Question about Kubota Garden
I just put main beariins in my b7100. now it will not start. a little white smoke comes out but not much
  • 773 Answers
Sad to say, you may have not put the oil seals back in properly. Did you coat he new seals with oil first and "seat" them? Sounds like the seals are leaking. White smoke; however, is the tell-tale sign of a head gasket failure. Run your car and see if water drips from the exhaust pipe. There is an inexpensive dye test that you can buy at any larger auto parts store to assist with confirming a failed head gasket. The most common reasons for failing head gaskets after rebuilds is not using new studs and bolts and/or not torquing the bolts to the proper torque in the correct order to assure they go on with even tension. Head studs and camshaft bolts are only intended to be used one time to assure proper torque.
Posted on Apr 10, 2015
White smoke coming from exhaust,need help
White smoke is condensation from a buildup of water from within the exhaust system - if it was blue smoke then it is burning oil ... let car sit for a few minutes and take the dipstick out - wipe it clean - then re-insert dipstick - take it back out and check level against gauge at bottom of dipstick if you think you may have overfilled the oil
May 07, 2017 | Cars & Trucks
White smoke delica
The thick white smoke is either burnt oil or steam you can easily identify the smell of burnt oil not really sure why you thought it would be a good idea to put a 2 stroke mixed fuel in but more than likely that alone fouled your spark plugs. But if the problem preceded the fuel blunder then your either have a bad intake/head gasket, leaking valve seats, or bad main engine seal. Replace the spark plugs and check cylinder compression. Change your engine oil and check to see if it contains water/coolant also watch for coolant or oil consumption
Apr 12, 2014 | 1996 Mitsubishi Delica
09 yamaha r6-Steam or white smoke on start up lasts for about 3-5 minutes
Hi, 123gevans your instrument gauges and lights can alert you to most electrical and engine issues they can not warn you about failed engine gaskets or seals so your engine has to resort to old fashion alert methods of colored "SMOKE SIGNALS" here is a breakdown of their meaning:
1. COLORLESS OR SLIGHTLY BLUE SMOKE on start-up means your air/fuel mixture is at the right composition and everything is well burnt in your combustion chamber.
2. BLUE SMOKE on start-up is usually caused by failed valve seals dripping oil into the combustion chamber when the engine is not running.
3. YELLOW OR BROWNISH SMOKE at start-up means your air/fuel mixture is too lean. Too lean means that there is low fuel but high air mixture in your combustion chamber.
4. WHITE SMOKE on start-up may be caused by a blown head gasket allowing coolant to enter the combustion chamber and may start dripping out of the exhaust pipes or mufflers. Smoke while riding is usually caused by worn out or damaged valves, seals, guides, pistons, rings, or cylinder walls.
5. BLACK SMOKE on start-up is usually caused by too much fuel in the combustion chamber this can be due to air/fuel mixture adjustment too rich, accelerator pump improperly adjusted, faulty choke/enrichner or not in the off position, air filter dirty and clogged, faulty carburetor float needle and seat, pilot jet too large, fuel injectors leaking, smoke while riding is usually caused by the main jet being too large or a damaged carburetor.
It should be noted that aggressive or abnormal throttle operation will cause these conditions to manifest themselves exponentially.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
07 08 white smoke in the exhaust
smoke from exhaust after oil change
Yamaha YZF R6 Service Manual
OEM parts for Yamaha
Yamaha YZF R6 Owner Manual
May 25, 2017 | 2009 Yamaha yZFR6
White smoke coming out of my yamaha 2008 r6 whenever i start the bike. why is the white smoke coming out ?
Hi, Anonymous your instrument gauges and lights can alert you to most electrical and engine issues they can not warn you about failed engine gaskets or seals so your engine has to resort to old fashion alert methods of colored "SMOKE SIGNALS" here is a breakdown of their meaning:
1. WHITE SMOKE on start-up can is usually caused by a blown head gasket allowing coolant to enter the combustion chamber and may start dripping out of the exhaust pipes or mufflers.
2. BLUE SMOKE on start-up is usually caused by failed valve seals. Smoke that is constant while riding is usually caused by valve to guide and piston ring clearances that have exceeded service wear limits.
3. BLACK SMOKE on start-up is usually caused by too much fuel in the combustion chamber this can be due to air/fuel mixture adjustment too rich, accelerator pump improperly adjusted, faulty choke/enrichner or not in the off position, faulty carburetor float needle and seat, pilot jet too large, fuel injectors leaking, smoke while riding is usually caused by the main jet being too large.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.r6-forum.com/forums/57-garage-mechanical-help/205697-white-smoke-exhaust.html
White Smoke Coming Out My Exhaust Please Help
2008 2009 Yamaha YZF R6 Service Manual R6 Moto Data Project
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Apr 28, 2012 | 2008 Yamaha YZF-R6
I have a honda accord 97 v tec T fix the head and put the main bearing and stil smoked
white smoke is water lite blue or black smoke is oil. Replacing the main bearing would not cause it to smoke, Could be eather a bad plug not getting fire or oil fillen, or bad ring's good luck to you.
Mar 27, 2011 | Honda Accord Cars & Trucks
Hesitating, has white smoke, and now sputtering
White smoke + engine not fully working = head gasket failure. Replace it.
Apr 04, 2010 | 1997 Mitsubishi Eclipse
Lawn mower engine runs rough and puts out white smoke
Pull the carburetor and clean it for staters.Be sure to change oil any little bit of moisture in the crankcase will let it smoke white by seeping by the valves and piston rings.Also put a little small amount of dry gas in the gas tank to rid all of the water that may have been left in the tank. I some of this will help you.
Mar 18, 2009 | Garden
White smoke useing a little oil
sound like your valve seals are goin. I wouldn't worry about it until it starts smoking alot more and burning alot of oil.
Feb 08, 2009 | 1989 Toyota Supra
Nissan Sentra 2000 model. Thick White smoke coming out of exhaust
Is the car runnig little rough on cold start up in themorning for few seconds?? Because I have done quite a few headgaskets on QG18 Sentra aka 1.8 liter nissan sentra. here is the test. Fill up your overflow bottle to the full mark and check the coolant level in about 5 days.(drive it normally as if nothing is going on) If the level is down, your head gasket is gone. How about the check engine light , is it on?? post results.
Aug 01, 2008 | 2003 Nissan Maxima
Garden Logo
80 people viewed this question
Top Kubota Garden Experts
Vernon Taylor
Mike Henne
Level 1 Expert
Are you a Kubota Garden Expert? Answer questions, earn points and help others
