Question about Garden
My mower starts easily, has NO motion forwards or reverse. s a drive belt slipping or what?
Castel 1150 Mower with NO Motion F/R
    Top Expert:
  • Garden Master
  • 44,268 Answers
Unset the brake push pedal all the way down and release it
Posted on Apr 10, 2015
Husqvarna 4623 zero turn mower will not move
Maintanance - How to purge Hydraulic drive system Published 01/13/2010 11:56 AM ' Updated 06/02/2015 02:52 PM
How do I purge the hydraulic system?
Hydrostatic transmissions use oil, under pressure, to provide movement for the tractor. The fluid is pressurized with a pump inside the transmission. If any air is in the fluid, the pump will try to pressurize air. This condition is known as cavitation, and is detrimental to the pump since it allows the pump top operate dry. When the pump cavitates it is not pressurizing any fluid, so the transmission is not able to provide the movement needed.
If your mower is new, or has been stored for a long period (longer than 2 months) the transmission needs to be purged before use. Also, if you experience loss of drive, or slower response, then the transmission should be purged first.
The following procedure will remove trapped air inside the transmission(s).
IMPORTANT: SHOULD YOUR TRANSMISSION REQUIRE REMOVAL FOR SERVICE OR REPLACEMENT, IT SHOULD BE PURGED AFTER REINSTALLATION BEFORE OPERATING THE TRACTOR.
Step 1- Place the rear of the mower safely onto jackstands on a level surface with engine off and parking brake set.
Step 2- Disengage transmission by placing freewheel control, located at the back of the frame, in the freewheeling position.
2a- Mowers with seperate pumps and wheel motors the freewheel is activated by turnign the bypass valves, one on each pump, two full turns.
The oil resevoir needs to be filled to the specifications listed in the owners manual before starting the purge procedure.
Step 3- Sitting in the operators seat(riders), start engine. After the engine is running, move throttle control to slow position. With motion control levers in neutral (N) position, slowly disengage clutch/brake pedal.
Step 4-Move motion control levers to full forward position and hold for five (5) seconds. Move levers to full reverse position and hold for five (5) seconds. Repeat this procedure three (3) times.
NOTE: During this procedure there may be some movement of the drive wheels, but they are not under load. The air is being removed from hydraulic drive system.
Step 5-Move motion control levers to neutral (N) position. Shutoff engine and set parking brake. Check and add oil as needed for units with an oil resevoir.
Step 6-Engage transmission by placing freewheel control into driving position, or by closing the bypass valves on the pumps.
Step 7-Sitting in the operators seat, start engine. After the engine is running, move throttle control to full speed. With motion control levers in neutral (N) position, slowly disengage clutch/brake pedal.
Step 8-Slowly move motion control levers forward, after the tractor moves approximately five (5) feet, slowly move motion control levers to reverse position.
After the mower moves approximately five (5) feet return the motion control levers to the neutral (N) position. Repeat this procedure with the motion control levers three (3) times.
Step 9-Your mower is now purged and now ready for normal operation.For further information or assistance, we recommend contacting your lo
Aug 06, 2016 | Husqvarna Garden
Yardman riding mower no reverse forward jerking motion
It sounds like you either have a lose belt that is slipping or the fluid in the transaxle is low, or the transaxle is going bad, if it is a hydrostatic transaxle, drain and replace the fluid first, if that fails, you may have a bad seal in the pump or a worn gear
Oct 16, 2013 | Yard Man Garden
Hydraulic system
I would say,that the Motion Drive Belt,has stretched to the point,that it is slipping on the pulleys. Over time all belts stretch or break. There is no adjustment,that can be made,once stretched,its time for a new belt. Look in your Owner's Manual,to see,a picture and directions of how to remove and replace a motion drive belt. If there isn't a picture of the drive belt in your manual,then look under the left foot rest. There you will find a decal,showing the correct method to install the belt over the pulleys. This is going to be a long belt,it runs from the Transaxle to the motor's upper pulley assembly. You can,it will be hard to do,remove and replace the drive belt with the mower deck attached. First,try lowering the mower deck,to the lowest position. This will give some room,to get to the motion belt,you will have to remove the mower belt,to get to the motion belt. I find it is easier to just remove the mower deck entirely. Doing this,give you ample room to work on the motion belt. The mower belt,can be purchased from Sears Parts Direct. Give them the tractor's Model Number and the Belt Part #,if you have the number,they will look it up anyway,if not. I gave more information,than you asked for. I hope this will help you. Sincerely,Brad Locke DTD. 12/04/15
Jul 15, 2013 | Sears Craftsman 46 in Mulching Tractor...
My Weedeater riding lawn mower will not move when it is in drive or reverse
Check your drive belt that it has not slipped off the drive cog under the motor. Also check the alignment of the motor with the handle on the right side (speed, reverse, and neutral lever).. This lever tilts the engine to engage the drive belt.. there is no transmission in this machine.. just how the belt engages by its angle when you push the lever forward and backward.. If the engine is running, it must be either the belt to drive the unit or the angle has been messed up somehow..
Apr 21, 2013 | Weed Eater Weedeater 26" Riding Mower
My Weedeater riding lawn mower will not move in forward or reverse after it has started
Check your drive belt that it has not slipped off.. also check your drive lever on the right side (speeds, neutral, and reverse). The mower uses this lever to angle the motor against the belt to move it..
It is most likely the belt or the angle misaligned if the engine is turning...
Riding mower surges in forward and not reverse. It
Ok first of all is not an automatic.Its a pedal operated transmission. The motion is accomplished by tightening a belt with a moveable idler and it is only shifted with a lever to forward and reverse. The belt probabley has a burnt spot in it and it hits that spot and it feels like a surge. Replace the motion belt
Mike
Oct 19, 2009 | Garden
Craftsman lawn tractor mower, automatic,917.273621, transmission will not pull mower up a slight hill. richard swint drive/motion belt seems normal,
The belt is probably slipping because it is not tight enough. look by the belt, inside there is a little spring, you may half to tighten it.
Jun 13, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
