Question about Life Science Medical
Explain the importance for the kidneys to filter the ****** supply
Using the word sweat glands
Kidney tonic from fusion health
discuss this with your doctor
best medicine for kidneys is plenty of fresh clean water
Kidneys are organic filters of the blood and plenty of water keeps the filters operating properly
Apr 25, 2017 | Fusion Health & Beauty
What caueses low potasium
Hi Susan,
Here are some common causes for low potassium:
  • Antibiotics.
  • Diarrhea or vomiting.
  • Using too much laxative, which can cause diarrhea.
  • Chronic kidney disease.
  • Diuretic medicines (water pills), used to treat heart failure and high blood pressure.
  • Eating disorders (such as bulimia)
  • Low magnesium level.
  • Sweating.
Jan 05, 2017 | Cars & Trucks
What are symtoms for low potassium and what caueses it
Hi Susan,
Common symptoms for low potassium are as follows:
  • Weakness.
  • Fatigue.
  • Muscle cramps.
  • Constipation.
Common causes of low potassium:
  • Antibiotics.
  • Sweating.
Low blood sodium symptons
Please go to this link on the Mayo clinic website. They have good advice. I hope you are feeling better soon:
http://www.mayoclinic.org/diseases-conditions/hyponatremia/basics/causes/con-20031445
Here is part of the information they have:
Sodium plays a key role in your body. It helps maintain normal blood pressure, supports the work of your nerves and muscles, and regulates your body's fluid balance.
A normal sodium level is between 135 and 145 milliequivalents per liter (mEq/L) of sodium. Hyponatremia occurs when the sodium in your blood falls below 135 mEq/L.
Many possible conditions and lifestyle factors can lead to hyponatremia, including:
  • Certain medications. Some medications, such as some water pills (diuretics), antidepressants and pain medications, can cause you to go to the bathroom and empty your bladder or perspire more than normal.
  • Heart, kidney and liver problems. Congestive heart failure and certain diseases affecting the kidneys or liver can cause fluids to accumulate in your body, which dilutes the sodium in your body, lowering the overall level.
  • Syndrome of inappropriate anti-diuretic hormone (SIADH).In this condition, high levels of the anti-diuretic hormone (ADH) are produced, causing your body to retain water instead of excreting it normally.
  • Chronic, severe vomiting or diarrhea. This causes your body to lose fluids and electrolytes, such as sodium.
  • Drinking too much water. Because you lose sodium through sweat, drinking too much water during endurance activities, such as marathons and triathlons, can dilute the sodium content of your blood. Drinking too much water at other times can also cause low sodium.
  • Dehydration. Taking in too little fluid can also be a problem. If you get dehydrated, your body loses fluids and electrolytes.
  • Hormonal changes. Adrenal gland insufficiency (Addison's disease) affects your adrenal glands' ability to produce hormones that help maintain your body's balance of sodium, potassium and water. Low levels of thyroid hormone also can cause a low blood-sodium level.
  • The recreational **** *******. This amphetamine increases the risk of severe and even fatal cases of hyponatremia.
Apr 28, 2016 | The Health & Beauty
What medication do you use for kidney failure ?
These medicines include:
  • Erythropoietin (rhEPO) therapy and iron replacement therapy (iron pills or intravenous iron) for anemia.
  • Medicines for electrolyte imbalances.
  • Diuretics to treat fluid buildup caused by chronic kidney disease.
  • ACE inhibitors and ARBs.
Kidney transplant patients may have new way to fight off rejection
Good Luck
Jan 29, 2015 | Rite Aid Allergy Medication Coated...
I HAVE SHRINKING KIDNEY AND KIDNEY STONES WHAT ARE THE SYMPTOMS
Kidneys usually remain the same size over your life span.
Unless you have an MRI to measure the kidney size, you can't evaluate the size, and additionally, there must be older evaluations of the kidney in question to equate to changes in tissue size. It could be, one kidney is smaller than the other, but that is not a problem as usual. Stones are a problem. Usually the Diet is the source. Calcium in excess can cause stones, over acidity is a factor, food and drinking water another. Drink a lot of Filtered Water each day. Filtration of the body fluids is done within the Kidneys and more activity is important. You must FLUSH the Kidneys daily and although you may end up piddling a lot more, you save the kidneys and they function better. Less or No Stones over a period of time.
Jan 04, 2015 | Health & Beauty
No Hot Water
Hard water contains a lot of minerals and depending on how hard the water is also depends on how often you must replace the filters. A much better alternative is to have a water softener installed before your hot water heater and any other sorce of domestic water supplying your home. I have one and it works great. Just be advised that you will need to replace the salt crystals every couple of months depending on the time intervals you set the timer to. If you find that the water still remains soft after two months and your filters are not to badly clogged then you may try adding salt every three or four months and see if that solves your problem. You also have to remember that your also using the water for drinking cooking and bathing so softening your water supply is very important especially if you or anyone in your household ever had any kidney stones or kidney problems.
Good luck,
Marty
May 08, 2014 | Navien CH-240-ASME-LP, Combi Condensing...
How do antiperspirants work?
The perspiration is created by the sweat glands under pressure. Antiperspirant is designed to stop perspiration by combining with the moisture in order to block the release of more sweat.
Jan 10, 2013 | Health & Beauty
Medical Logo
236 people viewed this question
Top Life Science Medical Experts
Electro Med Services...
Tom Chichester
ka4iup
ka4iup
Are you a Life Science Medical Expert? Answer questions, earn points and help others
