Question about yamaha boats Yamaha 6B500 Jet Boat Engine Impeller
I have a 2005 Yamaha 65 jet. It starts missing at full speed after running for about five minutes. Idles fine and runs fine and three-quarter speed.
1982 maxim 650 idles rough
Hi, Anonymous and the usual suspects are:
1. Idle speed improperly adjusted.
2. Air fuel mixture screws not properly adjusted.
3. Inlet system air leak.
4. Leaking accelerator pump.
5. Loose low-speed jet.
6. Plugged low-speed jet.
7. Contaminated or plugged low-speed circuit.
8. Enrichner valve/choke not seated or leaking.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Yamaha XJ650 Idle Problem
1994 xj600 seca 2 rough idle
Yamaha XJ750 Owners Workshop Manual
OEM parts for Yamaha
http://www.carlsalter.com/pdfs/Yamaha_XJ600SK_Owners_Manual.pdf
Aug 27, 2012 | 1982 Yamaha XJ 650
Ttr90 bogs down at high rpms
I have a ttr 90 that idles well but bogs down at full throttle. Carb is clean and has new pilot and main jets. Seems to run slightly better with intake off. Which leads me to believe the mixture is rich. No adjustment on carb. Stumped?
May 28, 2012 | Yamaha Motorcycles
2003 yz 250 starts and idles but runs rich and bogs as soon as the throttle is applied
1. Throttle cables misaligned or misrouted.
2. Damaged or restricted fuel tank venting system.
3. Intake system air leak.
4. Vacuum piston malfunction.
5. Accelerator pump leaking or no output.
6. Plugged bowl vent or overflow.
7. Fuel level in bowl too low.
8. Restricted fuel supply passages.
9. Plugged jets or passages.
10. Worn or damaged needle or needle jet.
11. The enrichner valve not seated or leaking.
2002 yz250 idles fine but bogs and tries to die when twisting the throttle...
Bike dies when you give it throttle
YAMAHA YZ250 LC Owner Service Manual
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Mar 19, 2012 | 2003 Yamaha YZ 250
Yamaha 2005 TTR250 carburetor problems
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the blue links below. Good luck and have a wonderful day.
Carb issues
2006 Yamaha Bruin 350 Starts idles dies won restart
Yamaha TTR250L Service Manual
Yamaha TT Owner Manual
Feb 26, 2012 | 2005 Yamaha TT-R 250
2008 Yamaha YBR 125 Custom. Does not want to start-up. Battery, fuel, spark, etc. OK, on centerstand, in neutral. Suddenly, it starts. Runs OK on any revs or at any speed, even with passenger. Once...
I would start with pulling the carbs, and cleaning the jets. run a wire from a wire blush , so you dont damage them, thru them, with some carb cleaner. should be fine after that. pull the jets and clean then, dont just spray carb cleaner thru them.
Mar 13, 2011 | 2005 Yamaha Ybr 125
Starts, idles and runs but quits after a few seconds of cutting
Check the air cleaner and muffler for plugging. One screw adjusts the idle stop (idle speed) position and the H and L jet screws set fuel mixture for high speed and idle speed mixture respectively. Turn both jet screws CW to stops (lightly) then back each out CCW 1-1/2 turns. This is a basic setting and should allow the engine to start and run. Start the engine and allow to warm up. Pull the throttle full on and adjust H CW until the engine starts to speed up, but 4-strokes. Correct adjustment is when the engine 4--strokes running free, but immediately 2-strokes when cutting. Release the throttle and adjust L needle CW until the engine idles fairly well, but allows the engine to 'follow the throttle'. Adjust the idle speed screw so that the chain stops turning, but the engine will continue to run. Hope this helps!
May 17, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Bogging and stalling at high RPM's
The main jet need cleaning.(you should clean them all though)
Main Jet: Main jet comes into play at three-quarters open to full throttle conditions. CRITICAL to high-speed engine operation. Not only does it meter the gas into the engine, it can aid in cooling the engine as well.
Please rate this Fixya
Jan 29, 2009 | 2002 Honda XR 250 R
yamaha boats Yamaha 6B500 Jet Boat Engine Impeller Logo
11 people viewed this question
Top yamaha boats Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a yamaha boats Boating Expert? Answer questions, earn points and help others
