What board could be involved when the projector presents a router issue?
How do i add a secondary monitor
If I saw correct picture of your laptop, you have HDMI and VGA connector on the left-hand side. Just connect external display, then press Windows key and key "P" and you will be presented with toggle screen with 4 options: 1-Disconnect projector, 2-Duplicate, 3-Extend and 4-Projector only. Choose to your liking (in your case: Duplicate).
Note: this is solution for Windows 7, 8.0 and 8.1. 25329432-yuc33qzjuwfqgyyin4u45syc-3-0.png
Dec 19, 2014 | ASUS WL-500W Router (WL500W)
How can I remove splotchy reds and yellows from HD80 picture?
it is possible the color wheel or sensor board issue.
at present, what you can do by yourself, please try to clean sensor board and that small black chip on it. perhaps it is helpful.
Aug 09, 2014 | Optoma HD80 Projector
Why yellow display in dukane projector?
it has several possible reason. 1) color wheel 2) sensor board. 3)DMD boar 4) main board.
the most possible reason should be color wheel or sensor board.
at present, what you can do by yourself, trying to clean sensor board, specially clean that small black chip on sensor board. perhaps it is helpful
Jul 13, 2014 | InFocus Lamp Projector Lamp for LP280,...
I bought a usb-vga cable for my optoma widescreen 16:10 enhanced projector but its saying
hi sir,
try to switch the way of output, so that choice suitable screen output way.
certainly, it is possible with compatible problem. review your projector instruction, check it can support USB function or not by the manufacturer.
hope it is helpful for you.
regards,
Jack
flying200809@gmail.com
any friends who were looking for below products, welecome you to contact me,
Professional wholesaler and retailer: for below products
1) projector spare parts, such as color wheel, lamp, mother board,DMD. lens, etc.
2) computer mother board,
3) HP server, switch, router. Cisco router. switch etc. complete machine or asscessories or parts
4) server or router memory
5) GBIC OR SFP
Nov 29, 2011 | Optoma Office Equipment & Supplies
Light outside screen
hi sir
try to recheck your machine data, rely on those instruction, adjust the distance between projector and screen.
Jack
Professiona wholesaler and retailer: for below products
1) projecot sapre parts, such as color wheel, lamp, mother board,DMD. lens, etc.
5) GBIC OR SFP
Nov 28, 2011 | Optoma DX602 DLP Projector
Projector takes 30-40 min to recognize signal from elmo 110xg
the resolution might not match from presenter to projector. are you using rgb, composite or s-video? the signal might not match. there might be an auto adjust on the projector to read and match the elmo's resolution. if not, the elmo may have an issue sending a powerful enough signal to the projector, and need a new main board.
Apr 07, 2009 | Elmo Projectors ELMO VISUAL PRESENTER,...
My remote won't work on my Dell 1200 projector
remote wont click to next page on Powerpoint presentation
Mar 05, 2009 | Dell 1200MP DLP Projector
Gateway laptop 450ROG video issue when using a projector
Honestly from the information you have listed it sounds like the issue is with your projector, not your laptop. If your laptop was having display issues it would be consistent on anything it was attempting to output display to, such as your monitor.
The projector sounds like its out of focus and possibly has a bad back light in it, I would suggest contacting the manufacture for a possible resolution.
Dec 15, 2008 | Gateway 450ROG Notebook
70 people viewed this question
jasbo
jasbo
