Question about General Electric Kitchen Ranges
GE fridge (model tbx18saxglww) fan in freezer won't cut off.
    Top Expert:
  • General Elec... Master
  • 10,875 Answers
Close the door,let it cool down
Posted on Apr 10, 2015
I had ge refrigerator and the fridge is not cooling well
For starters a year and model number would be helpful. Do you have turn dials to contol temp of freezer and fridge or electonic pushbuttons? The fridges with manual rotating dials use a "dampner" between the freezer and fridge section. In short the freezer evap fan blows air in the freezer but also has a passage from the freezer to the fridge section which aloows a controled amount of air from the feezer section to cool the fridge section. IThis passage may be obstructed by ice build up or some other blockage. Units prior to 2002 are not controled by circuit boards and the ones after 2002 are. For more specific help give me the GE fridge model please.
Sep 24, 2012 | GE Refrigerators
I have a GE Profile freezer on the bottom refrigerator model #PDS18SBMARBS. A fan was runnining on the inside of the fridge seemed to be between the fridge and freezer. It was very loud and now does not...
Could be a bad fan motor. A bad defrost part or a bad control board.
Check for ice buildup on the back wall of the freezer. If so you have bad defrost parts or a bad control board.
Enter your model number at www.appliancepartspros.com to find the exploded view to dis-assemble the freezer. You can also order parts from them.
Aug 20, 2011 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
Have a GE profile model # PDE18LBRARSS refrigerator the freezer works but the fridge is warm, when I turn down the fridge the fan cuts out,so I don't think it's the fan.
We have the same fridge and same problem.....our fan is freezing up. We have had to take the bottom panel out and use a hair dryer to melt the ice around the fan (serveral times!) I dont know what the solution is or why this is happeneing (we have the temp set very low).
please help.
Jan 01, 2010 | GE Monogram ZIC360NRRH Bottom Freezer...
Freezer is too cold (-14 degrees) and fridge is too warm (51 degrees). The freezer keeps gettting colder but the fridge part keeps getting warmer.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
The temp sensor for the freezer may be reading the warm air in the fridge so is not cutting the compressor off.
Sep 25, 2009 | GE Profile PDS20MFS Bottom Freezer...
I have a GE Refrigerator model # TEX21J1SRRAD 20.6 cubic feet top freezer. a couple of days ago i noticed the refrigerator was getting warm but the freezer was working fine. Could this be a fan problem and...
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Aug 26, 2009 | GE Refrigerators
I have a GE TBX25PAXCRWW top mount freezer model. It is leaking water from the light switch. I would assume it is a blocked evap line. Do I access it from the insde of the freezer or outside.
Your problem is a clogged defrost drain . This is accessed from inside the freezer section and by removeing the rear freezer panel . Use a hairdryer to defrost the pan , under the coils . Also , the drain line for your model , is located behind the refrig . So , you only have a short area between the drain hole and drain line , to clear . I would suggest blowing thru the drain hose behind the refrig also , to make sure it is clear .
Jul 02, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
GE Top Freezer Fridge - Freezer Buzzing
If you remove the half moon cap, and two 1/4" screws you can remove the cover and get to the fan. The fan motor shaft is mostly wobbling around making the buzzing sound.
Jun 28, 2009 | GE GTS22WCP Top Freezer Refrigerator
Coil fan will not run.
Replace the master control circuit board on the rear of the fridge.
Jun 22, 2009 | GE Profile Bottom-Freezer Refrigerator...
GE fridge runs continuousely
Simple! The replacement fan ran the wrong way forcing air circulation the wrong way. Fortunately it was possible to reverse the moter shaft.
Dec 11, 2008 | GE GBS22HCR Bottom Freezer Refrigerator
Freezer icing up
I changed the defrost thermostat and it solved the problem.
Oct 17, 2007 | GE GBS22HCP Bottom Freezer Refrigerator
Kitchen Ranges Logo
Top General Electric Kitchen Ranges Experts
reliableservice
ray gallant
EE Eddie
Are you a General Electric Kitchen Range Expert? Answer questions, earn points and help others
