Question about Cell Phones
Keypad problem - Cell Phones
    Top Expert:
  • Cell Phones Master
  • 47,768 Answers
Buy a new one
Posted on Apr 10, 2015
Keypad prpblem
My Dear your phone keypad ic default so please change keypad ic
and keypad problem will solved
Sep 27, 2012 | Cell Phones
Bro i have samsung t509s.keypad doses nt work.i did not find keypad ic.sir can tell meh where is keypad ic?
Oct 20, 2011 | Samsung SGH-T509S Cellular Phone
My craftman 139.52606 opener does not have a learn button to set pin on keypad. I had keypad working at one time but since I changed the battery I can't rember how to reset the keypad.I also changed...
If the keypad is hardwired, do this:
To program the keypad, first unplug the garage door opener from the electrical outlet. Next, remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next, enter your desired four-digit PIN number into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
Sep 02, 2011 | Sears Craftsman LiftMaster Chamberlain...
The keypad function not respond when i push it, so i can't unlock the keypad, what can i do with my nokia 6120c?
Hi, what causes the keypad not to function is that, the keypad might be dirty or the keypad IC that controls the function of the keypad might be damaged.
You can unscrew the phone and clean up the keypad area and see if it will function.If it doesn't function,that means the keypad IC inside the phone is damaged and will need replacement.
Have a nice day.
Sep 13, 2010 | Nokia 6120 classic Cellular Phone
2000 Lincoln Towncar. Keypad on door will not unlock doors. Interior lights do come on. The last two keys pushed simultaneously will occasionally lock the doors. I am using the code printed on a sticker in...
The driver door module (DDM) is connected on the standard corporate protocol (SCP) communication network. The DDM controls many functions including power windows, power door locks and remote keyless entry. The DDM also communicates with the driver seat module (DSM) to control the power mirror and seat memory functions.
Do you know anything about automotive electronic control modules ?
The driver door module (DDM) receives inputs from the digital transmission range (DTR) sensor, ignition switch, seat switch, window/door lock switches, lighting control module (LCM), keyless entry keypad switch and remote transmitter. The DDM outputs consists of keyless entry keypad switch illumination, power door lock actuators, luggage compartment release solenoid, horn relay, and lighting control module (LCM).
Best thing to do would be to have a factory scan tool hooked up to check for DTC'S diagnostic trouble codes . That should be the first step if it's not programming the code.
  • The doors do not lock/unlock using the keyless entry keypad
  • Keypad.
  • Circuitry.
  • Driver door module (DDM).
  • GO to Pinpoint Test L .
PINPOINT TEST L: THE DOORS DO NOT LOCK/UNLOCK USING THE KEYLESS ENTRY KEYPAD CONDITIONS DETAILS/RESULTS/ACTIONS L1 RETRIEVE THE RECORDED RESULTS FROM BOTH CONTINUOUS AND ON DEMAND SELF TESTS Use the recorded DDM DTCs from the Continuous and On Demand self tests.
  • Are any DTCs recorded?
Yes For DTC B1525, GO to L3 .
For all other DDM DTCs, REFER to the DDM Diagnostic Trouble Code (DTC) Index.
No If the door locks are inoperative, GO to L2 .
If the keypad illumination does not operate, GO to L10 .
If the keypad illumination is on continuously, GO to L14 .
L2 CHECK THE DOOR LOCK OPERATION Check the door lock operation by depressing a door lock switch.
  • Do the door locks operate?
Yes GO to L3 .
No GO to Pinpoint Test E . L3 MONITOR THE DDM PID KEY_PAD
Scan tool
Monitor the DDM PID KEY_PAD.
  • Are any of the keyless entry keypad switch numbers present?
Yes GO to L4 .
No GO to L5 . L4 CHECK THE KEYLESS ENTRY KEYPAD SWITCH
Keyless Entry Keypad Switch C525
Yes If 1/2, REPAIR Circuit 78 (LB/YE). TEST the system for normal operation.
