Question about Xerox Office Equipment & Supplies
Xerox 4595 mc has finisher but not theD finisher cannot get finisher to come when it is connected??
Error 93-311 xerox 4595
That error signified a failed dispense motor. First try reset NVM 762-032 to 0. If that doesn't work replace the dispense motor.
Part number 127K38220.
Jan 30, 2016 | Xerox Office Equipment & Supplies
Xerox 4595 error code 062-380
Platen AOC Failure.
Power off completely and then power back on.
If the problem persists please Call for Service.
Jul 12, 2014 | Xerox CopyCentre C128 Black and White...
Xerox 4110 fault code 077-330
ERROR CODE: 077-330, Front Door/Panel - DAMAGED
Apr 25, 2013 | Xerox 4110 4127 4112 4590 4595 Drum...
Xerox Staple cartridge stuck
If the cartridge is stuck in the slide it is because there are still staples in the replaceable sleeve, if the whole slide is stuck in the finisher, you might open the panel over the staple unit and see if you have staples stuck that are causing you to not be able to remove the cartridge.
Oct 25, 2012 | Xerox 4110 4127 4112 4590 4595 Drum...
Error 093-311
Hi
How to delete bug 093-311 in the Xerox 4112
br
Oct 06, 2012 | Xerox 4110 4127 4112 4590 4595 Drum...
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
