Question about Thermador Microwave Ovens
Thermador Microwave Door Sticky
Door is sticky
  • 2,544 Answers
By sticky do you mean as dirty or not working properly. If the door sticks squirt a little WD40 in all the working parts like hinges and latches and try that.
Posted on Apr 10, 2015
What keeps blowing my fuse on my Sharp R-1480 microwave oven ?
A short circuit diode will do that or shorted turns in the magnetron high voltage transformer, or the magnetron or a sticky/contaminated door switch.
Hope that helps.
Oct 24, 2010 | Sharp R-1480 Microwave Oven
My door latch pushes in but does not open the door.
But does not what? If the door doesn't open, chances are the seal has gotten sticky so try to apply a little outward pull... If it is sticky and opens, wipe down with moist cloth both the seal and the mating surface.
May 29, 2010 | Sharp R-230 Microwave Oven
Bosch microwave door sticking
I have the same issue on a later model, and the cam that releases the door is a poor design and only works if well lubricated.
You can lubricate the end of the engagement catches with some silicon oil or similar which worked for mine, although I did disassemble to understand the problem
Jan 10, 2010 | Bosch HLK4525GB Convection/Microwave Oven
GE® Spacemaker XL JVM1630
Sounds like a sticky or greasy door switch, or possibly a sticky relay on the control board.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
After you look into this, if you still need help, please write back with more details.
Jul 30, 2008 | GE JVM1630 Microwave Oven
I have thin baked on sticky residue in my microwave. How do I clean it without damaging it?
Wet a hand towel or multiple layers of paper towel and lay it over the sticky residue and turn the unit on high for 20 to 30 seconds to heat it. Then use a plastic spatula to scrape it off. The heating should loosen it up and the plastic spatula should be safe to scrape without damaging it.
Mar 16, 2008 | Microwave Ovens
Sharp R-204CW microwave,won't start at all
try to slam the door and try again. sometimes the micro switch at the door are getting sticky and would not latch correctly. if it work, open the housing and spray some wd-40 on the door latches.
Feb 17, 2008 | Microwave Ovens
Door stuck.
It might be in a bind , lift up on the door (small flat driver)
but it is likely the lubrication is sticky.
a hair dryer pointed at the latch area may loosen it if so.
stay away from the display area.
and try pushing in or pulling out just a bit on door when pressing button. be gentle.
Thats about the best you can do without opening case.
Jan 26, 2008 | Bosch HMT8625GB Microwave Oven
GE spacemaker Profile XL1800 vent fan will not shut off
It may be a bad door switch, a loose door switch mount, or a problem on the control panel, such as a sticky relay.
I would suspect a sticky relay first, but the door switches should be checked.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
If you need your control panel assembly (smart board) repaired, we do that for $39.95 nationwide.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Dec 02, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
104 people viewed this question
Top Thermador Microwave Ovens Experts
William Miller
William Miller
Chuck
Jerry Greenberg
Jerry Greenberg
Are you a Thermador Microwave Oven Expert? Answer questions, earn points and help others
