Question about Furuno Boating
Furuno 1731 radar i purchased, the person i got it from extracted the pins from the plugs on the signal cables 3 plugs. all pins are still on the wires i just need the pinout to reassemble the plugs
  • Furuno Master
  • 696 Answers
Your only option here would be to contact Furuno support and talk to a tech from the people that actually designed and built the unit.
Furuno support can be contacted at:
http://www.furunousa.com/Support/FAQ.aspx
Should anyone require the owner's manual it is accessible at the link below.
Hope this helps.
-Steve
http://www.furunousa.com/ProductDocuments/1731%20OME.pdf
Posted on Apr 13, 2015
Radar 1731 shuts down when tx is hit
There are a couple of things that could cause the radar to power off when going into the transmit mode.
The first thing to eliminate is input power. When in the standby mode the radar draws less current than in the tx mode so if you have low voltage for whatever reason, that could cause a shut down. Check all connections and measure the voltage to the unit while it is on.
A problem with the antenna motor or gear box could also be the problem. The antenna doesn't rotate unit the unit is switched to the tx mode. You would need to remove the dome cover (with unit off) and verify that the array will turn freely by hand. Typically, a bad motor will not cause a shut down but a physical obstruction could.
Focus on the power issue because that's the most common problem. Be aware that you need to measure the voltage as close to the radar display as possible and watch the voltage as you switch the radar from standby to transmit for a quick dip in voltage.
Jun 25, 2014 | Furuno Navnet 1834C/NT vx2 Radar C Map Nt
Furuno radar
Your antenna seems to be mis alighned. Its ZERO point must be readjusted.
Aug 30, 2008 | Furuno Navnet 1834C/NT vx2 Radar C Map Nt
Ca I buy a 5 metre extension cable as the 10 metre cable that came with the 1623 is too short?
Quite sorry but Furuno does not carry "extension" cables for radar antenna signal cables. If the original cable is too short, you would need to obtain a 15M whole cable, furuno part number 001-122-870-10. Or the 20M whole cable part number 000-144-565. You might be able to find a technician willing to custom manufacture an extension for you but I emphasize the word might.
Regards,
John
Feb 18, 2012 | Furuno 1623 Radar 16nm Range
I have a Furuno Radome RSB0094-075 with a Navnet RDP 139 10.4" What I dont have is the antenna cable to connect the two units. What cable should i be ordering for this?? Thanks, Mike
That is a Furuno 1823C Radar -000-138-972 (10 meter Radar cable) $150.00 msrp from Furuno. Give their Camas Office a call or your nearest dealership. The Furuno number in Camas, Wa 888-834-9330
Nov 06, 2010 | Furuno NavNet vx2 1920C GPS Receiver
I have a Furuno 1622 radar. It only shows a ring
I don't beleive this is goning to fix your problem. Open the dome and visually check that it is spinning. There is a maintenance menu though. To open the maintenance menu;
1. Turn the radar on.
2. Wait until the initial screen appears, then press and hold UP and DOWN keys together.
3. In about 10 seconds, the maintenance menu as shown below will appear.
4. Press MENU key to close the menu.
Feb 22, 2010 | Furuno 1715 LCD Radar System GPS Receiver
My radar displays all contacts reverse. How do I get the display reversed? model #1731
I agree with Nico-Fixus, the heading alignment is one of the things to be checked. Unless this is a new installation it is unlikely that the Radome (antenna) got removed and reinstalled facing the wrong way. So antenna orientation would not be a concern.
I have seen units that for some reason the wrong Radome was selected in the configuration of the Navnet display.
Read the model number on the Antenna, then check that correct antenna type in loaded in your display.
Oct 22, 2009 | Furuno Navnet 1732 GPS Receiver
Hi, Furuno 1731 radar - no sweep/echo seen on screen. Scanner is rotating and other display is normal.
Go to longest range and full Gain min Rain and Sea Clutter
Do you have speckle? Yes = Receive OK, Wiring OK,No transmit (magnetron or modulator) No = Most likely a broken wire
There is a very tiny coax (shielded wire) that is know to lose its' center conductor, which is very delicate
Oct 18, 2009 | Furuno 1623 Radar 16nm Range
Hi, I have a Radar Screen. Furuno 1942 MK2 . What Radar Dome can i plug this into. I have a Furuno 1720 Dome
A 1942 is a 6 kw radar a 1720 is either a 1.5 or 2.2 kw dome. The two will not work together. Besides the cabling is different. Also the radar cable on a 1942 is round where as the 1720 is square. The 1942 display should work fine on a 1943 navnet radar.
Sep 24, 2009 | Furuno 1942 Mk2 Radar
Furuno Radar 1623 and 1715
Hello.
According to the operating manuals of the two radars (found on Furuno's Website (www.furunousa.com), they do use the same antenna cable.
Hope this was helpful.
Dec 03, 2008 | Furuno Fr8062 12.1 Color Lcd 6kw 15 Meter...
Boating Logo
260 people viewed this question
Top Furuno Boating Experts
Daniel Dollive
Daniel Dollive
David Burbee
David Burbee
Colin Stickland
Colin Stickland
Are you a Furuno Boating Expert? Answer questions, earn points and help others
