Question about Miele WT945 Front Load Washer / Dryer
Rinse light keeps flashing and doesnt drain or spin
Have drained the machine manually and cleared out the filter at the bottom- what now?
  • 27 Answers
I think you will find it could be the circuit board. Have a look on line for a replacement because it should be easy to fit and save your self a fortune for a repair man!
Posted on Apr 11, 2015
Start matsui washing machine
Check the washer drain hose for clogs.
Jun 19, 2017 | Washing Machines
Cycle stops and won't drain or spin. The 'end' light flashes and it makes a whirring noise, won't go onto the rinse cycle.
Have you checked the pump and filter are clear? bottom right flap on front panel to expose pump. Check the hoses are clear, particularly if it is connected under the sink, via a spigot connection. If the machine has good motor action, but not spinning effectively, it will more than likely be a drainage problem.
Jul 05, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Washing machine is not draining and lights keep
It is likely that the pump/filter has blocked thus preventing the water pumping out.
You would need to check and if so unblock it. The location of the pump/filter varies with the brand but sometimes it is behind a flap at the lower front of the machine whilst on others you have to get the back off to locate it.
Jan 23, 2010 | Indesit Washing Machines
LG WD 8013F drains then won't spin
  • Hi,
  • Try these:
  1. Test the lid switch
  2. Test the timer control
  3. Test the centrifugal switch
  4. Test the water level switch
  5. Inspect the motor coupler
  6. Inspect the drive belt (belt drive only)
  7. Inspect under the washer for soot (clutch)
  8. Test the motor
  9. Inspect the pulley
  10. Test the transmission
please rate my suggestion...
May 21, 2009 | LG Washing Machines
Washer wont drain and spin properly
whee is th drain filter on crosley front loader
Apr 02, 2009 | Crosley CW5000 Front Load Washer
Water doesn't drain
water discharge drain $50 part, easy installation. google the lg model to locate part.
Nov 19, 2008 | LG WM-3677HW Front Load Washer / Dryer
Wont drain, wont empty, wont go onto rinse, drain or spin during
The filter on this machine is behind the flat at bottom right of machine. Tilt machine back before unscrewing to avoid spillage. If filter is clear get back to me and will explore other possibilities.
Nov 16, 2008 | Washing Machines
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Washer will not drain
Check out your outlet pipe from under tub to filter. Keep bucket to collect water if it drains from the hose, clear the hose; if possible look also into filter to remove any clogging. Fit back. You could pour some water into the machine (where u put your clothes) and try 'spin' only for a short time. See if water drains. Try half a load to see if the machine rinses and drains. This symptom is usually when your outlet drain pipe or out filter is blocked with something.
Apr 21, 2007 | Kenmore 24432 Top Load Washer
Miele WT945 Front Load Washer / Dryer Logo
183 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
