Question about Dishwashers
Hello, Can you please assist? I need to replace the basket wheels and holding clips on a D101 dishwasher. Is this something you can help with?
Upper and lower basket wheels required - checked on line but could not find the correct ones. The wheels appear to be the larger size, based on my checks online. Thanks
    Top Expert:
  • 10,875 Answers
Discontinued,no parts available,look for comparable parts
Posted on Apr 10, 2015
Replace Belling/Stoves/New World dishwasher upper basket runners
Take and remove the sides. There should be small stainless steel nuts holding them.
If they are like these, it looks like you slide them off to the end of the rail. Another possibility is that you pinch that angled piece down with needle nose pliers.
8 Upper Basket Rack Wheel Small Wheels for Belling Dishwasher 25mm eBay
Feb 12, 2018 | Dishwashers
DFUD142 Dishwasher. Plastic clips holding Cutlery/Utensil Cradle sliding tray have broken. Looking for new clips or an alternative solution. Thanks
Hello, welcome to fixya
Here's what works for me, take the lower basket out and set it aside to give yourself a more work friendly environment. Now move the rack stops to the left if you haven't already and then the rack itself...example
and
Now you'll need to remove the bumpers at the back of the rack rail, example...
push down on the bumper as shown
and pull it down and out at the same time...it takes some force, you can use a small screwdriver.
Now you'll need to slide the rail all the way out as shown, but careful not to let the ball bearings fall into the sump area in the process.
I usually hold the broken piece in place while removing the rail...
...( they come in a kit at "repairclinic.com" under number 1394379 like shown here individual holders # 8058638-77 from the link I pasted below at allvikingparts )
http://www.allvikingparts.com/Guide_Rail_Ball_Holder_p/pd110003.htm
The trick now is to install the balls into the holders first
and the holders into the stationary part of the rail on the inside wall...
The inside wall rail will keep the holders in place as you slide the inside rail into place...this will usually require holding the holder with one hand while pushing the sliding rail back into place...
Once this is done, re-install the back rail bumpers followed by the rack and then finally the front rack stoppers and that should do it.
Hope that explain it for you or gives you an idea of how it needs to be done. Please take a moment to rate the assistance I provided here today favorable and a brief testimony is also appreciated when providing free solutions.
Thanks for visiting "fixya" today for your repair help and good luck. Let me know if you require further assistance.
Regards,
Macmarkus :)
P.S.
I should also mention you as I alluded to, be sure none of the old 8 ball bearings didn't fall down into either the drain pump or circulation/wash pump. This is something I've seen far too often on Asko dishwashers with the end result being a broken impeller in either pump...or both, yikes ! I use a telescopic magnet to fish around as it will be the only object made of metal...unless something else has fallen in the sump well area, it's good to check.
Sep 13, 2011 | Viking DFUD142 Built-in Dishwasher
Hello there, I have a Bosch Logixx dishwasher which I purchased just over 2 years ago. My upper dishwasher tray is not fitting properly into the hose pipe holes on the inside of the back wall of the...
Hello Deepak,
You can definitely fix this yourself, but I'm not entirely sure from your description which part is "dropping off". It may be a simple fix where something needs to be clipped back into place or you may need to replace something. Please can you take a look at the images below and identify which part you are having trouble with.
Below is the back of the upper spray arm which clips on to the upper rack. It has a grey plastic cover behind which is a large white plastic washer / gasket. The washer simply slots in to the back of the spray arm and the grey cover clips in over the top.
Your description suggests the grey plastic cover and/or the white washer are dropping off. If the grey plastic cover is missing, it may have fallen into the bottom of the washer under the lower rack, in which case you should be able to find it and clip it back on. If it's missing or wont clip back on, you will need to replace the upper spray arm as the cover and washer are not available separately.
This is the water delivery tube which clips to the back wall of the washing compartment. There is a metal clip which secures the tube to the wall. The open hole and one of the spigots slot in to the two holes in the back of the upper spray arm above. The spigot used depends on which height setting the upper rack is on.
Basically, everything simply clips together. If nothing is broken, you should be able to fix this at no cost by simply clipping the offending part back into place.
Hope this helps. If you need further assistance or help locating replacement parts, please let me know what needs to be replaced. Nearly all Bosch parts are available and in stock direct from Bosch.
Regards,
BElectric
Apr 13, 2011 | Bosch 24 in. SGS69L02 Logixx Built-in...
Nothing wrong with dishwasher just need top basket weel and clips to go on upper basket runner to stop from falling out, all our have broken
can try to find the correct wheel and clips if you can provide the make and model of the dishwasher
Mar 14, 2011 | Dishwashers
I have a MieleG2142. One of the racks is not sliding smoothly which I believe I have narrowed down to one of the wheels in the rail guides not turning. How are the rail guides removed?
Hi dear.Try this.Pull the top basket towards you.Check on the side (if you can) back of the basket two of the wheels on top row should be on rail guide & third one just under the rail guide to support the basket.It should be even on both side of basket to run smoothly.If not pull the basket all the way towards you & lift up the basket you are holding.Basket will be free to come out of rail guide.(Please check,are the rail guides running in & out freely without basket?If not there are two plastic wheel inside of the each rail guide one or two of it must be damaged.That needs to be replaced.Please also check side wheels on the basket,they sould be freely turning.If not needs to be replaced.) If that did not work out,try to put back the basket even way to rail guide the way took it off.Contact Miele for assitants.Thanks.Goodluck.
Aug 07, 2010 | Miele G2142 24 in Builtin Dishwasher
We need new wheels for our lower basket
Hi, Welcome to "Fixya" ! You can find these lower rack support roller & clip assemblies at "repairclinic.com" for around $10ea. Their part number is 1156665. They are really easy to change as you may already know, they snap in place. Hope that is the answer you where looking for, let me know. Thanks for visiting "fixya" with your inquiry. Please take a second and rate my answer accordingly or if more assistance is needed post a reply. Good luck. Macmarkus :)
May 04, 2010 | Asko D1776 Built-in Dishwasher
Hi- my dishwasher - single drawer fisher and paykel seems to be stuck on runners- will not open smoothly
this could be a broken wheel or something jamed inside the runner, theres a little plastic clip that is on the end of each runner remove the clips and pull the basket all the way out then check for broken wheels or something jaming it, or even a twisted runner. be carefull removing the clips as they can snap. Ps carefull of sharp edges too.
Jan 20, 2010 | Dishwashers
Top rack is not level. Glasses and cups roll forward
I assume that the bottom rack is level and the upper rack is not.
On the LG dishwashers, you can remove the upper rack by removing the little gray clip at the front of the rails. Each will fall off in your hands. You can then pull the basket out.
Place it on the floor and confirm that all wheels roll properly and all touch evenly. Resolve any problems on the rack via LG service parts.
Inspect the rails still inside the dishwasher, confirm that they are paralel and level.
Replace the upper basket carefully, making sure the wheels all slide into the rail evenly.
Please update me on what was done to finally resolve the problem.
Oct 12, 2008 | LG 24 in. LDF 7811 Stainless Steel...
Quinny buzz shopping basket
1. take off the front wheels by squeezing the two buttons on the aluminium tube just up from the wheels.
2. slide the metal clip up the groove in the tube.
3.use the two velcro straps around the tubes that support the rear wheels to hold up the rear of the basket.
4.re fit the front wheels and make sure the buttons snap into the holes in the tube
Aug 13, 2008 | Quinny Buzz Jogger
Dishwashers Logo
192 people viewed this question
Top Dishwashers Experts
