Question about Coleman Hot Water On Demand
Checking fuse again but can you tell me what size?
New battery plenty of gas works on cold but not heating
2 Suggested Answers
Terry Corrow
  • 10875 Answers
SOURCE: colemans hot water on demand.new battery ,plenty of gas .works on cold,but not on hot
If it is out of warranty there is a fuse inside them that is covered with a light rubber coating, it is the common glass style fuse. That may be causing your issue assuming the battery is ok. The batteries die regularly too especially if it hasnt been charged and is sitting around.
Posted on Apr 04, 2015
I need heat. Can you tell me what to check or replace to get heater to work again?
First of all, does your heater motor run ? If yes, are you getting cold air only ? If no, check fuses.
If you are getting only cold air, might have an actuator problem. This is a component that opens and closes the flow of coolant into your heater core which provides interior heat.
Nov 20, 2016 | Cars & Trucks
In the morning when 1st starting the car, the climate control does not work
If the climate control is on "auto" there is a delay before starting. For 15 minutes it is either freezing cold outside or needs repair. Depending where you live. Well anyway a way around the delay is to go to a manual setting and the system should start blowing right away.
Of course if it hasn't warmed up yet the air will be cold!!
Track the temperature gauge on the dash. As the temperature lift's off and approaches normal range heat should be coming from the vents,
New cars that are super efficient are very slow to heat up. The old gas gushers had plenty of heat to spare
So if you think it is cold where you live heck out the videos,
Cold start RAM 2500 at 35F 37C Fairbanks AK
Subaru Winter start up 44c
Jan 09, 2016 | Cars & Trucks
Colemans hot water on demand.new battery ,plenty of gas .works on cold,but not on hot
Apr 04, 2015 | Coleman Hot Water On Demand
Whirlpool duet sport
F1 code is a control failure but lets not panic yet as a tech I have seen plenty machines work with this code, the click is what is important that tells me the contact in the heat relay closed the unit is calling for heat there is an open thermal fuse you didn't provide a model # so I don't know if gas or electric the I could tell you the location of the safety fuses.
Apr 02, 2014 | Dryers
Van wont start .checked alternator. fuses and brand new battery still wont start. van started acting u when fuse to rad fan went out. engine light came on but since we live in cold area never heated up....
I think you're over your head here. Take it to a professional mechanic and let her sort it out. Sounds like your alternator isn't putting out the correct voltage.
Apr 06, 2017 | 2000 Dodge Grand Caravan
Moen single handle faucet
Is the hot water heater on & working? Is the dial that controls the heat itself turned up? Is there a connection problem to the electric or gas feed?
Jun 17, 2013 | Plumbing
The blower on the heater works but no heat comes out just cold air, already changed the themostart and plenty of antifreeze, I had the system flushed and had a new heater core and nw radiator put in and...
sounds like all key components have been replaced, so I think the blend door in your air box is not switching, if you can switch selector and get air at defrost, panel and floor, but all cold, the blend door connected to the heat / cool control is not actuating. DW Mylin
Dec 01, 2012 | 1998 Chevrolet Blazer
Hi,i have chescold rt50 fridge freezer,older model,colourbond brown colour,recently i have replaced the 240v element and the fridge work perfect again,at last camping trip i used on gas and work icy...
try disconnecting thermistor let run if cold replace thermistor if not bad board or cooling unit look for yellow stains on cooling unit or if you smell ammonia
Oct 13, 2017 | Dometic Refrigerators
1996 buick lasabre won't start in cold weather the battery is new--it cranks great--this happened once before late last year when it got realy cold. When it got into the 20's I was able to start the car. I...
buy a more expensive battery and check the fuel injectors to make sure they are not clogged from the heat that you pured into the tank. i do not recommend putting heat in a gas tank of any vehicle
Jan 05, 2010 | 1997 Buick LeSabre
Coleman Hot Water On Demand Logo
106 people viewed this question
Top Coleman Sport & Outdoor - Others Experts
David Payne
David Payne
Vernon Taylor
Thomas Perkins
Thomas Perkins
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