If 3/4, REPAIR Circuit 79 (LG/RD). TEST the system for normal operation.
If 5/6, REPAIR Circuit 121 (YE/BK). TEST the system for normal operation.
If 7/8, REPAIR Circuit 122 (YE). TEST the system for normal operation.
If 9/0, REPAIR Circuit 123 (RD). TEST the system for normal operation.
No INSTALL a new keyless entry keypad switch; for additional information, REFER to Keypad-Keyless Entry . L5 CHECK THE KEYLESS ENTRY KEYPAD INPUT WITH THE KEYLESS ENTRY KEYPAD SWITCH Monitor the DDM PID KEY_PAD, while depressing all the keyless entry keypad switches one at a time.
  • Are all the keyless entry keypad switches operating correctly?
Yes GO to L9 .
No GO to L6 . L6 CHECK CIRCUIT 797 (LG/VT) FOR VOLTAGE
Keyless Entry Keypad C525
Measure the voltage between keyless entry keypad C525-7, Circuit 797 (LG/VT), and ground; and between keyless entry keypad C525-8, Circuit 797 (LG/VT), and ground.
  • Are the voltages greater than 10 volts?
Yes GO to L7 .
No REPAIR Circuit 797 (LG/VT). TEST the system for normal operation. L7 CHECK THE KEYLESS ENTRY KEYPAD SWITCH INPUT While monitoring the DDM PID KEY_PAD, momentarily connect a fused (7.5A) jumper wire between positive battery post and keyless entry keypad switch C525 as follows:
    Keypad Button Keyless Keypad Switch C525 Circuit 1/2 Pin 3 78 (LB/YE) 3/4 Pin 4 79 (LG/RD) 5/6 Pin 5 121 (YE/BK) 7/8 Pin 6 122 (YE) 9/0 Pin 1 123 (RD)
  • Are all the keyless entry keypad switch inputs operating correctly?
Yes INSTALL a new keyless entry keypad switch; for additional information, REFER to Keypad-Keyless Entry .
No GO to L8 . L8 CHECK THE KEYLESS ENTRY KEYPAD SWITCH CIRCUITRY FOR AN OPEN
DDM
Measure the resistance between keyless entry keypad switch C525 and DDM as follows:
    Keyless Keypad Switch C525 DDM Circuit Pin 3 C521 Pin 8 78 (LB/YE) Pin 4 C521 Pin 13 79 (LG/RD) Pin 5 C521 Pin 16 121 (YE/BK) Pin 6 C520 Pin 24 122 (YE) Pin 1 C520 Pin 25 123 (RD)
  • Is the resistance less than 5 ohms?
Yes INSTALL a new DDM; for additional information, REFER to Section 419-10 . TEST the system for normal operation.
No REPAIR the circuit in question. TEST the system for normal operation. L9 CHECK THE KEYLESS ENTRY KEYPAD BACKLIGHT Depress a key on the keyless entry keypad.
  • Does the keypad illumination operate correctly?
Yes INSTALL a new DDM. For additional information, REFER to Section 419-10 . TEST the system for normal operation.
No If the keypad illumination does not operate, GO to L10 .
If the keypad illumination is on continuously, GO to L14 . L10 CHECK THE KEYPAD - DDM ACTIVE COMMAND KEYPAD BACKLIGHTING LIGHT ON AND OFF Trigger the DDM active command KEYPAD BACKLIGHTING LIGHT ON and OFF.
  • Does the keypad illumination turn off and on?
No GO to L11 . L11 CHECK DDM GROUND - JUMPER CIRCUIT 66 (LB) TO GROUND
DDM 522
Connect a fused (7.5A) jumper wire between DDM C522-4, circuit 66 (LB), and ground.
  • Does the keypad illuminate?
No GO to L12 . L12 CHECK CIRCUIT 51 (BK/W) FOR OPEN
Measure the voltage between keyless entry keypad C525-7, circuit 797 (LG/VT), and ground; and between keyless entry keypad C525-8, circuit 797 (LG/VT), and ground.
Yes GO to L13 .
