> /> /> /> EC9F76D.jpg" />
ctf1800
  • 4402 Answers
SOURCE: Codes for a Konka Tv
Remote codes
http://www.remotecentral.com/index.html
Posted on Mar 17, 2008
SOURCE: AC Adapter for Konka TV
All I'm looking for is a Jewel AC Adapter Model JS-12030-2E.
thanks
Gary
Posted on Jul 22, 2008
SOURCE: Konka code
I have small TV called Konka for my small kid.This TV was bought in 2000.My problem is that kids have damaged the remote control of this TV now to operate it I need Unversal Remote control. Konka tv is never found on any of the manual of unversal remote control lists.
So, is it possible to get CODES for that Tv.
thanks
Posted on Oct 18, 2008
SOURCE: No Konka TV Codes on Uni. Remotes
Hey everyone if you are trying to find the code for your konka tv on philips universal remote it is : 0208. My fiancee just played around with codes and figured this out. so your code is 0208..
Good Luck!!
Posted on Jun 28, 2009
Wise Frog
  • 13 Answers
SOURCE: Sony wide screen projection tv model kp-57wv600.
I found this solution from SONY's website.
The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
I hope this helps.
Posted on Aug 05, 2009
I need konka tv model kp2107hsn service code
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Type in the brand name to your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Apr 08, 2015 | Konka Televison & Video
KP-57WV600 Sony Wide Screen tv blue arcs across entire screen
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
I hope this will help in solving the problem...
Sep 09, 2011 | Televison & Video
Screen shakes / jumps vertically on my Sony KP-51HW40
The jitter is called a vertical sync problem. The problem is on the "A" board. It can be replaced or rebuilt but will be quite expensive to service.
michtech
Feb 09, 2009 | Sony KP-51HW40 51" Rear Projection...
Need a code for a Konka flat screen
i canot fine the code for my konka tv flat screen model nuber klc 1508u
Dec 30, 2008 | Konka K1938U 19" TV
Sony kp-53S25 issues please help
The vertical circuit needs to be checked. It could be the vertical output needs to br resolderd or you could possibly have a bad capacitor. if you need more assistance let me know.
May 22, 2008 | Sony KP-53S25 53" Rear Projection...
Konka
I don' t have the code for TV KonKa model k 2386 U and my remote control no working
I have one universal remote Atak RA 10, but it don't have the code for konka TV.
Mar 16, 2008 | Konka K2386U 23" TV
TV Codes
try
www.remotes.com
to solve your problem.
Oct 14, 2007 | Konka K2386U 23" TV
Konka K3466 EXT 1 Model
replaceing parts will not solve your problem. you will have to go as per procedure. solution check power supply output. if it is ok check horizontal section.
Sep 21, 2007 | Konka K2001UM TV
MY KONKA MODEL KLC 1508U
My Konka model KLC-1508U tv will not come on there is no red light that shows it is off
May 11, 2007 | Konka K2001UM TV
Solution
You have a bad vertical output IC or a bad capacitor(s) in the vertical driver or output circuits. Not a job for the user to do unless you have the proper tools as well as a service manual. Good Luck
Mar 28, 2007 | Konka K2386U 23" TV
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
