Question about Casio G-Shock Chrono Quartz Stainless Steel GS-1001D-1ADR
How do you adjust time 1 hour forward? - Casio G-Shock Chrono Quartz Stainless Steel GS-1001D-1ADR
Can not set the date and day
I assume you are talking about a day-date Timex. Timex watches do have a quickset feature meaning the day and date can be set without having to simply advance the time by 24 hours to adjust the Day-Date. Not all watches have a quickset, but I'm sure your Timex does. Unscrew the crown from the stem by turning it counter clockwise until it is free from the threads. At this point pull the crown all the way out so that you can adjust the time. That's position 2 the quickset is in position 1 but the tricky part is getting the crown in the proper position to engage the quickset. Push the crown in very slowly while turning once you see the day or date window advance stop turning you are in position 1. Day and date can be set in this position by turning the crown in either direction. If your watch does not have a quickset or you cannot figure out how to engage it you must set the date by advancing the time forward 24 hours. This will make the date window advance by one day. Once the right date is displayed turn the time backwards 24 hours and this will cause the day window to move without affecting the date window. And that's all there is to it.
Dec 31, 2013 | Watches
My radio controlled watch is exactly half an hour fast according to the hands, but the internal clock appears to be correct. This happened when I tried to adjust the watch to Canadian time
If I understood correctly this watch have a analog watch display ..and it is half an hour forward..but when you set timing or the alarm it behave normal ..and so the internal one is correct ..but just do not display the correct time on the analog one ...If it do not have any means to correct manually the analog watch ..I advice to try to remove all power and stop the indicators at the exact time ...(a sharp hour...) and power it back after the exact time it is forwarded ....This way the analog clock will be stopped..and the internal one will go on and will adjust at the spot by the radio time ..and you will have both timers in correct display ...If it does have buttons or so in the back ..try to correct them by hand ..
Jul 12, 2011 | Watches
How to set time on timex 1440 sports watch
Welcome to FixYa!
Here's your request.
TIME AND DATE 1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash. 2. Press ADJUST to set SECONDS to zero. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change. 5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM. 6. Press MODE when done. 7. To display DATE from Time display , press START/STOP. 8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE. 9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME 1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash. 2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change.. Press MODE when done. 5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH 1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes. 2. With time displayed, press MODE to select Chrono Mode. 3. Press START/STOP to start. 4. Press ADJUST to view lap time. Press again to sesume lap timing. 5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero. 6. Repeat for successive laps.
Thank you for using FixYa! Have a great day.
Jas247
May 06, 2011 | Timex Watches
Cannot set time @ date for Ohsen watch...AD0721...thanks
(A=LIGHT,B=MODE,C=START,D=RESET)
1.How to use the luminescence Any time indication,Press A the Luminescence will last for 3 seconds.
2.How to view date? Standar time indication, press C "month/ date" indication.
3.How to switch 12/24 hour systems In the normal mode, press B twice and press D twice ,then hold C until 24 hour system is actuated, then press B for recovering.
4.How to check alarm ring and alarm time? Standard time indication,press D alarm time indication.
5.How to set alarm time? Standard time indication,Press B twice. The hour area flickers,press C to set the hour. After setting hour ,press D,the minute area flickers, press C to set the minute. Last press B for recovering.
6.How to set alarm ring? In standard time indication mode ,Hold D then Press C this will toggle alarm symbol on & Off.
7.How to set Hourly Chime? In standard time indicationmode, Hold D then Press B DAY OF WEEK area toggle on and off.
8.How to use stopwatch(1/100 seconds) Press B,then Oress C for 1 timing; Press D for multiple timings. Press D once more to continue operation after multiple timing. Press D for 1 timing; press C once and press Dtwice for multiple timing. (1)Max range of the stopwatch is 23 hours 59 minutes 59 seconds. (2)When timing within 30 minutes, the watch indicates: minute/second/1/100 second (3)When timing beyond 30 minutes, the watch indicates:hour/minute/second
9.How to adjust time, date,day of week (1)Standard time indication,press B twice ,the second area flickers, pressC to adjust second. (2)Then press D the Minute area flickers,Press C to adjust minute. (3)Press D the hour flickers, press C to adjust hour. (4)Press D the Date flickers, press C to adjust date. (5)Press D the month area flickers, press C for adjustment. (6)Press D the Day of Week area flickers, press C for adjustment. Then press B for recovering.
Nov 30, 2010 | Watches
Changing from 24 hr system to 12 hr system
  • Press "MODE" (lower left hand button) three times to get to the screen where the numbers are blinking, indicating that you can adjust the time
  • Make note of the hour if you don't have another clock handy
  • Press "LAP/RST" (lower right hand button) once to get the hour numbers to blink, indicating that you can change them
  • Press "ST/STP" (upper right hand button) to move the hour forward until you go past 24
  • At this point, you will notice a little "A" next to the time to indicate AM, and if you keep going past 12 hours, it will cycle back to 1, this time with a "P" next to it to indicate PM
Apr 18, 2009 | Lucien Piccard 26024 Wrist Watch
Need instructions for Timex 1440 Sport watch
TIME AND DATE
CHRONOGRAPH
Nov 22, 2008 | Timex 1440 Nylon watch
Kenneth Cole Reaction watch date set problem
I just dug my watch out after not wearing for a few years and had the same problem. There is an easy way to adust this watch's time and alarm, basically one way to enter both.
1) With the watch in the regular time display mode (doesn't matter if 12 hour or military time), depress and hold the lower left hand button (mode button). After a few seconds the watch appears to shift to alarm mode and it is blinking. This puts you into the mode for adjusting the alarm.
2) If you want to adjust time, date, etc rather than alarm time, after you have done step one, simply press that same lower left button again, and then it will put you into the time mode, but this time the time mode is blinking and you can adjust the various components (seconds, minutes, hours). You can only move minutes, hours, etc forward, no way to move backward. You will start off with the second display blinking, probably skip that unless you need to adjust seconds. Depress the upper right button to shift to the next option (minutes) and you will see the minute display blinking. Adjust the minutes by depressing the lower right button. When finished depress upper right button to move to next option (hours) depress the lower right button to move the minutes/hours/month/date forward as necessary, when you finish just press the lower left button again and it pulls you out of adjust mode and you are back in regular time viewing.
I had to post this because I've had this problem in the past and it killed me. Its kind of intuititve after you get into the adjusting mode by pressing the lower left button- remember, initially it will put you into adjust alarm mode, but press again and you will get into adjust time mode.
Oct 30, 2008 | Kenneth Cole RK5034 REACTION
Kenneth cole reaction
Jul 16, 2008 | Kenneth Cole RK5034 REACTION
Setting the clock on my baby g shock watch
Press & hold the adjust button until the time starts to flash.
Press mode button to select hours.
Press forward or reverse button to move hour backward or forward.
Press mode button to select minutes.
Press forward or reverse button to move minutes backward or forward.
Repeat the process for the month/dte/dy/yr
Press adjust again when finished
Mar 09, 2008 | Watches
Setting Time
Hold in the adjust button until the seconds start to flash. Then push the mode button until the hour is flashing. When the hour is flashing push the forward button to advance it one hour. After you do this hit the adjust button to exit the set mode.
Casio G-Shock Chrono Quartz Stainless Steel GS-1001D-1ADR Logo
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
