Question about Honda Garden
SIMPSON 2.5 HONDA 3400 PSI PRESSURE WASHER ITS NOT GETTING SPARK TO THE PLUG ITS BRAND NEW
5 Suggested Answers
  • 40 Answers
SOURCE: Pressure Washer trouble The Engine Won't Turn Over. What's Wrong?
well for starters if you let it sit all winter you the pump probably froz up and you might be able to get it un jamed by pouring in oil (any kind) in the hose inlet and let sit one night the try starting
Posted on Jun 03, 2009
  • 3 Answers
SOURCE: Karcher pressure washer with Honda GC160 engine only runs on chok
You need to remove the carb bowl, then with a small flat screwdriver remove the jet. ( on the side, at the bottom of stem.) take a small wire or toothpick and clean the gunk out of the jet, reassemble and open fuel valve, start, and pat yourself on your back.
Posted on Aug 04, 2009
SOURCE: My Husky pressure washer 2600 psi powered by a gcv
It sounds like the (RMW 2.2 G24) pump has gone out. Mine had this problem after about 6 hours of use. I was able to order a new pump for around $160.00, and then installed it myself. Go figure it was just out of warranty. I think my next pressure washer will be one with a professional pump as I was told the one on my husky is only rated for about 40 hours of use.
Posted on Aug 09, 2010
spraydoctor
  • 97 Answers
SOURCE: pressure washer, john deere 3000 psi, honda engine
It sounds like your intake is plugged with debris. What usually happens is a water hose that has been laying around will get various stuff in it -- dirt, grass clippings, small insects (and whatever they take into it nest building). These days most homeowner pressure washers do not have a proper inlet filter, but just a screened hose washer like on a washing machine. The unloader valve can cause pressure variance, but usually not in the manner that you described. The pump is being "starved" for input water. Just use a pair of needle-nose pliers and pull out the screen and clean it or replace it.
Posted on Feb 21, 2012
I bought a Simpson 3000 psi gas pressure washer. When I changed the oil (first time) I found the oil does not drain out into the pan but spills over the right wheel. I called a Honda dealership and
Easiest thing to do is buy a pipe nipple of appropriate thread size, a female thread elbow the same thread size and a male threaded plug to match the coupling. Turn the pressure washer onto its side with the drain plug pointing up. Remove the drain plug the screw in the pipe nipple where the drain plug was. Thread on elbow to other end of the pipe nipple and then screw in plug to the open end of the elbow. Buy a nipple that gets you just past the frame of the pressure washer and point the elbow at any downward angle you need to avoid draining onto the wheel.
Jul 22, 2014 | Simpson Garden
Honda gc160 engine on 2500 psi washer, no spark?
new spark plug? flooding may have fouled the old one.
Jun 05, 2008 | Karcher 2500 PSI Pressure Washer
Im not getting the simpson 3200 psi to shot out water
Give us a all when you. An be at the washer.
http://www.ppe-pressure-washer-parts.com/page/419383926-32577450
Nov 03, 2013 | Simpson PS3200 Powershot 3200 Psi Direct...
My 13.0 honda gx390 motor has no spark and will not start
try disconnecting the black wire which runs across under the fuel tank you should have spark.
Nov 15, 2011 | Simpson Taskmaster Industrial Gas Powered...
What PSI will the simpson Model WS5040H maintain while in use? I have had difficulty getting anywhere close to the rated PSI on a DeWalt 4200 PSI unit. Idle the pressure stays at about 4200 but as soon...
Engine is difficult to start when cold
  1. Check the battery condition, battery state of charge and starter motor current draw. Replace the battery if marginal and the starter motor if the current draw is beyond specification.
  2. Check the battery cable condition. Clean the battery terminals and replace corroded or damaged cables.
  3. Check the fuel system for proper operation. A fuel pump with insufficient fuel pressure or clogged injectors should be replaced.
  4. Check the engine's tune-up status. Note the tune-up specifications and check for items such as severely worn spark plugs; adjust or replace as needed. On vehicles with manually adjusted valve clearances, check for tight valves and adjust to specification.
  5. Check for a failed coolant temperature sensor, and replace if out of specification.
  6. heck the operation of the engine management systems for fuel and ignition; repair or replace failed components as necessary.
Engine is difficult to start when hot
  1. Check the air filter and air intake system. Replace the air filter if it is dirty or contaminated. Check the fresh air intake system for restrictions or blockage.
  2. Check for loose or deteriorated engine grounds and clean, tighten or replace as needed.
  3. Check for needed maintenance. Inspect tune-up and service related items such as spark plugs and engine oil condition, and check the operation of the engine fuel and ignition management system.
May 09, 2011 | Simpson WS5040H Water Shotgun 5000 Psi...
Spark plug is fine but it doesn't fire when you pull the cord. Water hose is connected and turned on, pressure nozzle open per instructions.
did you check for spark,maybe a new spark plug but check for the spark. if not check coil or wire and boot
Sep 12, 2010 | Honda Pressure Washer PSI 3000
I have a excel 2600 psi and there is no spark, the engine is a Honda
could be many things...get a new spark plug...check plug lead not rubbed and shorting out on body...take flywheel off and check/replace cdi...or points if it has them.
Jul 24, 2010 | Karcher 2500 PSI Pressure Washer
I need to buy a pressure washer for residential/commercial work
Were I to pick from one of those three, I would pick the Landa. The most reliable pumps are Hotsy and since Karcher bought Landa and Hotsy, those three brands now have Hotsy pumps, though it doesn't say it on the machines.
Jan 01, 2010 | Honda Pressure Washer PSI 3000
Gas pressure washer will not start
I have a 5hp honda power washer sat for 2 years it will only run if I spray gas in the carb as soon as I stop spraying the engine stops I have took off carb and cleaned it
May 31, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
