Question about Samsung Sme-2220n 8 Channel Lcd Dvr System, 8 Cameras
Mouse pointer is a continous hourglass after boot, never goes away. Is there a way to clear the bios or do a hard master reset? HELP
I removed my HDD from my PC and put it into another old pc. Then I replaced it again in the original. Now the mouse won't work
in this case,when you put your hdd in dell optiplex you must reinstall your windows,because the dell optiplex is a build up computer.
if you want more clearly detail you can contact me to my email
Dec 27, 2013 | Computers & Internet
Blinking hourglass on screen
External USB Memory sticks (Sandisk has a line of these with encryption built in, so it has a auto-run partition on it to run the program that allows decryption). It seems like the auto-run partition or the USB volume that can't be mounted because it's not unlocked yet, causes the system resource issues with the blinking hour glass attached to the mouse pointer.
Just unplug all your external USB memory sticks and see if the problem goes away.
Dec 27, 2009 | Craig Audio Players & Recorders
Mouse pointer is fixed
Improper boot media means it's not seeing your hard drive. Check hard drive ribbons and power connectors. Your hard drive might have failed if the ribbons and power connectors are installed properly.
Oct 01, 2009 | Intel D845GEBV2 Motherboard
My mouse disappeared on my hp 9925 screen i did a hard reset now the whole screen is black
If you power on and see the HP bios boot screen, the HP symbol, then the screen goes black, try pushing the F10 or F12 keys when you power on and select boot in safe mode. If the computer boots and you can see everything, power down and see if it will boot correctly to regular Windows. If you can not boot to a screen that you can see in safe mode you have a much larger problem and need to get a technician to look at the laptop to find the problem.
Sep 08, 2009 | Computers & Internet
Msi 848p neo v motherboard problems.
Once you reset the bios everything goes to manufactures default settings. You will need to make some changes within the bios. You'll need the help of the manual. See page 3-20.
If your operating system is loaded on to the ATA IDE drive make sure you set bios settings as follows:
Connect the ATA IDE to MB primary master IDE port.
Connect the ATA SATA drive to the MB's first SATA port.
ATA Configuration
Set as, [P-ATA+S-ATA]
S-ATA Keep [Enabled] Set to [Yes] This enables the SATA controller.
P-ATA Keep [Enabled] Set to [Yes] This enables the IDE controller.
On-chip IDE configuration, "ATA Configuration = [P-ATA+S-ATA]".
Next go to Boot menu. Make sure the ATA IDE drive is chosen as boot device three.
First boot device [Floppy] (If you have a floppy disk drive connected.)
Second boot device would be [DVD/CD-ROM] drive. This should be connected to the MB's secondary IDE port & the DVD/CD-ROM drives Master/Slave jumper, set to Master.
Third boot device [ATA IDE drive]
If your boot drive is the SATA drive than set: third boot device to the SATA drive.
(Hard disk drive with operating system loaded on it).
Save your changes & exit the bios.
Keep in mind all ATA SATA drives are seen as Master drives. SATA drives are seen by the SATA controller & in order by their connection to the SATA port number.
Save & exit the bios. The system will auto restart. Windows should start.
Jul 25, 2009 | MSI Computers & Internet
I have an acer netbook and occasionally i get a weird symbol when i move my cursor. it's almost like a bullseye. it pauses my cursor until it goes away and then in can continue. what is this?
This is a custom cursor that has been setup by either:
A program on your computer
A custom cursor program like free cursors or something.
Check you computer for programs like "smiley cursors" or check the windows control panel and open Mouse settings to see if you have any custom pointers.
It is possible that.. instead of an hourglass.. somebody, or a program has set a custom pointer for your mouse.
The pointer changes to an hourglass in any windows setup by default when it wants you to wait for something that is happening in the background to finish processing.
Check for spyware and viruses as well.. customer cursor websites are great at getting people to install them and you get infected sometimes.
www.techvisitor.com
Oct 31, 2008 | Computers & Internet
Dell Latitude D800- Keyboard and mouse stop working when undocked.
First update any drivers for your dell.
www.support.dell.com
Is the dock a dell dock, or a universal Dock?
the drivers may need updating.
Some times when you plug a dock in, and turn it on, they will load them into the drivers and when you unplug it, it gets confused and when you boot it up it has to re-install the original drivers and does this while its booting.
This happens alot with the GX620 desktops. If you pull a USB keyboard out while its off and plug it back into a different USB port and tun it on. It wont work right away.
We end up having to let it sit at the login screen for a while till it reloads the drivers to the new USB port.
You will know if yours is doing this as the Hard drive light will be flickering and running.
Try booting it up and letting it load windows and waiting a few minutes.
Sep 20, 2008 | Dell Latitude D800 Notebook
Pointer not moving. Tried everthing nothing works. New mouse, PS2 , light mouse , update drivers , unstalled and install mouse and usb ports . Its look good in device manager, everything looks goos and...
if you know how to boot up the computer and get into the bios than click on bios set up feature look for the ps2 and mouse and ensure it is set to auto and also there is a feature for turning on and off the usb ports in bios too so check to see that this is enabled then reboot this should help please let me know ok good luck
v/r mike
Aug 05, 2008 | Microsoft Windows XP Professional With...
Lag Booting
This is a shot in the dark, bare with me. Disconnect everything from the back of pc except the video, mouse & keyboard. Enter your bios. Still have lag? Reset the bios by clearing the cmos jumper pg. 9 in your manual & remove the battery & check it for 3v if you can. If the lag went away by disconnecting the other devices than re-connect one device at a time with a reboot inbetween. When the lag returns you will know which device is not right. Everything applies when doing this kind of search. If you have two dimms remove one. Check for lag. Than swap memory/check. When you boot to the bios it involves the cpu, motherboard, video, memory & power supply. Your hard drive is also an issue but only at booting to OS. Did the pc encounter a unexpected shut down? Did you replace a device like a mouse or a keyboard? Here it the link for your board. ESC shows very little in regards to FAQ's. I hope something above helps you find a answer! http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?detailid=674&DetailName=Bios&MenuID=1&LanID=9
Please vote...
Jan 30, 2008 | EliteGroup P4M800PRO-M2 (V2.0) Motherboard
Samsung Sme-2220n 8 Channel Lcd Dvr System, 8 Cameras Logo
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
