Question about Xerox Office Equipment & Supplies
How to get nvm mode on xerox 4595 - Xerox Office Equipment & Supplies
4 Suggested Answers
  • 62 Answers
SOURCE: xerox dc 12 mailbox finisher
its plug and play...you dont need to change anything
Posted on Nov 19, 2008
  • 62 Answers
SOURCE: mailbox ,finisher xerox dc12
i take you have a mailbox finisher. If so the finisher is plug and play with the dc12
Posted on Feb 20, 2009
upbeatjunk
  • 231 Answers
SOURCE: How activate printer xerox docucolor
I would try this:
Power off the copier/printer.
Power it back on
While it is warming up, press and hold the start button for 5 seconds.
This should activate the automatic start feature.
I hope this helps! If this did help you, please give a thumbs up!
Thank you for choosing FixYa!
Posted on Jul 06, 2011
I bought a used 7525 Xerox. Wont print now. Screen reads Activation Code Attempts Exceeded. The maximum number of Activation Code attempts has been exceeded and activation code entry is now locked.
The previous owner has set activation code check if you can get the code if unable to then reset the Xerox..use the following steps
1- enter diagnostic mode >> hold 0 10s then press start >> password 6789
2- tab on Adjustments then tab on dc301 NVM initialization >> choose copier >> selest all >> then initialize.
3- tab on call closeout then exit & reboot.
4- after the macthine turned on you find it in a non customer mode.
5- again enter diagnostic mode again >> hold 0 10s then press start >> password 6789
6- tab on Adjustments then tab on dc131 NVM Read/Write > enter 616-014 >> change the value to 2
7- again tab on call closeout then exit & reboot.
8- while the machine is turning choose customer then follow the setup as you want till reach to lock or unlock tools >> choose unlock tools.
9- you will never need the admin password again also on the web page.
Jan 26, 2018 | Xerox WorkCentre 7556/P Copier
Error 93-311 xerox 4595
That error signified a failed dispense motor. First try reset NVM 762-032 to 0. If that doesn't work replace the dispense motor.
Part number 127K38220.
Jan 30, 2016 | Xerox Office Equipment & Supplies
I have copier xerox 5021 error is 092-910 what does it mean
That error is an ATC failure. It can be caused by a bad drum or MCU Board. You can first try clear the value of NVM [752-059] (ATC Fail) or NVM [752-060] (ATC Fail Continuous Count) to '0'. Enter Diagnostics, Press and hold the [0] key on the Control Panel for 4 seconds or longer and then press
the [Start] button while keeping your finger on the [0] key.
Password is 6789. And go to NVM Initialize.
Sep 06, 2015 | Xerox Office Equipment & Supplies
As soon as machine is turned ON error code 124-315 appears. pls help!
Here is a note from a Xerox Tech:
Everything points to NVM coruption so try with reseating the NVM pwb. And then maybe NVM init.
Hope these helps.
Nov 23, 2010 | Xerox DocuColor 12 Printer
Xerox 8830 LL-60 Checksum fault
enter in diag mode and press 03-60 reset the nvm
Nov 01, 2010 | Xerox 8830 Copier
Xerox work center 5020dn service manual available here
Pl give the solution of N9 code in Xerox 5020Dn m/c.We have reset the NVM
Aug 19, 2010 | Xerox DocuColor 12 Printer
Error code 010-320?? What can I do?
  1. Press and hold the 0 key for 5 seconds, then while still holding down the 0 key, press the Start button.
    The CE Access Number screen will appear.
    Enter 6789 and press Confirm.
  2. The topmost area of the UI display will be reversed to let the user know that the mode has changed to the CE mode .
  3. then selcet NVM Read Write and enter appropriate chain (1st 3 digits of NVM) and function (last 3 digits of NVM) code .
Let me know if that works,
John
Jun 25, 2010 | Xerox Office Equipment & Supplies
Hello, after a NVM reset my ADF stop working and color where in wrong places. I resolve the color problems but ADF is not working is this activated by a NVM code? Regards, Hugo
How did you resolve the color problem? I am having the same issue on a Xerox Workcentre 24. After initializing the NVM, the auto-feeder does not work and the colors are off. How did you resolve the colors being offset?
Feb 02, 2010 | Xerox DocuColor 3535 Copier
Fault code problem whit xerox 5665
This sounds like a fuser problem, underheat or over heat. On this machine also, it might be related to NVM, or NVM memory corruption. Sometimes the batteries on the Main Board, they just get old and die.
This can be a multiple problem on the machine.
This might require a Xerox service person to visit the machine.
Some ideas are: A bad heat sensor(Thermistor), very fragil and brittle.
A NVM might need to be reset, Over heat or underheat code in the diagnostice service mode. You need a service manual to find it.Very complicated to explain.
A full sump bottle can cause this, the machine enters a code in the NVM and will keep the machine from "Logicly turning on." Or a broken full sump bottle, sensor falls off or not in place will cause the machine to enter a error code in the NVM.
Good luck.
Apr 03, 2009 | Xerox 5665 Copier
nvm 774056 if it is fuji the value -48
nvm 774056 if it is xerox the value -16
the problem is same
nvm 774057 it is 0 put 1
Jul 02, 2008 | Xerox DocuColor 12 Printer
63 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