No REPAIR circuit 797 (LG/VT). TEST the system for normal operation. L13 CHECK CIRCUIT 66 (LB) FOR OPEN Measure the resistance between keyless entry keypad C525-2, Circuit 66 (LB), and DDM C522-4, Circuit 66, (LB).
No REPAIR Circuit 66 (LB). TEST the system for normal operation. L14 CHECK THE KEYPAD ILLUMINATION - DDM DISCONNECTED
DDM C522
  • Does the keypad illumination turn off?
No GO to L15 . L15 CHECK KEYLESS ENTRY KEYPAD FOR SHORT TO GROUND
Yes GO to L16 .
No INSTALL a new keyless entry keypad switch. For additional information, REFER to Keypad-Keyless Entry . TEST the system for normal operation. L16 CHECK CIRCUIT 66 (LB) FOR SHORT TO GROUND Measure resistance between DDM C522-4, circuit 66 (LB), and ground.
  • Is resistance greater than 10,000 ohms?
Yes System OK. CLARIFY the concern with the customer.
No REPAIR circuit 66 (LB). TEST the system for normal operation.
Nov 03, 2017 | Lincoln Town Car Cars & Trucks
Keyboard letters 'm,j,k,l,u,i,o' permanantly locked for numerals. i have no idea how i switched this function on.
NumLock is on. Look for the Fn key in the lower left corner, and lookint in the top right, the NumLock key.
Mar 22, 2009 | HP 2133 Notebook PC
Lock 9 light is on
The numeric keypad functions like the numeric keypad on an external keyboard. Each key on the keypad has multiple functions. The keypad numbers and symbols are marked in blue on the right of the keypad keys. To type a number or symbol, hold down <Fn> and press the desired key.
  • To enable the keypad, press <Num Lk>. The keyboar2.jpg light indicates that the keypad is active.
  • To disable the keypad, press <Num Lk> again.
Mar 20, 2009 | Dell Latitude D410 Notebook
Ican"t type numbers can you please help
From Dell user manual:
The numeric keypad functions like the numeric keypad on an external keyboard. Each key on the keypad has multiple functions. The keypad numbers and symbols are marked in blue on the right of the keypad keys. To type a number or symbol, press <Fn> and the desired key after enabling the keypad.
Jan 13, 2009 | Dell Inspiron 6400 Notebook
2003 ford futura programming a new keypad
Adding and Removing remote Keypads to the Smartlock module
Up to four Keypads can be programmed and used with the Smartlock Remote
Central locking system.
If you have replaced the BEM, or new keypads are being added to the
system, you will need to train the keypad codes to the module.
# 1. The ignition switch should be in the Off position, with all the
doors shut and Unlocked.
# 2. Turn the ignition key to the ACCESSORY position and within 5
seconds, operates the rear demister switch exactly three times in quick
succession. (IE. Press the switch so the Demister light turns on, then
off, then back on again.)
# 3. After the 5 seconds is up, the door locks will change state, to
indicate that the BEM has entered keypad learn mode.
NOTE : All existing keypads at this point, have been erased from memory
# 4. Press either buttons on the keypad that is to be trained. The door
locks will change state twice, to indicate that the keypad has been
added to the BEM memory.
# 5. Follow step 4. for each keypad that is to be added to the BEM
memory. A maximum of 4 keypads can be added to the BEM memory.NOTE :
You must teach all remote keypads for the Smartlock module, before
proceeding.
# 6. When you have taught all the remote keypads, turn the ignition to
the Off position to leave the learn mode. The door locks will change
state to indicate a return to normal mode.
# 7. Check the function of both buttons on each keypad, to ensure that
the keypad has been trained.
Sep 15, 2008 | Ford Futura Cars & Trucks
How do I use Dell inspiron 1300 keypad?
If you are referring to the Number keypad.
Tap the "Num lock" key and you will see a light flashing.
Make sure the light is on when you stop.
Now try the keypad.
Mar 15, 2008 | Computers & Internet
Cell Phones Logo
29 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
