Question about Electrical Supplies
How do I set the throttle of unidentified generator?
Idle is off
Generator won't idle
Generators don't idle. They aim for maximum revs until the voltage regulator has enough voltage then it reduces the throttle.
May 01, 2017 | Electrical Supplies
Honda EM5000SX generator - will not idle up when a load is placed on. Will produce power but will not idle up.
from your description and what you do , the problem is in the auto control unit
it will be in the system to reduce the rpm to idle when there is no load ( auto mains on off controller switching between genset and mains supply)
by turning the auto operation off you are committing the gen set to full rpms regardless of the power requirement
you have the option of having it fixed at an gen set repair shop or leaving it off and starting the genset only when you have a mains power outage
check with an electrician to ensure that it is possible to run it that way as if the mains power unit is not correct , when you start it and you still have mains power , it will destroy the gen set
Dec 13, 2016 | Honda Electrical Supplies
How to adjust idle 3500e generator
if you have an idle control the idle only comes down to about 2000 rpm and thats the screw on the top of the carb that sticks out to the side
if you mean full throttle, it's set at 3600 rpm's and there is no screw for that
Oct 27, 2014 | EnergyStorm 3500 Watt Generator By Lifan
My Honda EB3500X Shuts off when auto throttle is switched on making me run full throttle at all times. Cause? Solution?
if your engine shutting down, then your auto throttle is working.
when you hit the switch watch the throttle arm move on the carburetor to the idle position,if so you may have to clean the carburetor jet and fuel nozzle ports.possibly this occurs when unit has been stored for quite some time.once jets are cleaned it should maintain idle.
May 31, 2014 | Honda Eb 3500 Generator
Throttle on generator question
The idle control switch allows the generator to go into idle when there is no demand form the appliances connected. This saves gas and increases the life of the generator. Damage can occur for some appliances like a refrigerator/freezer because the voltage and frequency are not prepared for the load resulting in a low voltage bad startup that will damage the appliance. Suggest that you leave the idle control switch off while any motor/electronic devices are connected.
The throttle control is likely a choke function for starting. These generators are designed for only one running speed to produce the necessary 60 cycles per second and voltage.
The following link is to a Canadian web site that later in the detail report describes the concern of idle control. In addition it provides good insight to the operation and use of portable generators
Hope this helps?
Understanding Portable Generators
The user manual see pages:
http://www.mikestools.com/download/Porter-Cable-Manuals/Porter-Cable-CTE300.pdf
May 06, 2017 | Porter Cable Portable Generator BSV750
It runs wide open all the time im wondering where idler arm setting is at
It sounds like the govenor spring has become disconnected or the clamp on the governor shaft has become loose and allowed the linkage to get out of adjustment. If problem has occurred suddenly it could mean the governor gear assembly inside the engine has broken and means the engine will need to be dismantrel to replace the governor gear assembly.
Check throttle linkage to see if spring is attached at both ends, one end on the throttle linkage and the other at the fixed point on the engine or to the end of the speed control lever. With engine stopped the spring should hold the throttle wide open and hand pressure on the linkage shoud be all that is needed to move throttle shaft closed to the idle position with no binding in the movement of the linkage.
If spring is OK and while engine is running, linkage should be able to be be moved to bring engine back to idle. If porblem has occurred gradually, then linkage will need re-adjusting. Loosen adjusting clamp on governor shaft, then holding linkage in wide open throttle position rotate shaft as far as it will go in the opposite direction to that requred to close throttle to idle . Re-tighten clamp.
Dec 11, 2010 | Coleman Powermate Premium Plus 6250W...
Unit starts with auto throttle off. engaging auto throttle shuts down unit. in past months, pluging in a cord would shut down unit. That is with no tool in use, just plugging into the receptacle.
Hi. There are 2 things that control the Auto Throttle and that is the idle control valve (Connected with black and yellow wires) and the Auto Throttle Unit.
Start Generator
Check for 12VDC on the Yellow wire of the idle control valve. Yellow is positive to any good Chassis ground. If you don't have 12VDC then either the Auto Throttle switch is bad or the Auto Throttle Unit iself.
You can gain access to the Auto throttle switch and again check for 12VDC to Ground on both sides of the switch with the switch on. (It may read as high as 13.8 engine running) If you don't get 12 - 13.8 VDC the the Auto throttle control unit is bad
If you have 12VDC to the Idle control Valve and it does not work perform a resistance check across the coil of the Idle control Valve (both wires disconnected Engine off) Black to yellow should read 3 to 4 Ohms If you have no resistance then the coil in the Idle control Valve is bad.
If you need more help just respond here
Kelly
Feb 09, 2010 | Honda 3000 Watt Portable Generator
Running at idle speed
1) Check the "Economy Throttle" setting (or some similar verbage). Inverter types dont have to run full speed to produce full voltage.
2) Apply a load. These magically accellerate and decellerate according to load conditions.
Hope this helps,
Dolf-
Oct 13, 2009 | Yamaha 2500 Watt Industrial Inverter...
Ust 3000 generator-only idles-no voltage output
chek brushes...if they seemed ok then replace AVR card
Sep 05, 2009 | Coleman Powermate Powermate 5000W...
Briggs & Stratton 135212/0129 - Homelite HL2500
the choke should be in the off position when running. YOU put the choke on to start it then when it starts u turn it off. If the choke is on the engine will die when reving
Aug 02, 2009 | Electrical Supplies
Electrical Supplies Logo
59 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
