Question about Lux PSD111 Digital Non-Programmable Single Stage 24V Thermostat
What is snowflake symbol - Lux PSD111 Digital Non-Programmable Single Stage 24V Thermostat
    New Friend:
  • 24 Answers
Shows that the setting [temperature] is set to come on when a temperature inside gets below 2 degrees or zero
Posted on Apr 13, 2015
How do i get rid of the key symbol
Push the buttons which have a key symbol for 3 seconds and the washer can be used after unlocking the child lock. Download your WHIRLPOOL AQUASTEAM 9559 WP user guide or user manual
Mar 08, 2015 | Whirlpool AQUASTEAM 9559 WASHER FOR 220...
Snowflake symbol on thermostat
Copy following link for Lux product manuals
http://www.luxproducts.com/instructionmanuals.php
It might mean that AA batteries needs to be changed.
Or it might mean 2nd stage heating cycle.
Air filter needs to be changed.
Tech assistance 856-234-8803
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 26, 2012 | LuxPro PSP711TS Touch Screen Programmable...
How do I set my Timer on the Hot Water Tank to give me hot water all the time. The slider has a clock symbol on one side and a beam symbol on the other?
Timer is not identified.
Usually the slide switch is override button.
Clock symbol probably represents timed functions.
Other symbol probably represents 'always ON'
Move switch to both positions and see what happens.
Add a comment with clear description of timer for more information:
http://waterheatertimer.org/How-to-set-timers.html
Jun 21, 2011 | General Electric Water Heaters
We have a White-Rodgers 90 series thermostat that started beeping last night. We have had it for about 4 years. Does it have a battery? I couldn't find anything about that in the manual.
Susan, the "90" series of thermostats covers a couple of different thermostats made by White-Rodgers. Here's how to find your model number. With that info, I can check the manual specific to your thermostat.
In the mean time, check the display for the word BATTERY or BAT. (Flashing) on the display. Battery flashing or blinking on the digital display indicates low batteries. If the batteries have recently been changed and the thermostat continues to indicate low batteries, use a pencil eraser to polish each of the battery contacts inside the back of the thermostat. Do not bend them up and down when polishing or you might break them. When complete, they should all be as shiny as a mirror. This will assure proper battery back-up, allow the backlight to work correctly and remove the flashing battery symbol from the screen. Battery (Solid) on Display The battery symbol (not blinking) indicates a loss of power (24 volts) from the heating and cooling equipment to the thermostat. Normally the heating and cooling do not operate when the battery indicator is on. If the battery indicator is on, check the fuses or breakers, make sure the furnace is switched on, and verify the blower compartment door is closed properly. The battery display is designed to indicate the thermostat is running on batteries, so replacing batteries has no effect on the indicator. See No Heat/No Cool for more information. Note: Some heat only systems (zoned systems) disconnect power from the thermostat during a normal heating cycle and display the battery symbol. Millivolt heating systems always indicate battery because they do not supply 24 volts to the thermostat.
A beep often is provided as audible feedback when keys are depressed on many thermostats. You should check to make sure that no key is stuck in the "in" position or is otherwise activated.
Jan 10, 2011 | White Rodgers Water Heaters
Flashing red light under ! on my worcester 24i junior combi boiler and pressure under 1
you don't have enough pressure in the tank you are using, needs to be a 2lb system to work properly it is starving the gas valve for gas
Apr 19, 2009 | Water Heaters
Vaillant 831 combi boiler timer help
check to see the time clock is set with the clock symbol. there are three settings on analog clocks I , O and clock the I setting is constant running, the O setting is off and the clock setting is timer.
also try setting the thermostat up higher to see if the boiler fires.
Mar 25, 2009 | Water Heaters
Lux PSD111 Digital Non-Programmable Single Stage 24V Thermostat Logo
192 people viewed this question
Top Lux Water Heaters Experts
Gene Haynes
Bill
Level 1 Expert
Are you a Lux Water Heater Expert? Answer questions, earn points and help others
