Question about Kyocera Office Equipment & Supplies
How to fix error c6950 on kyocera printer taskalfa 3051ci
  • 1 more comment
  • Terry
    Terry Apr 10, 2015
    Hi olawale , I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Service manual can be purchased for download in English:http://printcopy.info/?l=en&mod=free&cha... 3050ci&code=6950
  • Doug Sneddon
    Doug Sneddon May 02, 2015
    6950 Fuser IH PWB communication error No response is received in 30 ms since a command is sent to IHCPU. A checksum error is detected 10 times in succession
  • Doug Sneddon
    Confirm that the wiring connector is firmly connected and, if necessary, connect the connector all the way in. Power source PWB (YC9) and Feed PWB 1(YC4) Power source PWB (YC3) and Fuser IH PWB (YC1) 2. If the wiring is disconnected, shorted or grounded, replace the wiring. 3. If the +24V output is not given by the power source PWB (YC9), replace the power source PWB.
SOURCE: i also need a service
call service c3100
Posted on Nov 09, 2010
sodeep
  • 3267 Answers
SOURCE: installing a new kyocera TASKalfa 250ci and i got
C3100 Scanner carriage problem
• The home position is not correct when the power is turned on or copying the document placed on the contact glass.
Poor contact of the connector terminals.
Defective scanner home position switch.
Defective engine PCB.
Defective scanner motor.
This copier may need a service adjustment. The problem could be something as simple as a switch not being in home position. Please troubleshoot accordingly. Unplug device when troubleshooting.You should also troubleshoot it by looking to see if anything is blocking or stuck causing the carriage to not go into position.
Posted on Dec 22, 2010
shawn38
  • 200 Answers
SOURCE: my kyocera taskalfa 180 showing
C6400 is a fixing unit error.
To reset -
Try this, enter "10871087" from keypad, You should now be in maintenance mode.
Enter "163"press "Start / Print" key.
You should see a screen that says "Execute".
Cursor / highlight "Execute".
Press "Start / Print key.
The machine will turn off and should come back to ready. If not then you need to replace the fixing unit.
I hope this is helpful,
Shawn
Posted on Mar 02, 2011
SOURCE: Free service manual with code
Pls. send Free service manual with code for kyocera TASKalfa 180.
My email itechf2@gmail.com
Especially interisuet off hibernation.
Posted on Aug 24, 2011
SOURCE: reset all originals in DP
reseat orignals on DP.
Posted on Sep 05, 2011
Kyocera taskalfa 1800 call service c7900
Kyocera-Mita TASKalfa 1800 Error Code: 7900DescriptionDrum EEPROM error
No response is issued from the device in reading/writing for 5 ms or more and this problem is repeated five times successively.
CausesDR PWB. Main/Engine PWB.
http://printcopy.info/?l=en&mod=erc&brand=Kyocera-Mita&model=TASKalfa 1800&code=7900
Aug 08, 2016 | Kyocera Office Equipment & Supplies
My kyocera taskalfa 180 asking me to call service C6000. How can fix this error?
It is fuser error try resetting it by running mode 163, otherwise replace the fuser unit.
Feb 26, 2016 | Copystar Kyocera Taskalfa 181 Copier
Buying the Best Multifunction Heavy duty Printer
After looking at specs I would say the Kyocera TASkalfa TA-3051Ci but I never used nor worked on one
Jul 05, 2017 | Kyocera Office Equipment & Supplies
Code 2103
Developer motor MCY error
After developer motor MCY is
driven, the ready signal does
not turn to L within 5 s.
stabilized, the ready signal is
at the H level for 5 s continuously
Aug 08, 2014 | Kyocera Office Equipment & Supplies
Plz how to fix taskalfa 181 c6400 error
Fuser error. Ensure that no paper is jammed in the fuser unit.Switch the machine off/on.
If fault does not clear call technician.
Jul 26, 2013 | Copystar Kyocera Taskalfa 181 Copier
My kyocera taskalfa 180 shows an error.call service c6000.what should i do
Jun 30, 2012 | Kyocera TASKalfa 180 Copier
My kyocera taskalfa 5500ci showing error code C6600. please help
Please refer to the manual for error code listing and describe the error here can help
Aug 18, 2011 | Kyocera TASKalfa 180 Copier
My kyocera taskalfa 180 showing c6400 error please help.
To reset -
Shawn
Feb 25, 2011 | Kyocera TASKalfa 180 Copier
Aug 05, 2010 | Kyocera TASKalfa 180 Copier
1,522 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
