Question about Sony RDR-HXD860 DVD Recorder/HDD Recorder
No HDMI output - Sony RDR-HXD860 DVD Recorder/HDD Recorder
  • Michael Heaviside
    Michael Heaviside Apr 10, 2015
    Sony rdr-hxd860 dvd no hdmi output
    Top Expert:
  • Sony Master
  • 10,875 Answers
Hp g62 hooking it up to my samsung 1080p....should I do Hdmi to hdmi or go from monitor output to hdmi on tv
its not right to use the VGA output ( Monitor output ) its better to use the HDMI output, plus you can't hear sound from VGA output.. so the best is HDMI
Aug 04, 2011 | Computers & Internet
My playstation 3 will not display a picture i changed the settings from output HDMI to output RCA and now there is no screen on ether output but there is audio on the HDMI output how do i get the picture...
Turn off the PS3 and take the HDMI cable out, then switch it on again holding the power button for about 10-15 seconds until it gets turned off. This should reset the output settings. After that, put the HDMI cable back in and switch the PS3 on , if you did everything right it will ask you to confirm the HDMI output.
Philip
May 26, 2011 | Sony Playstation 3 (PS3) Console
How do i connect my laptop to my dvd player using hdmi cable
The HDMI connector at your laptop is output. The HDMI connector at the DVD player is an output also. So it's out of the question to connect two outputs, you may want to use the HDMI output from the dvd player to be connected at a tv or screen with HDMI input.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Mar 12, 2011 | Toshiba Computers & Internet
How do i connect my z5610 to my hd tv there is no hdmi or vga output on the pc
> no HDMI or VGA output
Every PC has either one DVI or one VGA output.
Does your z5610 have a DVI input? If so, connect the DVI-output to the DVI-input.
Or, add-in another video-card that does have HDMI output, and connect HDMI-output to HDMI-input.
Mar 06, 2011 | Computers & Internet
Component input no HDMI output
The receiver can only output picture from one video output at a time...ei; component video and HDMI cannot operate simultaneously. Nor can it transfer a signal from a component input to an HDMI output or vice versa. The input and output connections must match.
Apr 15, 2010 | Marantz SR5001
RX-V465 output HDMI 1 will work but HDMI 2-4 won't, also when I hook up Wii via rca to receiver only get sound no picture.
This receiver has only one HDMI output, but 4 HDMI inputs. If some inputs don't work, try connecting the equipment (DVD for example) to HDMI input which works with other equipment....
For the RCA (composite) video input - it won't work, because this receiver don't have any video processing circuit.
So HDMI input video goes to HDMI outout connector.
Composite (RCA) video input goes to Composite outout and no other video output.
S-video input goes only to s-video output.
Dec 20, 2009 | Yamaha Rx-v465/rxv465 Home Theater...
No sound from the HDMI
This document pertains to HP or Compaq PCs with an HDMI (High-Definition Multimedia Interface) connector for connecting a monitor or TV. If you use HDMI to connect your display, you must activate HDMI sound by adjusting your Windows settings . If HDMI is not activated, you cannot hear any sound. Because of this, HP recommends that you connect analog speakers to the computer to hear sound during the initial setup of the computer. Use the following steps to activate HDMI sound on your computer: NOTE: If you ever perform an HP system recovery, you must repeat this procedure to activate sound for the HDMI connector.
  1. Right-click the Volume icon by the time in the lower-right corner.
  2. Click Playback Devices . The Sound window opens.
  3. On the Playback tab, click Digital Output Device (HDMI) if it is listed. If it is not listed, click Realtek HDMI Output . Figure 1: Digital Output Device (HDMI) selectionc01503048.gif Figure 2: Realtek HDMI Output selectionc01063625.gif
  4. Click Set Default .
  5. Click Apply .
    • If you used Digital Output Device (HDMI) , click OK to close the window. This completes the steps to activate HDMI sound.
    • If you used Realtek HDMI Output , continue with Step 6.
  6. Double-click Realtek HDMI Output . The Realtek Digital Output Properties window opens.
  7. Click the Supported Formats tab.
  8. Place a check in the 48.0 KHz check box, and make sure that there are no checks in the Dolby Digital check box and all other check boxes. Figure 3: Supported Formats settings in the Realtek Digital Output Properties windowc01503049.gif NOTE: For most TVs to play back audio, the sample rate must be 48.0 KHz.
  9. Click OK to close the window.
Nov 23, 2009 | HP Compaq Computer Speakers
Connection problem with HDMI cables on Denon AVR-589
I want to clairify you install, you sat you have I an HDMI cable running from the Time Warner Cable box to the AVR-589, going in to the TV/CBL input. From the Denon AVR-589, I have an HDMI cable running from the output to my Toshiba RV525U television.
Check the connection at the TV, if as you indicated above you have an HDMI cable from the HDMI out from the Denon to an HDMI output on the TV, if this is the case you need to have that HDMI cable plugged into an input on the TV not an output
Feb 27, 2009 | Denon AVR588 Receiver
The HDMI "input" ports damage output ports of connecting devices
i know this sounds stupid, but have you "toggled" or "played" with the HDMI cables? are they the same manufacturer? HDMI channel connections are very fickle. If just one connection is not exactly correct, they go to a limp, no go status. Since they run at such a minimal voltage, i can't see them "blowing" the outputs on the devices.however....if your cable has a serial type output for video only, I would connect the hdmi convertor to it and see if it works.
Jan 10, 2009 | Yamaha HTR-6140 Receiver
Onkyo TX-SR875
My mistake, HDMI in is not routed to any other output but HDMI out
Oct 04, 2008 | Onkyo TX-SR875 Receiver
Sony RDR-HXD860 DVD Recorder/HDD Recorder Logo
65 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
