Question about Panasonic KX-DT333-B Digital Phone
How can I change the direction of incoming calls to various extensions?
Currently, our reception phone receives the first incoming call and then the second and third incoming calls (If reception is on the phone) will go to other extensions. I need to change these extensions.
Just a guess but maybe changing the connections for the lines on the switchboard. This may also change their numbers though.
Posted on May 05, 2015
When a call comes in and I transfer to my boss' extension, incoming calls do not come through, caller states phone keeps on ringing. Also on that same extension calls do not transfer to voice mail.
  • Begin the transfer. With the caller on the line, press the "Transfer" key. The caller will automatically be placed on hold and you will hear a dial tone.
  • Connect the caller to the other party. Dial the extension of the party you wish to reach. When you hear the extension ring or after you've announced the caller, complete the transfer by pressing "Transfer" a second time. If the person does not wish to receive the call, press "Release" to disconnect from the dialed extension. Press the key beside the flashing arrow on the LCD indicator where the various lines are displayed to return to the caller.
  • Cancel an incomplete transfer. If you make an error when dialing and need to retrieve the caller, simply press the key beside the flashing arrow on the LCD indicator.
  • Park an incoming call. Parking a call at a designated extension allows the recipient to answer the call from any phone in the facility. With the caller on the line, press the "Park" key twice. If your system designates a particular extension for parked calls, the caller will be held at that extension. Otherwise, the caller is held at your extension. To specify an extension for a parked call, press "Park," dial the desired extension and press "Park" a second time. Replace the handset.
  • Retrieve a parked call. On any system phone, press "Park" and dial the extension on which the call is parked. You will be connected to the caller.
Aug 18, 2016 | Nortel Norstar M7310 Telephone
How to stop / edit all incoming calls ringing to other 2 extensions at the same time?
What phone system are you using?
I will gladly show you how
KX-TEA/TES/TA series or KX-TDA/TDE/NCP series
Oct 25, 2015 | Panasonic KX-T7633 Corded Phone
All extensions ring on oncoming call on NEC Dterm series i
.. I don't have a solution, I need a solution.
NEC Dterm Series I, through internal calls my phone flashes notifying me that I have a call coming through but it doesnt ring. I have tried the volume key ^, that didn't work. Can anyone help me?
Aug 27, 2012 | NEC Dterm DTP-2DT-1 Phone
NEC Dterm80 phone, Model DTH-16D-2. We have an Extension that rings as a back-up to the main attendent/receptionist in the event she cannot answer an incoming call. I need to disable the incoming ring at...
Hi if you just want to silence the actual unit, most often you will find a small switch on the unit, that switches OFF the ringer, or often one can turn it down, via a control on the unit. Other times one can set it Off or down in volume via the settings, use the manual in these case to ascertain what to do.
www.southwesterntel.com/.../ITH-IP%20Installation%20Manual.pdf -
Above is a manual so you can check exactly what and how to do what you want.
If this cannot be done, then take the phones case OFF, locate the "Ringer" and disconnect it from the board, problem solved.
Apr 19, 2011 | NEC Dterm DTP 16D-1 Corded Phone
Incoming calls: When we receive an incoming call,
Extension call forwarding is controlled by a timer, and they put these things in the manual. If your CF after 2 rings is from a call to a specific extension, from that extension, dial *713 and a 2 digit number from 00-99 seconds on the intercom. Start with 18.
If your call forwarding is from intercept, then you have a system programming issue and need to look in the installer's manual or check with your system programmer.
Carl
Dec 01, 2010 | Panasonic KX-T7633 Corded Phone
How do I set phone to ring at my extention?
Partner, all releases.
Examples
Receptionist Call Routing. If you want calls to be answered by the receptionist first, set the lines at the receptionist’s extension to Immediate Ring and the lines at the users’ extensions to No Ring. (This is the factory setting)
Receptionist Backup. If you want all calls on a line to ring directly at users’ extensions -with the receptionist providing backup -set the line at the users’ extensions to Immediate Ring. Then set the line (or lines) at the receptionist’s extension to Delayed Ring. An incoming call that is not answered by a user within 20 seconds will also ring at the receptionist’s extension.
Programming
To change the way outside lines or pools ring at an extension:
  1. Press [ Feature ] [ 0 ] [ 0 ] [ System Program ] [ System Program ] [ Central Tel Program ].
  2. Enter the number of the extension to be programmed for Line Ringing. The green lights next to the line or pool buttons on the phone show the current Line Ringing settings for all lines assigned to the extension. (If a line is not assigned to a button, the green light next to the button is off.) The following ringing options can be shown by the green light next to the line button.
    • Immediate Ring - on steady
    • Delayed Ring - flashes slowly
    • No Ring - flutters quickly
  3. To change Line Ringing for any line, press the line or pool button until the button light shows the correct setting (the setting for the currently selected line or pool also appears on the display).
  4. Continue programming or exit programming mode.
Dec 01, 2009 | AT&T Lucent MLS-12D Phone
During incoming call the line will go to others extension line.
Consult an expert he will fix it bcos normally they wont let go their codes.
Rate this
Apr 06, 2009 | Panasonic KX-T7730 Corded Phone
Need all incoming calls to ring on preferred phone
Depending on how the private lines were programmed, you need to pull the ringing out of DIL 1:1 if it was assigned and put it into DIL 1:N. Look at programs 407-8 and 603-4.
Carl
Feb 18, 2009 | Panasonic KX-T7425 Corded Phone
Panasonic KX-DT333-B Digital Phone Logo
607 people viewed this question
Top Panasonic Computers & Internet Experts
micky dee
Computer Repairing
Computer Repairing
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
