I want to repair input channel pv14...how do i repair it
    Top Expert:
  • Televison & ... Master
  • 75,304 Answers
What repair you want to do?
Posted on Apr 10, 2015
I have been given a peavey pv8 mixer without the power supply, I have used a different power supply with the same voltage, my problem is when it's turned on the clip lights are glowing on all channels and...
Kinda hard to tell you exactly what the problem is. Your current power supply may not be able to give you the amperage you need even though the voltage is the same. You can get the correct power supply on Ebay.
Peavey 16 5 Volt II Power Supply 03013830 Mixer PV6 PV8 PV14 PV 6 8 14 16...
Dec 20, 2017 | Music
PV14 volume output shuts off and sometimes has intermitent static when adjusting slides
The slide-type volume controls are defective and will have to be replaced.
Jan 08, 2018 | Peavey Electronics Peavey PV14 Mixer
Slide pots for PV14 mixer
The pot needs to be cleaned. Get a spraty can of DeOxit 5. Spray it into the track and move the slider up and down a number of times. If that doesn't fix it, replace the slide pot.
Jul 30, 2012 | Peavey Electronics Peavey 00512140 PV 14...
Peavey pv14 right side stop working all of a sudden how do i fix it?
you could have blown the output on that side,, here are some other things you may need to know about that mixer http://bose.infopop.cc/eve/forums/a/tpc/f/8566055944/m/3281007943 I have seen the manual for this unit in the past and it really doesn't give many details of what all can be used for this mixer,, However that seems to be par for most unpowered mixers, I do know that if your using a mic with it,, its very choosy on which ones work , and those that have issues
Sep 11, 2011 | Peavey Electronics Peavey PV14 Mixer
Connect Qsc pair kw122 powered speakers and kw 181 powered sub to peavy pv14 mixer?
Two things... Use BALANCED LINES, either XLR or TRS... AND power the mixer from the same receptacle or power conditioner as the speakers and the sub.
Apr 30, 2011 | Peavey Electronics Peavey 00512140 PV 14...
How do you hook up a peavey pv14 usb mixer to non-powered speakers?
You'll need to provide an amplifier if there isn't one built into the speakers. All the mixer does is combine audio sources and provide a line-level output. A separate amplifier is needed to boost that to speaker level. If you're just using the mixer in a home setting and you have a stereo receiver or home theater system, you can feed the mixer's output to an auxiliary input on the receiver and use the speakers you have connected to that.
Feb 25, 2011 | Audio Players & Recorders
6 mnths old Alto L8 Mixing desk developed hiss on channel 1 only.
The slider or the amps for channel 1 may have a problem.
Sliders do wear out.
Try shorting channel 1 input and see if that affects the noise. A hissing noise is probably a bad preamp chip. That is shop work at a repair facility.
Aug 16, 2009 | Music
Eq on channel a doesn't work on 2 units
It could be an internal ground connection on the EQ that's broken ( maybe inside the connector) ..I repaired numerous peavey products and broken grounds are common.
Feb 11, 2009 | Peavey EQ215FX Home Equalizer
New to PA systems......
What brands are we talking about my friend?
Oct 09, 2007 | Audio Players & Recorders
Televison & Video Logo
Top Televison & Video Experts
