Question about Vehicle Parts & Accessories
Where is the obd 2 port on 2010 honda odyssey located at
I want to hookup a Delphi connector from verizon
    New Friend:
    Problem Solver:
  • 13 Answers
where is the  obd 2 port on 2010 honda odyssey loc - 25638733-x0o4ftpzfyugajdlwqhevkgv-1-0.jpg
Posted on Apr 10, 2015
I have a code 763 C in my Honda Odyssey where is my SOLENOID located.Also codes 748 A Electric and 753
Po763 shift solenoid c honda odyssey - Fixya
www.fixya.com/cars/t1954836-po763_shift_solenoid_c_honda_odyssey
Apr 9, 2009 - po763 shift solenoid c honda odyssey what to do - Honda 1999 Odyssey question. ... THE OBD CODES ARE PO705, PO753,PO763. Mar 03 ...
Aug 24, 2015 | Honda Odyssey Cars & Trucks
Where is the fuse for the 3rd brake light for a 2010 Honda Odyssey EX-L?
The fuse for the 3rd brake light is the same as for the other brake lights. Do the other brake lights work ? If so you need to look at the MICU-Rear Junction Box .All brake light power goes through it.
It is behind right rear trim panel .It has 4 or 5 connectors to it. It is also on the B-CAN communication network , do you know what serial data bus communication is ? google it ! There is a microprocessor inside ! Connector H pin 2 is power for 3rd brake light.
Jan 30, 2015 | Honda 2010 Odyssey EX-L
I cannot locate where the port is for the obd II on a 1997 Isuzu oasis does anyone know the location
old post
the isuzu car in uSA, only has this port.
its a USA invention an began in 1996 (some cars 2 years early short list)
the OBD2 is in the cab. of car. near center of the steering wheel (by law in usa)
most cases its at drives knees, just under dash lip.
if someone didnt move it (my trick)
on my cars i have and extension cable there to passenger side so we can scan and log data.
in this case they hid it nice, behind glove box.
and is 16pin D-shell female conn. with 12vdc on pin 16 if power is missing on this pin, the scan tool will be INOP
Aug 07, 2014 | 1997 Isuzu Oasis
Cant fond obd plug for Honda logo
its and DLC jack, for scan tools .
in USA, can answer until that is answered
oBD2 is usa, OBD is diff. all over the world.
if by chance the car is USA spec, car its, usually 1 meter from
center of steering wheel. or a yard.
the FSM states. (USA)
The 16-pin OBD-II compliant DLC is an electrical connector with a gray housing located under the dash behind the center console on the driver's side of the vehicle.
Dec 02, 2013 | 2000 Honda Odyssey
Where is obd II port in 2003 honda civic
The 2003 Honda Odyssey OBD 2 port is on far right edge of dash; next to console; faces down
Jan 23, 2012 | 2003 Honda Civic
How do I access DLC Port location in a 2002 Honda Odessey Minivan?
On 2002 Honda Truck Odyssey 3.5L MFI SOHC VTEC 6cyl the OBD Diagnostic Link Connector is located under the instrument panel in the driver's side. It is bolted to the kick panel and is gray in color on the 1998 and newer models.
Also refer to Haynes manual in the emissions and engine control system section .
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Dec 12, 2011 | 2002 Honda Odyssey
Is there any way to rewire the power outlets in a 2010 honda odyssey so it's live when the van's ignition is off? We want to use the power outlet but do not want to have the key to turn the vehicle from...
yes several ways 1 is you remove the power port cut the power wire about 2 inches from the port . find a power source at the fuse panel box that is not being used. with a spade tap into it ,run wire to port. 2 way is to find a power wire that is not plugged to anything you sometimes you see plugs hanging under dash for other options . as long as its live with out key you can use it.
Jan 05, 2010 | 2009 Honda Odyssey
On a 1995 honda odyssey there 's a green connector on pass side kick panel that is obd 1 now witch wires do i jump for codes ?
On 95–98 models, to access DTC memory using the MIL, the SCS 2 pin connector is located under the righthand side of the instrument panel. Place ignition switch in the On position to begin MIL flash code diagnosis.
Simply connect the two pins (a paper clip is most often used to do this) before you turn the switch on, then turn the switch to the ON position and your MIL will flash the codes.
This URL lists the codes for OBD I:
http://www.troublecodes.net/honda/hondadtc.shtml
SOME 95 vehicles had the SCS on the left hand side of the Glove compartment, under the dash. Usually the connector was blue. See pic, although I don't think this applies to your vehicle.
64b545b.gif Hope this helps you.
Dec 03, 2009 | 1995 Honda Odyssey
Location of connector for OBD tester
Inside van, in driver's seat area, to the right of the steering column, under the dash. It is to the far right under the dash, next to the center section that goes down.
Aug 22, 2008 | 2000 Honda Odyssey
Vehicle Parts & Accessories Logo
373 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
