Question about Home
Zipper pull needs to be replaced. - Home
A zipper replacement for a tommy hilfiger back pack. zipper breaks open, after it is zipped close.
You can do a google search for "tailors" in your area, call and ask them if they would replace/repair a zipper on your back pack.
This FixnZip item may also work, without any sewing needed.
Zipper Repair Without Tools or Sewing FixnZip
Nov 16, 2016 | Tommy Hilfiger Watches
How do you replace a complete zipper and what do you need
Bring your garment to the sewing store. Find a replacement zipper like the one on your garment and make sure the replacement zipper is long enough (ask a clerk for assistance).
Then when you get it home, you will need to carefully remove the broken zipper by cutting the thread stitching that holds the zipper in place. Use a thread nipper or seam ripper but be careful to not cut the fabric. When you get the threads cut, you should be able to remove the broken zipper. Line up the replacement zipper in the open seam, pin in place and stitch.
Dec 06, 2015 | Sewing Machines
Zipper pull came off of zipper of suitcase
if it has a warranty , take it back to where you purchased it
if there is no warranty then get a key ring of good quality and pass tt through the hole in the zipper body for something to pull with
this page does not handle equipment of any kind ,just advice
Oct 24, 2015 | Cars & Trucks
My zipper on my jacket wont zip up.
Make sure it is properly hooked at the bottom. Get a cake of soap and rub it on all the zipper teeth. Carefully and slowly try to ease the zipper up. Also,make sure there is no material caught in it.
Oct 13, 2013 | Eureka Tundraline Tent
Zipper won't zip up its almost shut closed
If all the teeth of the length of the zipper are snapped together, it is closed and the pull piece is all the way at the ends of the two matching sections. It appears jammed at that point, right? If so you may need to use a little muscle to pull the end links one way and the zipper tab the other. A pair of plyers sure could help.
Jan 23, 2013 | Crafts & Hobbies
Kamik champlain zipper broken
You may be able to fix it.... if it is just separated work the zipper head all the way down then use a pair of pliers gently squeeze the zipper head, top to bottom. Then run the zipper.
If the zipper is missing teeth or is unsewn ... take it to a shoe repair place and get it fixed or replaced.
Dec 31, 2012 | Sewing Machines
Making clunking noise, lost a zipper pull
check the inside of the drum, if you don't locate it, you need to open the machine and check along the belt path, and idler pulley,, I don't think a zipper pull would cause a thump so it may have lodged in something else that would cause this sound
Jul 04, 2011 | Dryers
Camera bag zipper
Have you contacted Lowerpro? I asked them how to get a replacement sternum strap for my Fastpack and they only asked me two questions: male or female, and mailing address. I had the replacement part three days later.
Mar 10, 2010 | Sony Cyber-shot DSC-H10 Digital Camera
Broken zipper pull on snowboarding jacket
Put the zipper back on its tracks....use some staples (appr.3) and push them into where the old stopper was making as many tight circles as you can .use small needle-nose pliers. after this simply sew over top of the staples with strong thread or fishing line. It's a bit red necked ...but it works.
Aug 29, 2009 | Winter Sports
How to use a zipper foot please? I have lost instructions and have no idea which is the zipper foot or how to use it can you help please.
  1. Step 1 To prepare the fabric for a centered zipper application, use the standard presser foot to baste the opening of the fabric shut using 5/8 inch seam allowance. Press the seam allowance open. Place the zipper teeth side down on the seam allowance and pin the zipper to the seam allowance only.
  2. Step 2 Release the standard presser foot from your machine. There may be a button or lever behind the foot that you need to press. Put the standard foot in its holder or someplace where it won’t get lost.
  3. Step 3 Decide which side of the machine you want to attach the zipper foot to. Zipper feet are asymmetrical, with one side that’s wider than the other. You’ll want to put the narrow side toward the zipper teeth, and the wider side away from the zipper teeth.
  4. Step 4 Attach the zipper foot to the sewing machine. You may need to line up the bar on the zipper foot with the presser foot holder, then lower the presser foot by lowering the lever. Raise the presser foot and make sure the zipper foot is securely attached.
  5. Step 5 Place the prepared fabric with the pinned zipper in the sewing machine. Lower the needle into the zipper tape and the seam allowance only, then lower the zipper foot. Stitch the zipper tape to the seam allowance. To sew the other side of the zipper to the seam allowance, remove the zipper foot from the sewing machine and install it on the other side of the presser foot holder.
  6. Step 6 Topstitch the outside of the fabric to each side of the zipper tape, making sure that the zipper foot is on the appropriate side of the machine for each side. Remove the basting with a seam ripper.
Jun 19, 2009 | Janome Harmony 2039 Mechanical Sewing...
Home Logo
481 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
