I want to repair input channel..how do i repair
    Top Expert:
  • 10,875 Answers
Get a flat screen tv,get rid of the crt,they use way too much electricity and are an elephant to repair,its gonna cost alot to repair and unless you are a tv tech,you cant do it
Posted on Apr 10, 2015
  • 3 more comments
  • john Apr 10, 2015
    Is not a tv...is a audio system....peavey power miixer....input channel not function
  • john Apr 10, 2015
    Hello...anybody?
  •  johnny rebel
    johnny rebel Apr 10, 2015
    well,when you post it here,,,Question about Standard (CRT) Televisions,,,how are we supposed to give an accurate answer?
  •  johnny rebel
    get your user manual here,http://www.manualslib.com/brand/peavey/m...
  • john Apr 10, 2015
    Sory...ok tq mr
    Top Expert:
  • Televison & ... Master
  • 75,289 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Yamaha AX700 amp distorts R channel - sound suddenly louder from R LS and distorted or metallic. Swapped LS L to R to eliminate
1) Check speaker polarity carefully
2) Ensure that speakers are securely connected.
3) Check your Balance control
4) Check your inputs (change inputs L/R)
If that does not alter or fix the problem your right channel may have developed an internal fault. Repair or have it repaired.
Have Fun
Sep 03, 2016 | Yamaha Audio Players & Recorders
Certain cameras are showing the same video.
First you need to isolate the problem. Step one - make sure the video from the cameras is correct - use a monitor and check each input separate. If the video is correct, use one camera and start from input one on the DVR and check all inputs - in other words plug your camera in input 1, check for video to make sure is correct and shows up in the right place, than go to input 2. This way you check your DVR cards. If the video shows up, but in the wrong place - check the settings on the DVR - you might be able to change the physical input in the viewer.Or you might have a bad DVR.......do a search for DVR Doctors in Google - in case you need repair.
Jan 27, 2012 | Avermedia AVerDiGi SA6832E RACK 32-Channel...
Kustom KSC 4080 Just bought - channel 1 is dead, for both 1/4-inch and XLR inputs. By the way, the nut securing the 1/4-inch jack is gone (any wild possibility that creates a grounding issue that cuts out...
The missing nut is not likely to kill the channel. You just bought this so exercise your warranty... unless it is used in which case you bought someone else's problem. Somebody probably blew out the channel by zapping it with high voltage that destroyed the input circuit of the channel. Often there are bypass capcitors right at the input which short out. If this is boiught used, take to a repair shop and if new, exercise your warranty. I suspect they removed the nut from the connector to mark the dead channel.
Aug 18, 2011 | Kustom KPM4080 PA Amplifier/Mixer
TV changes from input setting to channel 3 when turned on.
you need a service repair, on that ckt there's an IC function as memory IC replace that part and all your program well be stored. can found that ic most likely near switch botton area 4 or 8 pin IC.
Mar 03, 2010 | Apex Digital PF2025 20" TV
Mic channels 2 and 3 don't work no sound. mic channels 1 and 4 work okay as well as inputs 5-12. how can i fix this??
There is an internal f ailure and the unit will require servicing. To get by until you can get it fixed, you can get line transformers that will allow the mics to be used on the higher channels.
If you have inadvertently plugged a source into the :insert" jacks of these bad channels by mistake, that may have blown the input op-amps.
A lot of dis-assembly of the board must be done to get to the parts to repair.
Another possibility is if the sliders have gone bad... SAME prognosis for repair.
Dec 26, 2009 | Mackie 1202vlz3 12 Channel Mixer
6 mnths old Alto L8 Mixing desk developed hiss on channel 1 only.
The slider or the amps for channel 1 may have a problem.
Sliders do wear out.
Try shorting channel 1 input and see if that affects the noise. A hissing noise is probably a bad preamp chip. That is shop work at a repair facility.
Aug 16, 2009 | Music
Behringer EP2500 amplifier channel crackling noise
Got asilimar problemwit a behringer europower pmh 3000.
my
The Right channel began to crack up and drizzle now it seems completely dead.
Changed the cables both of input and seapkers , still the problem stays the same. Any suggestion before brigning for a month at the repair shop? And get out with a 200-400$ bill ?
Apr 28, 2009 | Behringer EUROPOWER EP2500 Amplifier
TV screen goes black but tv is on. But will stay on sometimes.
i have a 2000ish 32 inch trinitron Wega and i have had the EXACT same problems as you have, except mine was blacking out more and more frequently, but yes if u changes the channel or hit return onto the same channel you're watchin the picture wil come back, but not very long, about the longest it'll show a steady picture is 1/2 hr, but it's usualy going black within every 10-15 mins or so.
I took it to a Sony approved/recommened repair shop and aftet having a look i was told it would cost $200 cd including taxes to replace a 'vacuum tube' or something like that, i wish i could be more specific anout the part. I'm still considering whether or not to go through with the repair. I might just buy a working/used newer Tube Flascreen with HD for another couple hundred dollars. If there was a newer 2003+ 32 or 36" Sony that has a good track record I would love to hear suggestions. I don' trust flat panels, way too mny horror stories, and for every 1 i hear about there's probably 10-20 more.I'll give them another 5 years or so to get their acts together.
On the other had, if i do decide to get my 32" wega fixed i will post the results and the exact pt numbers of the pts used i the repair. Your problem is exactly the same as mine, to the letter. I'm a mechanic by trade, but i have a good feeling they're not going to give me correct pt # until i have payed them to fix it. Or else i'd order the part and install it myself.
Good Luck,
Aaron
Jan 24, 2009 | Sony Televison & Video
Vestax o5 pro mixer channel 2 not working
Doe you get sound in from the headphones? If so, then the issue might be the volume fader for that specific channel.
If not, then the issue might be the input connections or input pc board the connections are soldered on to.
The fader can be self replaced, although complete disassembly of your unit is required. Not a hard task, but there are alot of jumper cables, and you have to be careful when putting her back together.
If it's the latter, then I would suggest taking it to a service center for repair.
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
Dec 20, 2008 | Sony PS-LX250H Turntable
Input jack
Sounds like a problem with the tuner in your set. Probably not an economical repair. What you can do is if you have a VCR kicking around, connect it to one of the video inputs on the back of the set and run the cable into the VCR then set the TV for the appropriate video input and tune in the channels with the VCR.
Oh, and I kinda like the pun.
Oct 09, 2008 | RCA 32V420T 32" TV
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
