The HD how can I turn it back on it is disabled
  • ray gallant Apr 10, 2015
    Hi Tony Noble, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? without posting make and model there is no way we can assist you
Panasonic viera cc
Try identifying which caption is from the TV and which is from the cable box by turning the TV Closed Caption on and off while you have to sets of captioning. This will show you which closed caption never turns off.
Aug 08, 2013 | Televison & Video
Greetings, I have a Gateway 832Gm Media Center PC, I want to add a Radeon HD 5550 graphics card to get the ability to get dual monitor support. My question is do I disable the chipset via the bios or can...
Most likely what you will want to do is just turn your resolution down to it's lowest settings. and turn off unplug the computer and install the card. Plug the monitor into the card and then boot up the computer. Sometimes depending on the computer you may have to disable the onboard video in the bios but a lot of times you don't. If you do run into an issue you can unplug the card hook the monitor back up the onboard video, then if need be disable the onboard driver, by going to control panel, then system properties, then device manager and then under video adapter disable the drivers for the onboard video but it shouldn't be necessary.
Thank you,
Lee
Dec 07, 2010 | Gateway 832GM PC Desktop
In turning on my handycam, I get the message "movie recording disabled". How do I get out of this disabled mode?
It seems problem with hard disk that need to be formatted, please make sure you have copied/ transferred recorded files in computer or format HD will delete every thing on HD.
Press Menu button on lcd screen and select settings then select HD and select Format, it will take little time to format hard disk.
Now you can record in camcorder.
Thanks.
Jul 28, 2010 | Sony Handycam DCR-SR40 Camcorder
Camera shows hd movie recording disableD
HD movie recording disabled: SOLVED for 2 HDRSR5's (work and home): After copying all movies to computer, "DELETE ALL" from HD view. Evidentally if you have been deleting movies using computer, the still images used for 'scene selections' remain and fill its capacity. You must be in HD view when choosing Delete All (that is, rather than just deleting all Standard movie clips)
Apr 04, 2010 | Sony HDR-SR12 HDD Camcorder
How do I turn off the closed captioning in HD
If you are using a HD cable or Satellite box, the closed captioning has to be disabled on those devices.
Nov 03, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Cant get it to go back to av
You have to reset the display setting and this is how you do it. make sure ther is no disc in the system, turn off ps3 in the back (main power switch), turn that switch back on and you should have a red power light, hold the power button, you will hear a beep right away and the a 2nd beep a few seconds later and then let go of the button. The light should be green, if it still does not work try the steps 1-2 more times. If this does not work, you will need to cal 1-800-345-7669 to get your ps3 serviced
Aug 10, 2009 | Sony PlayStation 3 40GB System
Toshiba 62hx94 cant shut off closed caption have comcast cable How do I turn off closed caption on my TV. It suddenly turned on.
if the tv is not hd then the control is on your tv.
However if the comcast box is an hd box do the following;
Press cable, then power and then with 2 seconds press the red menu button to get the hidden hd user setup menu. You may have to hit the menu button multiple times to get the menu to stay up on the tv.
Next go down to closed captions which is probably enabled, and hit the left or right arrow key to change it to disabled.
Then press the power button twice to turn the box off and back on.
Dale
Dec 26, 2008 | Toshiba 62HMX84 62" Rear Projection HDTV
My ATI RADEON HD 3870 over-clocked edition wont work. Plz help.
if your original graphic card was intecrated then u most first disable it in bios then u can use the new one
Dec 26, 2008 | VisionTek RADEON HD 3870 X2 Video Card -...
Closed captions go on and off sporadically
if the comcast box is not hd then the control is with your tv/remote.
If the comcast box is hd, then you can control it from the comcast remote. To do this press cable, then power and in 2 seconds press menu to get to the hidden hd setup menu, scroll down to closed captions and set it to enabled or disabled then press power twice to get back to you rtv
Nov 26, 2008 | Toshiba 42LX177 42 in. LCD HDTV
Turn off closed caption on input(component) on Sharp Aquos 42"
I have a Sharp Aquos 46" and go a Comcast HD receiver as well, and had the same problem turning off the Closed Captioning. I order to turn it off you need to go into the box user setting by (starting w/ the cable box and tv on) pressing the power button for the cable box then the menu button for the cable box. This will open up the user settings menu. Just toggle CLOSED CAPTION to DISABLED.
Jan 29, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
