Question about Honda Garden
What's your question? Gxv160 Honda lawnmower over reving
  • Honda Master
  • 991 Answers
You need to adjust it at the governor arm.
Posted on Apr 10, 2015
What is the tappet clearance on a Honda HRU196
The HRU196 has a GXV160 engine. Intake on the left and exhaust on the right in the following chart.
GXV160 0.15 +/- 0.02mm ( 0.006 +/- 0.001in ) 0.20 +/- 0.02mm ( 0.008 +/- 0.001in )
Feb 18, 2015 | Honda Garden
Choke not working on Honda GXV 160 for Muck Truck
Check the linkage on the carburator. Also loose mounting screws on the carb can cause a problem.
Oct 12, 2014 | Honda Vertical 5.5 HP OHV Engine 7/8 x...
HONDA MOWER CARB. LEAKING GAS OUT OF CARB
Replace carb gaskets. Replace carb bowl gasket.
Jan 15, 2014 | Honda Gxv160 55hp 55 Hp 1" To 78" Lawn...
Honda mower won't pull start
you will need to find out if you are getting a spark. generally cheap to fix it you just need to find out which part isnt working first
Jun 03, 2012 | Honda Gxv160 55hp 55 Hp 1" To 78" Lawn...
Honda lawn mower stops running
Flush gas tank, reill fresh gas & Stabil. Replace air filter and plug.
May 13, 2012 | Honda Gxv160 55hp 55 Hp 1" To 78" Lawn...
I need a repair guied to tare apart this engine
Model Number Search : eReplacementParts.com
Go to this site, it is one of the best I have found for Honda parts.
Put in your model number and you can find all parts in good exploded views.
Gary
Feb 15, 2011 | Honda Gxv160 55hp 55 Hp 1" To 78" Lawn...
My Honda Lawnmower engine is reving up and down. Tried adjusting the pilot and high speed but still reving up and down. Cleaned up air cleaner etc. Was working bang on one day and the next day went to use...
I think your mower has a blade clutch. If so, does it surge when the blade is engaged or only when disengaged? Either way it usually means there is some sort of debris in the carburetor. If it is surging with the blade disengaged, that is usually an indication of excessive wear in the carb and I would recommend to replace the carb. Otherwise, it can be cleaned.
Sep 10, 2010 | Honda Garden
I can't start my honda lawnmower, checked the oil, put new gas use choke,it gives litle sound but not enough to start
Try a touch of starting fluid right into the carburator by taking the air filter off. If it then starts but wont run or stay running, the reservoir below the carb should be removed to clean at and the pinhole in the intake tube above the bowl nut. This is the most common problem with lawnmower start problems, the pinhole can be unplugged with one wire from a wire brush. Be careful with the gas, at least pinch off the gas hose with a vise grips while removing the carb bowl.. Never use a droplight around gasoline. most lawnmowers have no mixture adjustments, so it is a matter of cleaning the carb, tank, gas lines. Some oils in gas mix systems settle and clog after less than one season. Spark can be tested by sight, remove the plug and use a clip-on ground wire from spark plug body to metal on the engine with the plug wire connected.
Jun 10, 2010 | Honda Gxv160 55hp 55 Hp 25mm Dia Lawn...
Garden Logo
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
