Question about Craftsman Garden
I have a 21 hp Briggs and Stratton model #331877, what are the valve settings?
Trying to set valves due to compression lock on start up
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Eugene isn't exactly correct and 1/4" isn't correct or necessary, just make sure the piston is at the top of it's stroke.
.004 ~ .006 for both intake and exhaust
Then roll it over a couple of times, bring it back up and check them again. Then roll it over slowly watching for the compression release. pay close attention to the exhaust valve because they like to wear away from not being adjusted properly
Posted on Apr 28, 2015
  • 109 Answers
Move crankshaft around so neither valve is raised and set loose at the rocker arm, set at 6mm intake and 8mm exhaust forget about where tdc is
Posted on Apr 21, 2015
  • Craftsman Master
  • 1,169 Answers
Intake 003 - .005
Exhaust .005 - .007
Adjusted with the piston 1/4" past TDC of compression stroke for each cylinder.
Posted on Apr 10, 2015
Valve clearance Briggs model# 331877 1371b1
Danny, I set lash at .004" / intake and exhaust clearance. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www4.briggsandstratton.com/miscpdfs/RNT/Engine%20Specifications%20Chart_ms3992.pdf
briggs and stratton 21HP backfires like cannon
YTS3000 Craftsman model 917 289213 valve gap setting 331877 1371 B1 Briggs...
Lawn Mower Repair Valve Adjustment
Jul 08, 2016 | Garden
Hard hitting on compression stroke when starting
Most Briggs deco vaves are internal and pretty reliable, the valve clearances are very important, if the exhaust valve clerance is too wide the valve lifter will not work, if there is no adjustment yoy would have to fit a new service valve and re do the clerance by removing material from the valve stem
Jan 02, 2014 | Briggs AND Stratton Intek Briggs &...
I need the specs for valves on briggs 21 hp model 331877
I am sorry but you will need to supply the type and code also. Email them to me @ flynow_1@hotmail.com and I can give them to you. Most of these engines are: Intake .003 to .005 and the exhaust @ 005. to 007. I set them in between @: Intake 004. and Exhaust 006.
Aug 07, 2013 | Briggs & Stratton Garden
18 hp vanguard 165lbs and 180 lbs compression have to hand turn engine past compression or starter wont turn engine over
if its hard to get the engine to turn past the compression release then pull your valve coversand try setting your valve lash
.006 on intake
.008 on exhaust
Oct 25, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Engine wont start
go to youtube and type in valve adjustment on briggs,very simple procedure to do.
Apr 23, 2010 | Briggs & Stratton 66set Panzer Tractor...
Hard to start 18 hp briggs &stratton
cold engine
loose .002 exhaust
loose .004 intake
be sure both valves are closed and you are on top dead center TDC of the compression stroke when setting
Jun 21, 2009 | Briggs & Stratton Garden
Garden Logo
529 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
