Question about Garment Steamers & Presses
How do i unblock the vitesse steamer
Under the plastic tray water is being held. how do i unblock it?as i cant use the steamer
Where can I get a replacement plastic part?
Try the place that you bought it. They may have the supplier / manufacturer information of where you can get parts from.
Sep 19, 2015 | Yamata PSS-2001 Power Stand-Up Steamer for...
Why doesn't carpet cleaner dispense water and soap?
Get a needle and clean all the nozzles, since they work with hot water they tend to get clogged with a white built up.
Aug 27, 2014 | Royal RY7910 Procision Deluxe Upright...
Why is there no steam?
Plugged in? Add water? Check the fuse on the power cable.
Jul 20, 2014 | Haan Complete Multipurpose Steamer MS-30R
Home Touch PS 250B
Best way is to contact manufacture and ask for part dealer near your location
Nov 17, 2013 | Homedics Home Touch Commercial Garment...
My hand held little steamer will not get hot. switch comes on, but that is all it does
If the switch isworking then the only possible fact is that the heating element has failed and it might be too costly for a change.
Jun 10, 2013 | Ingenious Designs, Llc My Little Steamer...
Conair Lysol hand held steame
It could be broken but it could also be jammed or clogged by some dirt or water. My first answer would be to get a new one. but if you dont want to throw it away you should take it to a recyling store.i know that is getting rid of it but it is not exactly because you still remember it.
May 25, 2013 | Garment Steamers & Presses
Home touch ps-250B steamer
Need Water Tank top cap which is brocken
Apr 21, 2013 | Homedics Garmet Steamer PS-250B
Garment Steamers & Presses Logo
585 people viewed this question
Top Garment Steamers & Presses Experts
Tom Chichester
Bill Boyd
ray gallant
Are you a Garment Steamer and Press Expert? Answer questions, earn points and help others
