Question about Whirlpool AKZ 515 Double Oven
F03 Bottom oven only not working.Have replaced temperature sensor and checked thermal fuse. Still the same warning.
Is there also a Control Panel Thermal Fuse If so where If that fuse is OK what could the problem be
    Top Expert:
  • Whirlpool Master
  • 43,064 Answers
Check the element probably burnt out
Posted on Apr 10, 2015
What is error code f03 and how do i fix it
F3 or F4 Open or shorted oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
May 19, 2015 | Hotpoint Ovens
Free fuse box diagrams
Parts #: W10317343
Substitution: WPW10317343 $145.98 at sears
Parts #: W10354052
Substitution: WPW10354052 $125.92 at sears
Part #: W10317347 front LED board $230 at sears
Many ovens have a bi-metal thermal fuse-also called a thermal limit switch-that protects the oven from overheating. The oven thermal fuse trips when the temperature in the oven gets too hot. After the thermal fuse trips, the oven won't heat. If the thermal fuse trips after the self-cleaning cycle, try resetting the fuse by turning off electricity to the oven, removing the exterior back panel, and pushing the reset button. If the fuse tripped during normal operation, replace it. If the problem persists, the electronic oven control board might require replacement. Reset the thermal fuse after replacing the control board.
Jul 15, 2014 | KitchenAid Ovens
My built in oven AKZ 110 is showing F 03 and nothing happens when I try to tune it in to work just stays on F 03 no fan no light either
This should help any further assistance please feel free to contact me.
WHIRLPOOL
Range/Stove/Oven Fault Codes Non Y-Line
NOTE: Not valid for Y line. If there is a Y near the end of your model number, do not use this chart.
Failure
Code
Condition Check/Repair 4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock (ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3 Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse F4 Shorted oven temperature sensor Replace oven temperature sensor F6 Problem in time keeping circuit 1. Reset time and/or cooking operation
2. Check for proper ground F7 Stuck function switch or button on Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F8 Failure Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F9 Door lock circuit Check wiring and test operation of door lock switch bkg-faultcodedivider.jpg txt-gototop.jpg WHIRLPOOL
Range/Stove Oven Fault Codes, Common
Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective 4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
Jul 16, 2011 | Whirlpool Ovens
Error code 003
F03 = The oven temperature sensor is open
Check for open wire connection between EOC (Electronic Oven Control - Clock) and the oven temperature sensor. Replace sensor if no wiring problem.
Jan 28, 2011 | Frigidaire Ovens
My kitchen aid oven has error codes f3 e1 what do these mean, i can't use it , it keeps shutting off.
Hello there:
Now if it is just a f-3 and nothing else3 f 3
Jan 22, 2010 | KitchenAid Ovens
Display reads code F03 on Whirlpool oven. Can I
Hi
Thanks for using FixYa. F3 error means Open oven temperature sensor or thermal fuse. You’ll need to replace oven temperature sensor or thermal fuse to resolve the issue.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 15, 2010 | Whirlpool RBD305PD Electric Double Oven
I bought a Whirlpool double oven AKZ161 and error code F03 appear
On this model, F03 indicates a faulty power control board (also known as the "Capricorn" board by Whirlpool technicians). A new oven with no guarantee? There is usually a reason something has no guarantee, in your case, a faulty control board. It is a relatively expensive part unfortunately.
You can try disconnecting from power, removing top panel from oven. The large square electronic board you see on the top of oven is the power control board. Check all plug connections are OK, especially the large thin multi plug that goes to the display board- I have had a poor connection at this plug causes F03 faults. If still no go, power control board will need replacing
Aug 17, 2009 | Ovens
Oven won't heat
Unplug the power cord for thirty minutes, this should reset the oven.
If this still does not work do the following:
Press clean and then cancel. This will reset the appliance.
If the error does not clear , then during the self cleaning cycle, the high temperature has probably damaged the temperature sensor probe, and it must be replaced.
Dec 03, 2008 | Whirlpool RBD305PD Electric Double Oven
I keep getting an f3 code n my wall oven what does that mean ? and can it be repaied easily?
Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fusef3 falure code means oven temperature sensor or thermal fuse you have to check the oven temperature or the thermal fuse for possible replacement.hope this helps pls dont forget to rate as fixyaa .thanks and Godbless
Nov 23, 2008 | Whirlpool Kitchen Ranges
Whirlpool oven fault f03 shown
f03 error is a sensor error.you could have taken an ohm reading on the thermistor to see if it was bad.if you replaces the t-mistor then the only other component responsible is the board.make sure all the connections on the board are clean and tight before you replace it.
Sep 28, 2007 | Ovens
Whirlpool AKZ 515 Double Oven Logo
83 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
