Question about Toshiba E-Studio 166 Digital Copier
Is its problem of upper fusar missprint and ink of the papper not dried
My Epson workforce printer prints pictures and the all blue
Hello, Clean the printer end of the cartridge with a damp papper towel. Dabbing them, until ink starts to flow and then wipe dry. If this doesn't work the cartridge is bad.
May 31, 2014 | HP DeskJet 656c InkJet Printer
How to clean air filter in Bajaj Platina 2007 model
If it is papper filter just blow with compressed air if it is a sponge wash with petrol and keep it dry after its dry spill little drops 10 to 15 of oil and fix it.
Apr 11, 2011 | 2007 Bajaj Platina
I replaced by color ink cartridge and it will only print in yellow
remove the cartridge and clean the nosil of the cartridge carefully, you check the nosil by taking an image on tisue paper before putting in to printer. On papper all three color will apper, red ,blue and yellow
Apr 08, 2011 | Kodak EASYSHARE 5100 All-In-One Printer
When printing, the top half of page prints normal... bottom half of page very faint...
Your ink cartridge has about 9 very small nozzles that spray ink to complete a letter the upper nozzles complete the upper half and the lower half is done by the lower nozzles. The lower nozzles are stopped or clogged up by dried up ink or the control resisters in the firing circuit are burned out. some times you can unclog the nozzles by soaking the lower part of the cartridge in hot water for a half hour and drying it well ,replace it in the carrier and try it again. However you will lose a lot of ink and it may be more prudent to replace the cartridge.
Dec 02, 2010 | HP inkjet 2280 Printer
Got hp psc 1210 all in one at yard sale don't know how to put papper in, how do you put papper in?
Please refer to the illustrated picture below:
Put the blank paper in/through the (labelled IN) Lower Tray/passage, and the printed paper will come out from the Upper Passage (Labelled OUT).
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Aug 23, 2010 | HP PSC 1210 All-In-One InkJet Printer
Canon Mx320 printing error 5200.How do I fix it?
Just remove the ink cartridge from the printer and clean the surface contact using a cotton moistened dipped in an alcohol .
Return back the cartridge and try to print again.
Try also to Press and Hold the STOP/RESET button until printer restart. Release the button when to completely initialize the printer
Aug 20, 2010 | Canon PIXMA MP130 All-In-One InkJet...
My Epson R265 is sending a message saying that it
If the lights are flashing alternately and slowly (with the power light off), then the waste ink absorbers are full.
The pads are near the bottom of the printer and can either be replaced (call the service department for the parts) or rinsed clean under running water. The hard part is usually extracting them (you need to disassemble the printer most of the time). Then (if reusing the pads, wait until they are dry) reinstall them and reset the waste ink counter. The reset requires a program such as the one available here: http://inkjetprinterhelp.us/epsonSSC.html . Do not run this utility until the pads are replaced, the ink will smear everywhere. Epson used to have a link for their own reset tool but I do not see it for this printer.
However, the printer is designed that under normally usage, the waste ink absorber will be full at the expected end of life of the printer. Thus additional failures may be coming.
I hope this helps.
May 04, 2010 | Epson Stylus R265 InkJet Photo Printer
It is printing blue on the photos all over
your ink cartridges are empty or these are dried up if dried cleane then with clean cammond and then try
you can also clean them with wet tissue papper to oppen there nozzels manualy.
Jun 14, 2008 | Canon Office Equipment & Supplies
Toshiba E-Studio 166 Digital Copier Logo
23 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
