Question about Samsung 50 in. Plasma TV
What would cause a samsung plasma pn50c550 screen to stay black with no sound?
I have replace the y-sustain, y-buffer, power, and logic boards.The set will click on and shut down but has no screen
    Habit-Forming:
  • Samsung Expert
  • 40 Answers
This will help you.
What would cause a samsung plasma pn50c550 screen  - 25638652-3h2yj3av3q55dwtsjmshd1km-4-0.jpg
25638652-3h2yj3av3q55dwtsjmshd1km-4-2.jpg What would cause a samsung plasma pn50c550 screen - 25638652-3h2yj3av3q55dwtsjmshd1km-4-5.jpgt/uploads/images/25638652-3h2yj3av3q55dwtsjmshd1km-4-5.jpg" alt="25638652What would cause a samsung plasma pn50c550 screen - 25638652-3h2yj3av3q55dwtsjmshd1km-4-9.jpg"h_mi" />
What would cause a samsung plasma pn50c550 screen - 25638652-3h2yj3av3q55dwtsjmshd1km-4-20.jpgages/25638652-3h2yj3av3q55dwtsjmshd1km-4-14.jpg" alt="25638652-3h2yj3av3q5What would cause a samsung plasma pn50c550 screen - 25638652-3h2yj3av3q55dwtsjmshd1km-4-27.jpg
Posted on Apr 10, 2015
Vizio LC470DUG powers on for 4 seconds than goes off--possible mother board
No such thing as a mother board in a TV set. Here is a list of the PCBs
Types of TV Boards Every TV uses a collection of various boards to perform every function imaginable in a television. The boards work together to produce sound and images on a television screen. When certain mechanisms in a TV fail, it may be time to start testing different boards to see if they are functioning properly.
Main Board
The main board, or motherboard, is the central hub of a television circuit system. The easiest way to identify a main board is to find the board with the various video and audio inputs/outputs. Generally speaking, main boards also contain a tuner, HDMI, USB, and S-video port. Main boards are one of the largest boards in a television. This part is also sometimes called the main module or the A/V (audiovisual) board.
Power Supply Board
Another large and important board inside a television is the power supply board. Usually found in the center of the TV, the power supply board has several connectors that supply power to the other circuit boards. It can contain transformers, large capacitors, and integrated circuits. There is usually a table on the power supply board indicating the different voltages it produces in addition to the signal names.
Inverter Board
Found on LCD TVs, inverter boards are used to mount the LCD backlight. These are smaller boards, usually shaped like long, thin rods. If an LCD TV's screen is dark, distorted, or difficult to see, it can be the result of a defective inverter board. Inverter boards fail when inadequate power is not allowing current to pass through the backlight bulb.
Timing Control Board / Logic Board
The timing control board, known as the T-CON board, is typically only found on LCD and LED TVs. Plasma TVs, on the other hand, use a logic board. The functions of the logic and T-CON board are similar: each functions to digitize the information it receives from the TV's processor. This allows the screen to display images on the pixel level. When the T-CON or logic board fails, the screen images may become distorted, leading to pixilation and the appearance of lines on a television. On a logic board, there are slotted connectors on all four sides, while T-CON boards have connectors on just two sides.
X-Sustain and Y-Sustain Boards
Also known as the X-SUS and the Y-SUS, the x-sustain and Y-sustain boards only appear in plasma screen TVs. The X-sustain board may also be called the Z-SUS. These boards function similarly, producing proper screen images. Although they serve pretty much the same function, the two boards work independently of each other. The X-sustain board activates all the display lines at once, while the Y-sustain board addresses all the individual lines of display. When one board breaks down, it probably does not affect the functionality of the other. However, it may be a good idea to have both replaced because X-SUS and Y-SUS boards have a relatively short lifespan anyway. A failure of one could mean an impending failure of the other.
Buffer Boards
Buffer boards are also only found in plasma screen TVs. Connected to the Y-sustain board, a buffer board works to turn output to the plasma display. Common defects of buffer boards include the burning and shorting of power lines.
Dec 03, 2016 | Vizio Televison & Video
How do I fix a LG plasma tv that has sound and no picture.
If you wish to get some details; check the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
May 15, 2016 | LG 50PT350 50 in. Plasma TV
Tv repair.for plasma tv
No screen boards found. Do you mean any of these?
Types of TV Boards Every TV uses a collection of various boards to perform every function imaginable in a television. The boards work together to produce sound and images on a television screen. When certain mechanisms in a TV fail, it might be time to start testing different boards to see if they are functioning properly.
Main Board
The main board is the central hub of a television circuit system. The easiest way to identify a main board is to find the board with the various video and audio inputs/outputs. Generally speaking, main boards also contain a tuner, HDMI, USB, and S-video port. Main boards are one of the largest boards in a television. Main boards might also be referred to as a motherboard, main module, or an A/V board.
