- Your device and your PC are connected to you network - All the settings you entered are valid Firewall software is not interfering with your Install
Please resolve it asap
  • hoit
    hoit Apr 10, 2015
    is there anyone to help me from this error
    Top Expert:
  • Office Equip... Master
  • 45,291 Answers
TRY RESTARTING SYSTEM
Posted on Apr 10, 2015
I purchased a new EL 1850G EMachine. I have installed the software for a Belkin USB to connect to a Verizon wireless 5 Spot device. The software installs correctly, the device indicates the computer...
Hello Linda!
It sounds like a firewall is blocking the connection. I assume you`re using Windows, so go to Control Panel > Windows Firewall and disable it.The next step is, if your not using a proxy. Open up your browser, if you`re using Firefox go Tools>Options > Advanced> Settings... (Connection) and make sure the 'No proxy' option is checked, restart your browser. For Chrome go to Options>Under the Hood>Change proxy settings (Network) a new window will come up from here you select LAN settings(Note: This will change the proxy settings for your whole system) and select automatic if it`s on manual. Finally disable your antivirus software just for a short amount of time, and try to browse the web, just to make sure that it`s not interfering with the connection.
Mar 11, 2011 | E-Machines eMachines Desktop PC
"The installer is unable to
1. check your firewall. you might have 2 firewalls - one from windows and one from any other security software you might be running in the background.
2. if you have a router, make sure all the information you need is transferred to you (NAT forwarding). Check the port that the installer needs and ask the router to redirect it to your IP. you can find the rounter's address via start->run->cmd-> ipconfig->- default gateway.
Mar 05, 2011 | HP Laserjet M2727nf Multifunction Printer
Where do i enter my code #
Hello.
Not certain of your question, but first, set up a single PC to connect to the SG565 unit. Information is entered from that PC.
The initial steps are:
1 Connect your administrative PC to the SG unit:
- If you are setting up the SG560, SG565 or SG580, attach your
PC's network interface card directly any network port on switch A
(A1 - A4) using the supplied network cable.
2 Modify your PC's network settings to enable communication with the
SG unit. Click Start > (Settings >) Control Panel and double-click
Network Connections. Right-click Local Area Connection and
click Properties.
Note: If there is more than one existing network connection, select the
one corresponding to the NIC to which the SG unit is attached.
3 Select Internet Protocol (TCP/IP) and click Properties. The
Internet Protocol (TCP/IP) Properties dialog box is displayed.
4 Select Use the following IP address and enter:
- IP address: 192.168.0.100
- Subnet mask: 255.255.255.0
- Default gateway: 192.168.0.1
5 Select Use the following DNS server addresses and enter
Preferred DNS server: 192.168.0.1
6 Click OK and Close
Hope this helps.
Jan 20, 2011 | SG565 (SG0186US) Firewall
I cant conect to the intornet. im using cable can u help mi.
First thing is check and see if you have a valid IP address (Start, run, CMD enter) type (IPCONFIG /All ) this will give you the IP address information. If result of IP address is 0.0.0.0 or 169.254.x.x then you don't have connectivity with your broadband connection (Bad Cable, Bad NIC, Other communication issue etc)
If no valid IP address, the 1st thing is to power off system, power off any router you may be using and power off the broadband modem. Wait 3 minutes. Power on broadband modem, wait a minute to let it reset, power on Router (If you have one) wait a minute for it to reset, power on system and test your connection. If no change, try a different computer at that connection see if it can access the internet. If another system works, it is likely the Network Interface Card (NIC) which on a Dimension 2400 is part of the motherboard (Buy a PCI NIC for $10)
If you have a valid IP address, boot to the safe mode with networking (F8 at boot) then see if you can connect, if so then your issue is software based (Firewall, security software, possible virus) If it doesn't connect then there could be issue with your TCP/IP protocol settings. If you can't connect in safe mode with net, reboot to normal mode, then right-click your local area network connection and click REPAIR and see if that doesn't resolve. If no change try an anti-malware program like Malwarebytes
Oct 10, 2010 | Dell Dimension 2400 PC Desktop
HP 2727nf MFP software cannot be install through network
Are you installing SOFTWARE over network (i.e. from remote server) or you're installing your MFP over network? The latest means that you're installing software on your machine from CD/DVD/Image/etc and trying to connect to your MFP over network.
May 06, 2010 | HP Laserjet M2727nf Multifunction Printer
I cant install yahoomessenger its asking for firewall settings which i cant understand where to do that
A system designed to prevent unauthorized access to or from a private network. Firewalls can be implemented in both hardware and software, or a combination of both. Firewalls are frequently used to prevent unauthorized Internet users from accessing private networks connected to the Internet, especially intranets. All messages entering or leaving the intranet pass through the firewall, which examines each message and blocks those that do not meet the specified security criteria.
to disable firewall
  • Right-click on My Network Places
  • Select Properties
  • Double click Local Network Connection or Modem
  • Click Advanced
  • Uncheck Internet Connection Firewall
thats where u cud find the firewall settings on ur windows....
and also if ur using any antivirus... u wud be required to diable the firewall settings there as well
since i do not know what antivirus u might be using iam sending u link which has a list of procedures for disabling firewall in various antivirus softwares... identify ur product and do the procedure given under it
http://www.bleepingcomputer.com/forums/topic114351.html
Jul 19, 2009 | Yahoo Messenger
How to install a wireless care to the aspire x1700
If you are trying to install a wireless network card on an Aspire x1700?
1. Go to Wal-Mart or local computer store and purchase a USB Wireless Network Adapter.
2. Get home and install the cd, then plug the device in after installing the software first. You must install the CD with the software before you plug in the USB hardware in the rear USB slot.
3. Reboot
4. Your wireless software should start with the next boot, if not in the system tray (clock) You will see bars, such like on a cell phone, and right click on this to choose View Available Networks.
5. You can connect to nearby routers which are recognized as "access points". Then click connect, after choosing a network to join.
Mar 14, 2009 | Computers & Internet
Could u tel me any firewall software plz
try www.opendns.org
set up in 5 minutes, need some knowledge in dns.
You have to register and validate a link from the internet IP you want to filter.
This ip may be dynamically assigned.
Commercial : websense
Feb 18, 2009 | Cisco PIX 515E Firewall
I just installed my siemens se567 wireless router nd I want to set up a wireless network to another computer using a linksys wireless usb network card. What must I do?
Hi tbopper, install linksys software. Follow the instruction. Disable your anti virus / firewall software. (temporally). Make sure the PC with the wireless card is turned on.
Than open My Network connections & run windows Set up a home or small office network. Follow windows instructions.
That's it. When you restart your PC your Anti virus software should enable it's self. Check your firewall is also back on, if it's included in your anti virus it will re-inable it's self. Since your running a wireless make sure you enable security & password, other wise anyone with a wireless can tap into your wireless signal slowing your bandwith down.
To test your linksys is correct. Open internet explorer. In the address window type in 192.168.1.1 & press enter. Your settings should show up. Tech support is free with linksys.
Good Luck & Enjoy!
Mike
Mar 31, 2008 | Computers & Internet
jasbo
jasbo
