Question about Bushnell Optics
Need to replace the plastic eyepiece.Can I get a replacement part?
2 Suggested Answers
  • 10865 Answers
SOURCE: I have Nikon 8x42 7*
Hello. It sounds like you are really into binocs. Therefore, you may enjoy this website http://www.nikonchat.com/nikon-binocular-parts/
That said, all of the parts you may need are available directly from Nikon
Nikon Parts Department
7AM - 3PM (Pacific)
Monday - Friday
310-414-8107
Fax- 310-322-6979
Joe
Posted on Oct 20, 2010
I need a replacement screw on plastic eye piece for a set of asahi pentax 7x50 binoculars. Where can I purchase the part?
Either order from Pentax or take the screw from the other eyepiece and take it to a hardware store and match it up.
Dec 01, 2014 | Pentax Optics
Is there an adapter so I can fit my 2"Collimation Tool into my .965" eyepiece holder on my telescope
There are adapters, but normally a 2" collimation tool is way way too heavy for a .965 eyepiece holder. Most of the eyepiece holders are made from plastic, and they break fairly easily, so you take a big chance of your 2" collimation tool dropping to the floor or concrete. Even if the plastic did not break, the weight of the collimation tool would bend the eyepiece holder out of position. It only takes the slightest amount to make your test worthless - after all, you're after precision. Bending or distorting anything destroys the precision. They do make 1.5" collimation tools, and there are adapters to get from the tool to your eyepiece holder. They also make things called "cheshire eyepieces" and regular collimating tools which will work with your 4" reflector.
Nov 05, 2017 | Celestron Cameras
BI need to replace some of the eyepieces...what did the 60AZ originally come with? and where can I purchase them?
You can buy eyepieces from many on-line retailers. Eyepieces come in 3 sizes .965, 1.25 and 2 inch sizes. The .965 size is harder to find. Measure the HOLE in the focuser or the diagonal and buy the correct size.
Here is one on-line retailer that sells eyepieces:
http://www.agenaastro.com/
Mar 30, 2011 | Meade TeleStar 60AZ-A Telescope
How do i get the lenses attached to the telescope. neither one of them is fitting in the opening
I think you mean the eyepieces. There is more than one fitting size of eyepiece, but if you bought the telescope new, the ones supplied with it should certainly fit. There may be a little plastic plug in the opening that the eyepiece goes into, to keep out dust, and there may be a protective cap on one or both ends of the eyepieces as well. You need to remove these before fitting the eyepiece. The commonest sort of eyepiece measures 1.25 inches in outside diameter, and fits in a tube of the same inside diameter, with a little screw that you tighten by hand to hold it.
Jan 04, 2011 | Edu-Science (10166) Telescope
Hi, the plastic bit snapped off the telescope's diagonal (where you fix the eyepiece), and this, plus the eyepiece is nowhere to be found. It was a childhood telescope I am trying to rescue! (a Bushnell...
You can certainly buy both eyepiece(s) and a diagonal, but you may find the price rather high compared with the value of the telescope. You probably don't actually need the diagonal- if you remove the broken one you should find that it is possible to insert an eyepiece directly in the hole it comes out of. The diagonal is useful for two things, it partially erects the image (astronomical telescopes usually display the image inverted), and it provides a more convenient viewing angle.
I am assuming the the eyepiece size is 1.25 inch outside diameter- the standard for small telescopes. Some earlier scopes might require an eyepiece just under an inch in diameter. These will be much harder to find now.
There is a useful website about small scopes on THIS LINK
Jan 03, 2011 | Bushnell Deep Space 18-1560 (150 x 53mm)...
Lost lens to bushnell 18-1561
I have a similar problem with my Bushnell 18-1650!
As you can see below, the plastic thing that holds the lens snapped off from the telescope's diagonal, and is now lost along with the eyepieces. This is a childhood scope I'm trying to rescue!
Should I:
1) glue a new eyepiece straight onto the diagonal
2) buy a new diagonal AND eyepiece
Or do I need to just buy a new telescope?
Thanks in advance.
Sep 04, 2009 | Bushnell Deep Space 18-1560 (150 x 53mm)...
Lost Nikon Travelite ex eye piece
I'm supposing by eyepiece you mean the rubber or plastic eyecup. The eyepiece is the whole unit that contains the lens. Nikon has a service center in many countries. If you have one in your country then they can order the part. I have ordered from Nikon. They find the part number if you tell them your model and can email you an order form. Alternately Binoculars.com is very good to deal with as is Adorama Camera in New York. Both will sell internationally.
Jul 13, 2009 | Nikon Travelite V Binoculars
I need a new eyepiece for my Swift 3200 microscope
Hello--I have recently bought Swift eyepieces and objectives on UK Ebay.They come up regularly and sell for £4-£18 dependant on spec--any help?kind regards martin r
Mar 16, 2009 | Science & Laboratory
Scope eyepiece screw replacement.
Dear Tony,
Please see properly at oject ring case or eyepiese plastic case.Their is a three screw.I thik one of this come out.
Dec 19, 2008 | Celestron CPC 800 (480 x 50mm) Telescope
Optics Logo
323 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
