Question about Epson LX-300+ II Matrix Printer
Printer does not print pdf file and set as default not select show error 0*00000709
SOURCE: CX5000 can't connect to printer
My son came by and fixed the problem. Thanks, Terry Eden.
Posted on Feb 13, 2008
Basti
  • 1447 Answers
SOURCE: epson tm u220
What type of interface card are you using to connect printer to your computer?
Posted on Apr 04, 2008
SOURCE: problems with regular printouts
That's been the work around. open the print window, select the Lexmark printer then select the HP printer and it works. but you know what happens when your end-users have to click more than once...not acceptable...I'm still working on this issue myself.
Posted on May 13, 2008
luciana44
  • 292 Answers
SOURCE: Epson Stylus T10 printer prints out random symbols from PDF file
When you attempt to print, make sure you are using the correct printer. If you had an old printer before, its name will be still in the printers' list.
and unknowingly you may be trying to print with that printer. To check this:
Goto the File Menu -> select Print-> Highlight the printer you are currently using, and then Print.
I am pretty sure this will solveyour problem.
If it does, give a rating to this answer.
Have a good day.
luciana44
Posted on Jan 06, 2010
  • 124 Answers
SOURCE: I have an Epson TX100,
Go to Control Panel - select Printerss - right click on your printer - click on Remove Printer - reboot - printer drivers should reinstall automatically.
Posted on Aug 03, 2010
Error 5
If no default printer is selected, or no printer driver is installed, Printer Error #5 is displayed.
Select a default printer in Windows by going to your Control Panel > Printers. Highlight your Printer and go to File on then Menu Bar and choosing Set as Default.
If the correct printer is already set as the default, and you get Error #5, try setting another printer as the default printer. Then select and set the desired printer as the default, and reboot the machine. This sometimes clears the problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/printer-support/
Mar 15, 2013 | Canon PIXMA MP150 All-In-One InkJet...
Tip
Printer Offline Error
If you are getting an error message that states USER INTERVENTION REQUIRED or USE PRINTER OFFLINE, the printer driver may have become disabled. Please follow the directions below to resolve this issue.
Please note that the printer must be in an online state/Print mode.
WINDOWS 95/98/ME/NT/2000
1. Click on START, SETTINGS, and PRINTERS.
2. Highlight the icon of your printer with a single click.
3. Click on FILE.
4. The only check mark showing should be beside SET AS DEFAULT.
5. Ensure that there is no check mark beside PAUSE PRINTING or USE PRINTER OFFLINE.
6. Simply click on the check marks to remove it.
7. Try printing.
WINDOWS XP
1. (a. Click START select CONTROL PANEL and click on PRINTERS AND FAXES.
NOTE: If you cannot locate PRINTERS AND FAXES, Follow 1(b..
1. (b. Click START select CONTROL PANEL double click PRINTERS AND OTHER HARDWARE, and click on VIEW INSTALLED PRINTERS AND FAXES.
3. Click on FILE.
7. Try printing.
on Jun 04, 2008 | Epson Stylus Photo R2400 InkJet Printer
Sometimes when I print .pdf file the computer request me put the file name instead of printing
this happens when you have selected a PDF printer instead of the real Physical Printer for printing
a PDF printer is a software which converts any thing sent out like a document or file for printing into a PDF file tis is useful for saving data from files or majorly from websites and emails as a softcopy on your system.
next time on, when printing check to see that the selected printer on default is a Physical Printer (like HP or Cannon etc.) connected to your computer and you'll have your hard copies
hope could be of help, cheers
Mar 28, 2011 | Computers & Internet
Quicken will not print. Program aborts after error message: Problems communicating to printer: "Dell Photo Printer 944" The specified resource name cannot be found in the image file.
Ensure that your printer is online and all cables are securely attached.
(i) If your printer is on a network, ensure that your network allows you permission to access the printer.
(ii) If you are printing to paper, ensure that the Quicken PDF Printer is not selected.
(iii) If you have more than one printer:
(iv) Ensure that you have selected the correct printer in Quicken. (Select the QuickenFile menu, select Printer Setup, and select the item you want to print. Be sure the correct printer shown in the Printer field. For example, if you are printing a report, select File > Printer Setup > For Reports/Graphs.)
(v)Try making another printer the default printer.
Microsoft Windows Vista:
Click the Microsoft Windows Vista logo (Start button) and select Control Panel.
Under Hardware and Sound, click Printer.
Select the printer and click the Set as default command button.
Microsoft Windows XP:
Click the Microsoft Windows Start button and select Printers and Faxes.
Right-click a printer and select Set as Default Printer.
(vi) Try printing from WordPad or Notepad to be sure Windows is communicating with your printer.
