Question about PIAA 2003 Kia Sportage - All Sportage models - Xtreme White Bulbs
What is the recommended torque setting for the sump plug and will it need a new washer when refitted?
    Master:
  • 428 Answers
Ya wood replace it and the rule is no !!!Torquing it !! Just tighten it by hand with a Wrench or Socket Just Tight that,s it or Spend 500 dollars Later removing it cause you thought Don,t
Posted on Apr 10, 2015
Stop oil leak in sump Mazda 323 1.6 motor
1st thing I would recommend would be getting the whole engine degreased.then drive vehicle for a couple of days and then recheck where leak is coming from 100percent as it could be running down from rocket cover gasket.
if you pin point the leak is coming from the sump you will need to drain oil and remove sump and clean surface area and resell sump and refit.also replace sump plug gasket while ur going.
Apr 06, 2018 | Mazda Cars & Trucks
How to fix oil plug leaking on honda odyssey
if you are refering to the oil sump drain plug you should purchase a new copper washer when you do an oil change if the old one is refitted it can leak
Aug 16, 2014 | 2002 Honda Odyssey
How to change the oil
You will need a sump plug removal tool.
On older vehicles, this was just with a wrench.
But it could be a special key, check the plug on the base of the sump.
Take keys from ignition (as you do not want to accidentally start an engine with no oil.
Open the oil filler cap, place a container under the vehicle (could be quite a few litres of oil to come out) and remove the sump plug.
Leave the vehicle to do this for a short while, until it all stops dripping out.
Now you would want to change the oil filter.
These are in different location, but you can get a filter wrench to wrap around to remove.
PRE FILL the new oil filter with clean oil before installing (This stops any air locks when you start the engine after the change)
Hand tighten the new oil filter, they do not need a great deal of torque to screw in place. so generally a good hand tighten is enough.
You may need a new washer for the sump plug (some oil filter kits come with this in the box)
Now that the new filter is on, and the sump plug is back on. Fill the engine with the correct amount and type of oil.
I do not know the exact amount you will need.
But it is better to fill a little at a time, check the dip stick for the correct level.
When you are at the correct level.
Run the engine for a few minutes at IDLE.
Stop the engine and check the oil level again.
You should be all good after this.
Also check again after a few miles, that the sump is not leaking, and that the oil filter is also not leaking.
Apr 03, 2014 | 1998 Mercury Mystique
Oil leak renault clio 1.2 w reg
Is it leaking from the plug or the gasket around the sump? whichever it is refit it with an layer of automotive RTV silicon sealant on the joint.
Dec 15, 2013 | 2000 Renault 181
How do u replace the drain hose on the inside that is connected to the pump
most washer are set up pretty much the same ill do this by number so you can follow
1 make sure you empty washing machine either by spin cycle or manual drain through kick flap at front make sure you have rags towels bowl 2 unplug the plug from electrics 3 turn water supply off at wall disconnect water inlet pipe 4 now all electrics and water are disconnected you need to disconnect the drain hose usually attach to drain pipe behind wash be careful these are usually full so drain off 5 if you can manage yourself carefully put washing machine on its side put some towels down to protect 6 underneath usually to the front right bottom is the sump pump with the sump hose black and the drain hose grey and the manual drain hose now either by clip or screw loosen the drain hose it is usually attached up the sides by clips they can just be pulled off one free from the sump motor just pull it through if refitting remember its just all reversed what you have done good luck
Mar 10, 2013 | Siemens WFXD5200UC Front Load Washer
Oil drain plug for 2006 flhrs
The nut is a 5/8 socket, its almost directly under the seat on the bottom of the engine. Best to pull out the dipstick to drain the oil quicker. Use a new washer when you refit the sump plug to prevent leaks.
Jan 26, 2010 | 2006 Harley Davidson FLHR Road king
Overfilling
usually a blocked sump hose.. accessible from the rear lower panel..(power off and plug out 1st).. it has a large jubilee clip and inside is a white filter cage.. when refitting make sure connection is remade correctly. i stress this as the older sumps can be a pain to refit so only attempt if competent else a flood will be at hand when used..failing this then a faulty pressure switch or nic in pressure hose...Thanks
Dec 15, 2009 | Hotpoint WMA44 Front Load Washer
PIAA 2003 Kia Sportage - All Sportage models - Xtreme White Bulbs Logo
659 people viewed this question
Top PIAA Optics Experts
Lawrence Oravetz
Vernon Taylor
Are you a PIAA Optic Expert? Answer questions, earn points and help others
