Question about Vacuums
Why won't it steam ,it makes a burring sound ,but not releasing steam
  • 774 Answers
If you are in a Soft-water area using rivers of lakes for tap water or use rain water as we do in Hawaii, add "just a pinch" of normal table salt to the reservoir and it will steam for you.
Posted on Apr 10, 2015
Sc20 trigger does not release steam
Clean jet(s) where steam comes out from . They may be clogged.
May 19, 2015 | Top Vacuums
Yello steam mop does not make steam
The release lever is held in place by tabs molded into the base. You just need use a screwdriver or two to press the plastic tabs back and then push the release lever out. The new release lever can be just pushed into place and the plastic tabs will snap and hold it in place.
Feb 13, 2014 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark s3601a no steam
Don't you have to push down on the handle while mopping the floor to get the steam to release. I know the one I have has a handle that slides down the shaft in forward mopping motion which releases the steam.
Oct 15, 2012 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Water in shark floor cleaner is not hot
sounds like some kind of bad connection to the heater in it. how about the receptacle to which you plug into the wall,. is it making good contact?
Best regards
Ck
Dec 03, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I have a turbosteamer 220 hand steamer. It heats up but won't spray steam
It's most likely the trigger not engaging the piston that releases the steam. Due to the fact that the plastic inside the 220 holding the trigger in place has cracked on both sides.It will need to be taken apart.That's another issue.Be easy on the trigger press down gentle.....
Jul 27, 2011 | Vacuums
No Steam after heating up
Sounds like the switch on the handle or the steam release solenoid on the steam chamber is faulty ,use a volt meter/tester to see if you have current to the solenoid when you turn on the switch.
Dec 02, 2008 | Euro-Pro S3325 Handheld Steam Vacuum
Polti steam cleaner
It should go just below the red providing steam isn,t escaping from the cap otherwise you won,t get the pressure build up to enable it to come out when you pull the trigger
Oct 23, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
Chain saw starts runs, bur saw won't start next time it is needed, craftsman chain saw
Steam vacuum? no clue but on your chain saw make sure you check the choke. it would explain why it wouldn't start again.
Sep 27, 2008 | McCulloch MC1275 Steam Vacuum
Hoover steam vac will not turn on.
did you drop the handle on the floor? sounds like you may have a loose prong on the on/off switch take it apart and look to see
Oct 05, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Vacuums Logo
56 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