Click the Microsoft Windows Start button, select All Programs or Programs, select Accessories and select WordPad or Notepad.
Enter some text. Select the File menu and select Print.
(vii) If your file does print from WordPad or Notepad, try reinstalling the printer or printer driver.
(viii) If your file does not print from WordPad or Notepad, it probably means that Windows is not communicating with the printer. Check your Windows printer settings.
Thanks for using Fixya.
Good Luck and have a nice day.
May 25, 2010 | Computers & Internet
Can't print multiple PDF files in 11x17 format. I open windows explorer and select the specific PDF files. Click on File, Print. They all print out, but they all are 8 1/2 x 11 on a 11x17 paper, instead of...
Adobe Reader can be real pain it the... neck sometimes.
But first I would inspect not only the printer setup, but also printer's default print settings. Windows XP has 3 places, where you can see the printer options:
1. Printer properties
2. Print preferences
3. Default print setup.
The third one is the one you have to set. When you double click on your printer icon, a print queue window opens. Choose Printer->Properties, go to Advanced tab, and on the bottom there's a button "Default print setup" (I don't have English XP handy, so I'm translating back to English from my version - excuse me if they might appear a little different).
It's there you need to set up the default page size and so on.
If this still doesn't help, try opening Acrobat Reader, setting the Page Size Scaling to None, printing something and closing Acrobat Reader. From what I've seen, it tends to remember this setting from previous sessions.
You may also try alternative PDF readers, like Foxit Reader or PDF Xchange Reader.
Good luck :)
Oct 28, 2009 | Adobe Acrobat Reader 3.0 for PC/Unix/Mac
Error 49A What does this mean?
Hi! I will be glad to assist you. If this is your issue, here are the steps you need to do:
HP LaserJet P3005 Printer Series - Service Error 49.0E00 when Printing PDF Files from Mac 10.5
Issue
A Service Error 49.0E00 message appears while printing PDF files from Mac 10.5 with the EconoMode setting enabled from the printer control panel and using the printing presets with the EconoMode setting disabled.
Solution
Recommended action:
Disable the EconoMode setting from the printer control panel (the default setting is OFF ).
Select printing presets with the EconoMode setting disabled.
Try performing a test print from PDF files in the computer to check for the results.
NOTE: If it is required to use a printing preset with the EconoMode feature turned off, ensure that EconoMode is set to OFF from the printer control panel also.
or you can go to this link:
http://h10061.www1.hp.com/ccsearch/search?ctry=us&lc=en&dlc=en&mode=lz&tmv=0&method=prodFinder&pid=1846089&productBigSeriesOid=1846087&spid=1846090&pname=HP+LaserJet+P3005+Printer&opname=HP+LaserJet+P3005+Printer&pname_desc=HP+LaserJet+P3005+Printer&st=1&ptype=commercial&stype=pn&qry=Error+49A&translate=&iqry=&ctflag=&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-007%2Cs-005%2Cs-017%2Cz-001%2Cc-002%2Cc-001&spname=HP+LaserJet+P3005+Printer&cqry=&uqry=&product_line_code=PQ
Oct 05, 2009 | HP LaserJet 3055 All-In-One Printer
Time Out Error
This is from Xante's 3G Manual (downloadable via PDF)
"Printer Timeout The Timeout feature allows you to select the number of seconds the
printer waits for additional data before cancelling a job and returning
to the READY/IDLE state.
Set Timeout from the MISC:TIMEOUT configuration menu. The
factory default of 40 seconds (40 Sec) is an average setting. Set
timeout according to the type of files you send. Use a low setting for
small, simple files to prevent an indefinite tie-up on one job. Use the
300 or Never setting for large files, such as graphic intensive or CAD
(Computer Aided Design) files, to allow enough processing time.
With the NEVER selection, the printer does not timeout; it waits
until it receives additional data or until the printer is reset."
Here is the address where you can download the manual:
http://www.xante.com/support/aw3g/manuals/PDF/complete.pdf
Nov 15, 2008 | Xante Accel-a-Writer Laser Printer
The spooler is not connected
3. Click on FILE.
7. Try printing.
WINDOWS XP
3. Click on FILE.
7. Try printing.
pls rate as fixya if helpful! thanks!
Jun 18, 2008 | Computers & Internet
Printing Problem
You can print the Coniguration page and demos?
If so, somehow you may the settings to the printer wrong.
If you select , file, then print, see that the proper printer is selected.
If you can print those other pages, the printer and connection is fine. There is some setting not sending the print job from the applications.
Really sounds like the printer has be deselected at the default printer
Dec 07, 2007 | HP Color LaserJet 2600n Printer
Epson LX-300+ II Matrix Printer Logo
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
