Question about Cobra 29 WX NW ST 40-Channels Base CB Radio
The weather channels quit working on my cobra 29 nightwatch.
CB works but no weather channels, you can run through all seven frequencies and no affect, sounds like it's trying to receive all seven channels at once on every channel
    Genius:
  • Cobra Master
  • 1,795 Answers
Its an internal problem , take it to a tech and let them fix it. the board for the wx probably has jumped freq. and thats why you can't receive wx.
Posted on Apr 15, 2015
    Top Expert:
  • Cobra Master
  • 10,875 Answers
Check antenna and connections
Posted on Apr 10, 2015
Every time i turn on my cobra 29 wx nw st sound tracker it goes back off
Hi Davis, please post on CB radio forum, this is Radio scanner forum.
Cheers,
Peter
Feb 20, 2013 | Cobra 29 Wx Nw St 40-channel Nightwatch Cb...
How does the nightwatch work
turn the radio on at night and you will see.
Nov 25, 2012 | Cobra 29 WX NW ST 40-Channels Base CB...
With my cobra 29 wx nw st I can not pick up any weather channels. I have the k30 antenna. Do I need a dual band antenna?
Do you hear static when you turn on weather? If so there are just none in range of you. There are not weather radio stations everywhere. You would not use a dual band antenna on any CB. Only an antenna designed for the 11 meter band. Which is the 27mhz CB radio band.
You can go here and see if you have NOAA All hazards weather radio coverage in your area.
If the CB radio is working otherwise it is most likely that there is just not a NOAA transmitter near you.
Aug 09, 2011 | Cobra 29 WX NW ST 40-Channels Base CB...
The lights on the front of my nightwatch is not working but the rest is the meter and channels light up and the dimmer works just the backlighting wont whats the problem thanks
  • That Night Watch face plate is AC ran by a converter inside the radio. The LEDS are part of the face plate and sold as one unit. The face plate goes out often on these radios. In short the face plate needs replaced if you want it to light up. The radio's performance will not be effected by this. Cobra can actually switch that out fairly cheap. Cheaper than buying a face plate used on the net.
  • https://www.cobra.com/index.cfm
Regards, Tony
May 20, 2011 | Cobra 29 WX NW ST 40-Channels Base CB...
Information for ordering parts
find a old cobra radio and get the switch out of it or go to your local cb shop and you should be able to get one.
Mar 06, 2009 | Cobra 29 LTD CB Radio
Weather Radio won't work on 29 Nightwatch
Hello papapyr07,
It looks like you are trying to run the CB and the commercial radio off of the same antenna at the same time? This I gather is failing. This may be due to the pre-wired antenna having a filter on it to prevent exactly what you are trying to do. If this is the case you may have no choice but to run a separate antenna for your CB (this is the most logical choice), now you can try to find the filter if it is an external filter and remove it and use an antenna matching network to connect the CB to the existing antenna system (next logical, but may void the antenna system warranty). In any event you will either have to run another antenna for the CB or find and remove the present antenna filter.
I hope this helps
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Dec 06, 2008 | Cobra Radio Communications
Cobra 29 WX NW ST 40-Channels Base CB Radio Logo
179 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
