Question about Fasco Tools & Hardware - Others
Fasco f1b 7c-16 pneumatic stapler. How do I take apart to repair o-rings? Airbus leaking from rear cannot find any help from the company and associates on fixing with replacement parts. Please help!
2 Suggested Answers
  • 121 Answers
SOURCE: schematics on fasco air stapler #F1B 7C-16
I can e-mail you schematics. I have all Fasco & Rainco parts for this tool and more in stock!
Posted on Aug 26, 2009
I need O rings and lower bumper for Rainco R1B 7c 16 uphostery stapler
"O" rings are sold by diameter, thickness and type of material, any auto parts store can likely match up what you have. I would use a material called "Viton" not just rubber, holds up better to chemicals
Apr 04, 2017 | Tools & Hardware - Others
LOOKING FOR SEAL REPALCEMENT AT TOP OF PISTON
Search Results
    [PDF]How to Repair you Nailer - Master Tool Repair
    www.mastertoolrepair.com/.../How%20to%20Repair%20you%20Nailer....
    Air leak through the top head exhaust port. • Nothing ... head valve or the seal located on the top of the cylinder (the part the driver ... Look to see if the piston top of the driver is aligned in the ... Solution: Remove and replace trigger valve (if.Missing: question
    Rebuild a Framing Nailer ' The Family Handyman
    www.familyhandyman.com/tools/air-tools/rebuild-a...nailer/view-all
    Keep your framing nailer in top working condition and save time and money with a ...O-rings that cause air leaks, a trigger valve that won't fire, or a leaking cylinder seal ...then replace the rings one at a time, matching each one to its replacement. Install the new bumpers, piston seals and piston stops and reinstall the cap.
    FASCO - Frequently Asked Questions - fasco tool finder
    www.fasco-tools.com/en/faq-manuals.html
    Search Tools by Application ... My Fasco pneumatic nailer/stapler leaks air from the
Feb 09, 2016 | Air Tools & Compressors
What should I do if my brand new Fasco pneumatic upholstery stapler is leaking air through the tail end...not the hose, but the two holes in the handle? Any suggestions?
Hi Anonymus,
What's happened if the driver blade has stopped in mid stroke, the air will escape. Quickest was 'round this is to take the airline off the tool, then find some scrap wood, place the tool on it as though you're firing it, and in THIS ORDER... pull the trigger and re-connect the airline at the same time. This usually sorts this out. Regardless of the tool make and model this will happen to most users sometime....
Leigh Co Limited
May 25, 2014 | Fasco Tools & Hardware - Others
I have a Fasco F1B7C-16 upholstery stapler that won't shoot. There's no mechanism to push the staples forward -- is that normal? The instructions are completely useless ... Help!
The staples are loaded in from the bottom of the unit.
Pull out the staple tray all the way to the rear then turn the unit upside down and drop the new staples into the grove in the unit.
Push the tray back into the unit and you are ready to go!
Dec 03, 2011 | Fasco Tools & Hardware - Others
Air leak from trigger in bostitch pneumatic stapler
you need to replace rubber o ring on the trigger shaft pretty easy fix o ring is real small to deal with but doable automotive part stores usuly have assorted size in trays you can take old one out match its size .
Mar 31, 2011 | Stanley Air Tools & Compressors
I need the schematic for a Fasco FIB 7C-16 fine wire upholstery stapler...and, if available, an owners manual. My stapler is not shooting staples and I have tried everything that is on the troubleshooting...
Hello from FASCO ITALY. Pls let us have yr complete email address and we will send you the manual and the schematics. Our email is fasco@fasco-spa.com best regards FASCO
Feb 12, 2011 | Garden
I have an older Fasco stapler, it is orange in color. S3G 16 is number on it. The part that pushes out the staple has a piece of staple stuck in it. How can I get this out?
Some models have small screws on the face plate that can be unscrewed to release pressure or a spring clip to release. You can also push the plunger back into stapler with a thin narrow srewdriver, the staple may fall out.
Nov 30, 2010 | Fasco 9 Narrow Crown Pneumatic Staple Gun
Schematics on fasco air stapler #F1B 7C-16
Aug 10, 2009 | Fasco Staple Gun Pneumatic F3c Atw-38 Mod...
Pneumatic stapler leaks at the top
your problem is you have blown a seal. On some of the cheap chinese guns, it might be a flat gasket instead of an o ring.
May 25, 2009 | Air Tools & Compressors
MY PNEUMATIC STAPLE GUN WON'T WORK/ looses air through firing lever.How do I repair it? Where do I put the oil in?
I would agree with rowdy that the make and model number are essential to getting the right parts - If you have that information, just find a dealer that supports your brand. That being said, air leaking out the trigger area is likely to be an O-Ring or Seal problem. Pneumatic staplers have O-rings and Seals that need to be replaced periodically. Most have rebuild kits available that contain all the O-Rings and Seals that need to be replaced. Many staplers have O-rings and/or Seals on or near the trigger shaft that can wear and allow air to leak out
Mar 11, 2009 | Tools & Hardware - Others
Tools & Hardware - Others Logo
108 people viewed this question
Top Fasco Tools & Hardware - Others Experts
Are you a Fasco Tool and Hardware - Other Expert? Answer questions, earn points and help others