Power Supply Board
Another large and important board inside a television is the power supply board.. Usually found in the center of the TV, the power supply board has several connectors that supply power to the other circuit boards. It can contain transformers, large capacitors, and integrated circuits. There is usually a table on the power supply board indicating the different voltages it produces in addition to the signal names.
Inverter Board
Found on LCD TVs, inverter boards are used to mount the LCD backlight. These are smaller boards, usually shaped like long thin rods. If an LCD TV's screen is dark, distorted, or difficult to see, it can be the result of a defective inverter board. Inverter boards fail when inadequate power is not allowing current to pass through the backlight bulb.
The timing control board, known as the T - CON board,, is typically only found on LCD and LED TVs. Plasma TVS, on the other hand, use a logic board.. The functions of the logic and T-CON board are similar, as each functions to digitize the information it receives from the TV's processor. This allows the screen to display images on the pixel level. When the T-CON or logic board fails, the screen images may become distorted, leading to pixelation and the appearance of lines on a television. On a logic board, there are slotted connectors on all four sides, while T-CON boards have connectors on just two sides.
Also known as the X-SUS and the Y-SUS, the x-sustain and y-sustain boards only appear in plasma screen TVs. The x - sustain board might also be called the Z-SUS. These boards function similarly, producing proper screen images. Although they serve pretty much the same function, the two boards work independently of each other. The x-sustain board activates all the display lines at once, while the y - sustain boardaddresses all the individual lines of display. When one board breaks down, it probably will not affect the functionality of the other. However, it might be a good idea to have both replaced because X-SUS and Y-SUS boards have a relatively short life span anyway. A failure of one could mean an impending failure of the other.
Buffer Boards
B uffer boards are also only found in plasma screen TVs. Connected to the y-sustain board, a buffer board works to turn output to the plasma display. Common defects of buffer boards include the burning and shorting of power lines.
TV Boards Buying Guide
Nov 28, 2015 | Hitachi P50H401 50 in. Plasma HDTV
I have a Samsung Model HPT5054X/XAA 50" plasma TV. the picture went black but still have audio.I purchased a reman Y sustain board.The Y buffer boards looked good. Now when I reassembled the unit,st
Did it work with the Y-sustain board replaced? Likely if it did not work then there is an issue with the capacitors on the Y-sustain board and the power board. Check these caps for failure and replace them with the exact type. Likely the caps are blown and cause voltage loss in one or both boards.
Feb 01, 2015 | Samsung HPT5054 50-Inch Plasma HDTV
Samsung TV Plasma heard a pop then screen went black red blinking screen
How old is the set? Are you attempting to fix yourself? The popping/no picture issue is usually do to a faulty y buffer or y sustain board. If you are willing to open up the set, I would look for blown IC chips on the y buffer (long skinny boards on the far left) boards and for any blown components on the Ysustain (located just to the right of the y buffers) board. If you are considering taking the set to a shop I'm here to tell you it will be cheaper to replace vs. repair. I hope this helps and if you have time please sign my guestbook
http://www.back2lifeelectronics.com/Guestbook.php
Jun 10, 2014 | LG 42PQ30 42 in. Plasma TV
My samsung plasma becames black with sound but no screen after 1 min after turned on. we turn off the tv and turn on again and do it again.
Black screen on the PLasma TV can be caused by failed sustain boards and or power supply. I would inspect the caps on the sustain boards and the power supply boards first.
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Dec 08, 2010 | Samsung SP-R4232 42 in. Plasma HDTV
Short circuit on the "Y" sustain board
The problem is heat!!! If the tv has fans they should be checked for normal operation,although on the early samsung models there were none, and the problem is that the panel drive buffers are getting to hot due to inadequate cooling. This is most apperent when tv is mounted to close to the wall, also external fan blowing on the rear left side will dissapate the heat. It is a problem on early Samsung and Electrograph 42 " plasma models. Hope this helps.
Jul 28, 2010 | Samsung Televison & Video
1/2 screen blacked out
There is a couple of problems that will cause this symptom. The lower y-buffer board, y-sustain board, or the z/x-sustain board, on rare occasions the power supply. Most manufacturers tech support recommend replacing the buffer and the sustain boards, because there is no easy to isolate the problem. The easiest way is to swap boards till you find which one is bad, and this gets expensive. The buffers range from $75 and up, and the sustaines from $250 up to $400 each.
Aug 30, 2009 | Samsung HP-R5012 Television
RE: Dell W4201C
a few things, on checking the ground, are you sure you have a good connection (try scratching or pushing harder with your probe tips) to ensure that is 0v they should all be reference gnd which is 0v
did you know that there are two (2) power supplies? This set has a power and sub power supply, did you check both?
I tried to look at your posted pic, but that site blocked your image (no hotlinks allowed)
Jul 29, 2008 | Dell W4201C 42 in. Plasma HDTV
Samsung  50 in. Plasma TV Logo
166 people viewed this question
Henry  Thomas
Henry Thomas
