Question about Fuses/Circuit Breakers/Relays Barry Grant Fuel Pump Relay & Wiring Harness - 30 Amp
Cavalierlocation of fuel pump fuses an relays on a 1994 cavalier
    Top Expert:
  • 1,144 Answers
Posted on Apr 10, 2015
Where is the inertia reset on a 04 cavalier
What seams to be the problem Jessica ? No fuel ? This vehicle has no inertia fuel cut off switch ! I 'm looking at a wiring diagram for this vehicle, there is a fuel pump relay in the under hood fuse / relay box . In the instrument fuse box is a fuse marked F/P-INJ. fuse 15amp.this supply's power to the fuel pump through the fuel pump relay. If you knew how to do it you check for power at the fuel pump relay ! GM Fuel Pump Relay Testing
Feb 28, 2015 | 2004 Chevrolet Cavalier
Fuse box diagram for a 1994 Chevy Cavalier 2.2 litter
The Fuel Pump Relay is located: Under hood, passenger side, rear side of strut tower, mounted on fenderwell
Sep 12, 2012 | 1994 Chevrolet Cavalier
Location of fuel pump relay 1994 toyota corolla
The fuel pump relay is located in the fuse box drivers side of fuse box
Jan 26, 2012 | 1994 Toyota Corolla
Where is the fuel pump relay in my 94 cavilier
under the hood in the fuse box.goodluck
Mar 08, 2011 | 1994 Chevrolet Cavalier
1991 chevy cavalier- stopped running going down road. Replaced fuel pump and fuel pump relay-ran for two weeks and the when making a stop,cut off again and won't start and is blowing the fuel pump fuse...
Sounds like a short between the fuse panel and the fuel pump relay. This can be from the fuel pump relay itself through an exposed bit of wire, or even a defective relay which seems to happen more than most times. Check the wiring to the relay and wrap or tape anything where bare wire may be exposed. Disconnect relay and try a new fuse. IF the fuse doesn't blow, then the problem source is the relay itself that is defective.
Hope this helps!
Chip
May 31, 2010 | 1991 Chevrolet Cavalier
Where is the fuel relay switch on a 2002 chevrolet cavalier
The fuel pump relay is located in the fuse junction block,under the hood
on the left fender. There is also a fuel pump+injectors fuse, in the fuse
block behind the left side of the dash. It should be marked f/p-inj.
Hope this helps.
May 20, 2010 | 2002 Chevrolet Cavalier Coupe
Need to find the fuel pump relay and its wiring
fuel pump relay is under the hood in the under hood electrical centre with the fuses
Nov 24, 2009 | 1994 Chevrolet Cavalier
1994 toyota fuel pump relay
Fuel pump relay is in the engine compartment left side fuse block
Jun 30, 2009 | 1991 Toyota Camry
My cavaliers fuel pump wont kick in when the key is turned on
you should be able to find a fuse in the line that triggers the relay
Jun 03, 2009 | 1997 Chevrolet Cavalier
Fuses/Circuit Breakers/Relays Barry Grant Fuel Pump Relay & Wiring Harness - 30 Amp Logo
990 people viewed this question
Top Fuses/Circuit Breakers/Relays Measuring Tools & Sensors Experts
Thomas Perkins
Thomas Perkins
D. E. Hev
Ngoro
Ngoro
Are you a Fuses/Circuit Breakers/Relays Measuring Tool and Sensor Expert? Answer questions, earn points and help others
