Question about Home
How to fit doona cover
Easy way
I have shrunk a Woolen Doona is there anything I can do to restore it
I would make a frame around it approximately the size it should be. then use lots of strings to pull it evenly all around. Gradually shortening the strings while working the wool to try to get the fibers to open up.
Dec 19, 2014 | Washing Machines
Drivers side sun visor, 2006 Toyota rav 4 will not stay up
there isnt really a quick fix for this, i suggest you buy another sun viser from the dealers and fit it in.
its realy easy to fit, it normaly just has a cosmetic cover that goes over the screw, pop this cover off, remove the screw and refit the new sun visor.
Feb 15, 2011 | 2006 Toyota RAV4
Acer aspire with no sound card fitted is this a reasonably easy job to fit one?
I am assuming this is an acer aspire laptop - the simple answer is no. The sound capabilities are built into the motherboard.
Dec 18, 2010 | Acer (54.AA806.001) Sound Card
I have a scotch brand laminator tl901- it is jammed...and making a clicking noise...is there a way to open the system and try to unjam it?
First, make sure that the unit is unplugged and has sufficient time to cool off. Then remove six screws on the bottom of the laminator. The screw driver shaft must be thin enough to fit into the holes where the screws are located. Two are very easy to find -- one on each side in deep holes. The other four are hidden under small black rubber disks that the laminator rests on. peel up the rubber disks and remove the rest of the screws. At this point it is easy to remove the cover and remove the jam. To replace the cover you must use a thin tool to pull back the release level so it will fit into its opening in the cover. Replace the six screws and you should be able to ready to laminate again.
Jul 10, 2010 | Office Equipment & Supplies
How do i fit a belt to hotpoint washing machine WF865
*********** unplug from mains************** top cover off ....rear cover off ....remove old belt belt ...place new belt on lower puly feed it on to larg pull turn at same time ************WATCH YOUR FINGERS ********THEY CAN GET CAUGHT EASY******* done .put covers back on ...
Dec 30, 2009 | Hotpoint Ultima WF865 Front Load Washer
Need to know how large a hole to drill into wall for manifold to fit no instructions came with my faucet set
If you can't find any documentation, the manly(easy) way would be to buy a hole saw set, find the part of the faucet that goes through the wall, and select the closet fit possible of hole saw that will fit the part. It's okay if the hole's a little bigger than the pipe because the cover plate will probably cover it up, but please double check before drilling that the hole really will be covered by the coverplate.
Oct 23, 2009 | Peerless Industries Peerless Wall Mount...
Odour filter
hi there patrick the odour filter is located under passenger footwell you will need to remove cover (if fitted) unhook fusebox from bracket remove bracket once moved you will see a cover beside heater now you will need to remove three 7mm screws once thats done remove cover remove filter & fit new one once thats done rebuild back up hope this helps you.
Jan 19, 2009 | 2000 Ford Focus
Home Logo
390 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
