Question about Toshiba 36A43 36" TV
Won't turn on or off - red light blinking
TV was working fine and taping a show - I left the house and when I came back the tv screen was blank and the little red light by the power button is blinking - TV won't turn on or off
  • stumpedinFL Nov 14, 2007
    I thank you for the prompt response - don't know where to look for the fuses much less know if they look okay - too heavy to lug around town - going to run down to Best Buy and purchase a new set
  • 1,139 Answers
This sounds like a power supply problem, visually check the fuses and if they look ok, and you have a backgroud in electronics test to see if the set is prducing Dc voltage, you will need a multimeter and a schematic to do this with. However, if you do not have a background in electronics please take the set to a qualifide TV repair shop to have the repairs done.
I hope this helps.
Thank you,
Posted on Nov 14, 2007
Samsung plasma blinking red light, tv won't turn off
Hello, The real problem is on your TV 'scircuit. Due to high electric power supply there might be a short circuit damage. It's better you call up your service technician and ask him to offer you a onsite support.
Nov 11, 2017 | Samsung PN51D7000 3D Plasma TV
Yesterday i changed the lamp. After this I turned the TV on and it worked fine. This morning, upon turning it on,it showed for a few minutes and then the screen went blank, the green power light started to...
how many times is the red led blinking? if you just changed the lamp make sure and check that the lamp door is secure if the door is ajar it will flash 3 times.
Dec 22, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Dec 22, 2009 | Sony KP-46WT500 46" Rear Projection...
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Stuck in standby
Sorry about that. When the tv goes bad like not turning on, the green light will blink, and goes right back to red standby light while the dtv letters will briefly show on the lower right of the tv screen, then go back to blank screen. The tv will need to be taken to an authorized service center for repair. Common causes are a bad inverter/power supply, power control board, or circuit board.
May 16, 2009 | Emerson LC320EM9 32 in. LCD HDTV
It will power on but then turn right back off it worked fine yesterday
One of four things happen when these lcd's get power problems. 1. They either go completely dead[no power with no lights] 2. Little green light will blink and go back to red with dtv briefly showing and then the tv screen go blank 3. Same as # 2, but with screen staying blank. The fourth is extremely rare, which is a shorted panel that makes the tv set behave like it's getting no power. All signal a bad tv, and the fourth is not usually repairable, requiring a whole new panel. I hear that power flows thru the panel, so that would explain how sometimes it will short out.
Apr 28, 2009 | Emerson EWL3706 37 in. LCD Television
I can't get my tv to turn on... nothing but blinking red light
Dont know if this will work for you or not, but my brother gave me his because of the same problem. It would power up and a green light would come on, then after 10 -15 seconds it would change to a red blinking light. I plugged a usb cable into the service port on the side and left the other end unplugged. Then plugged the tv back into the power. i took a small screwdriver and ran across the contacts in the end of the usb cable until both the red light and the green lights came on. I did this several times listening fot the clicking noises in the TV. after doing this for approx 20 seconds, i pressed the power button and the TV worked fine. 5 days now and no problems. Only thing I can think is I somehow reset the software and now it is working fine. Hope some of you can figure this out and give it a try. if the TV is just sitting, you have nothing to lose
Aug 17, 2008 | Philips 26MF231D 26 in. LCD Television
Toshiba 36A43 36" TV Logo
209 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
