Question about Samsung HCL4715W 47" Rear Projection Television
HCL4715W - Shut off unexpectedly and won't power on..
I have a HCL4715W rear projection HDTV.
Last night it shut off - and now it won't power on. Instead, the red timer light on the front panel just blinks a few times and then it shuts off again.
Is it a bulb problem ? Any help would be appreciated.
  • Peter Lee
    Peter Lee Nov 24, 2007
    After a power drop to 68vac for a couple of minuets the picture was darker and after this the picture was reduced in size with a 3" black border and hte color convergence was out, a so called Samsung tech came ad expanded the picture and then everytime the picture went bright it cut out, I would switch off and back on and it was OK until the next time, setting the color to low contrast and britness and it was ok, for longer. Then one night I switched on and it went Pheeeeewww and died. Samsung in Spain say they cannot (or will not) repair it.
    Problem Solver:
  • 18 Answers
Seems I have a SP47W3HFX and the bottom of the left (from front) tube has brokern off just above the coils. parts anyone?
Posted on Nov 25, 2007
  • 934 Answers
It is
Posted on Nov 14, 2007
  • William Rayburn
    William Rayburn Nov 14, 2007
    It is most likely the convergence amps causing the problem.. With the power off and the unit unplugged remove the back. In the upper right corner - looking in the back - you'll see a board with two relatively large Ic's on it marked STK392-040. On the left corner of the board there is a connector, the board is marked +/-20v... Unplug that connector and plug the Tv back into power and try turning it on... If it powers up with audio you've just diagnosed your first Samsung.
    You have three options here (1) buy the whole board and replace it, (2) send the board out for repair, or (3) buy the amps and 3.9 low ohm resistors to repair it yourself... It will all depend on the skill level you think you have..
    If it's limited, sending the board in would be my suggestion and I'd recommend sending it to a shop that can modify the board with a cooling fan, like the picture above, to eliminate as much heat as possible. We modify them automatically for the ones we get in here. It's a $60.00 modification but it will save you from replacing the Ic's every couple of years.
    If I can help any further just let me know.
    Bill
    William Rayburn, CET
    Premium Technologies
    PO Box 442
    Long Beach, WA. 98631
    360-642-4993
    premtech@willapabay.org
  • William Rayburn
    PS. The amps aren't cheap either - about $30.00 a piece...
I shut the tv off last night and now it won't turn
If total dead (no lights on blinking etc) follow power cord into the set and find and check the main fuse--in this set it usually is a glass 5 amp fuse.
Dec 19, 2012 | RCA P52926 52" Rear Projection Television
Set TV to Auto ON/Auto Off.
hit menu button on remote....should be an option for power settings....check auto shut off option...
Jan 15, 2012 | Samsung HCL4715W 47" Rear Projection...
Screen turned solid red, and tv shuts down . worked fine last night.
Most likely cause of that is a red CRT has shorted which will shut the set down.
Mar 04, 2010 | Sony KP-46WT500 46" Rear Projection...
Phillips Rear Projection HDTV just shuts off.
I reacon it might be nearly as cheap to replace the tv because there are only 2 thing which can cause this problem dry joints on the solder ( Quite rare on this type of telly) or the line output transformer and that will cost you nearly a hundred pounds
Nov 27, 2009 | Philips 46PP9302 46" Rear Projection...
Working fine, then shut off.. won't come on, no power
A clogged air vent will cause the unit to overheat and not turn on.
Apr 16, 2009 | RCA D52W19 52" Rear Projection Television
Red red wavy lines across the TV screen
I did not fix the problem, but you have the model number wrong, it is KP-46WT510
I do need some help.
Nov 23, 2008 | Sony KP-43HT20 43" Rear Projection...
Tv possessed by the devil
The d52w20 processor will shut the set down if it detect one of many problems. this processor generates an error log. technicains have computers that can read those errors. to help find out trouble.. common problems include bad horizont output. flyback and signal board. for the fact it comes on indicates to me power defection issues
Oct 19, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Samsung HCL4715W 47" Rear Projection Television Logo
313 people viewed this question
Jerry Greenberg
Jerry Greenberg
