What does it mean when the system says topping limit error?
What does 9ascap mean on jeep liberty
GAS CAP means its loose.
it means the EVAP system detected a breach to the EVAP venting system if you connect the scan tool and scan it , you get far better DTC errors, the operators guide cover this dash warning
lost that already?
Oct 21, 2014 | 2011 Jeep Liberty 4WD Limited
What does error code CA on my calypso washer?
Ca - Average Current peak - happens if there is a 2 second average of current draw greater than 5.55 amps at the motor windings. This may signify problems with the drive motor, thermal protector, or motor controller. Overloading the unit may cause this problem. Try washing smaller loads and see if the problem goes away. If it recurs when you wash bigger loads, decrease the size AND watch to see if you have to continue to decrease the size to keep the error from happening. If that were occurring, it could well be a sign of the electrical problems noted, requiring service.
CA Cl Average current limit Or Instantaneous current limit If a status signal comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either CA for average current limit trip or Cl for instantaneous current limit trip. Average current trip occurs if there is a 2 second average of current draw greater than 5.55 amps at the motor windings. Instantaneous current trip occurs if there is a spike of 26 amps instantly at the motor windings. This may signify problems with the drive motor, thermal protector, or motor controller. Over-loading the unit may cause this problem.
I think CA means [C]ontrol [A]verage Error. It means you need to reset the control panel, and retry again.
Aug 22, 2014 | Whirlpool Calypso GVW9959K Top Load Washer
Fault code 5n1
I'm assuming this is a Cal Spa? I'm going to reply to this but I'm willing to bet this issue resolved itself?
Error code of Sn1 ("Sensor 1"- Spa is shut down. High-limit sensor is not working.)
This could be a temporary condition. If not, your high limit sensor is bad. "SN" means your spa has a sensor error and "1" means it's the high limit sensor. Without knowing the year of your spa I don't know which manual to give you but the link below has just about every Cal Spa manual available.
http://www.calspas.com/manuals/
Apr 24, 2013 | Fisher and Paykel GWL11 Top Load Washer
Bmw e60 . Error: the word "limit" in
Is dont remember bad, this is the Speed Limit Display. That is a revolutionary new driver assistance system. The Speed Limit Display keeps the driver informed of the maximum permissible speed at all times. A camera fitted near the interior mirror permanently monitors the signs by the road as well as variable speed limit signs on overhead display screens.
If there is a sign indicating a speed limit in the wet, limitations at certain times of the day or restrictions applying only to towing vehicles, the intelligent driver assistance system, part of BMW ConnectedDrive, collects data from the rain sensors, clock and tow bar before displaying the restriction in the cockpit or, if requested, on the Head-Up Display.
Hope this helps; remember to rating this answer and leave a testimonila comment. Thank you for using Fixya.
Oct 14, 2011 | 2009 BMW 5 Series
Error sc:544
Hi
SC544 error means Fuser Overheat Error 1 (Hardware). This has happened due to Fuser Low Temperature which occurs due to Abnormal Hot Roller Fusing Lamp Lower Limit Temperature Detected. Try turning off & unplugging the copier for 10-20 minutes to check if error code resets. If it doesn
Oct 09, 2010 | Gestetner DSm615 Digital Imaging System
My calypso washing machine has an error code of "CA" What does this mean, it is squealing and will not drain water
CA means average current limit . this may signify problems with drive motor or motor controller over loading the washer may cause this problem. to clear this-press stop /cancel
Oct 04, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
I have a ca code what does this mean
Hi
Thanks for using FixYa. Error code CA means Average current limit. This error code will display if the load of clothes is more then the normal load. Also if current limit breaches then status signal comes back from the motor controller. The unit will return to standby mode and display CA. Average current trip occurs if the current draw at the motor windings is greater than 5.55 amps in 2 seconds. This error occurs if there is a problem with the drive motor, thermal protector or motor controller. Over-loading the unit may cause this problem.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 22, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
CA error code on Calypso Washer
Meaning you had stuffed it full one time and then it was hard on the motor, you will have to change the drive motor most likely...
May 07, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
C1 code what does it mean on a clypso washer
The C1 error is displayed when the motor tries to pull more than 26 amps to run.
This indicates a problem with the motor or motor controller.
Overloading or excessive suds can also cause this error.
If you like to make a few more checks then the image below contains the instructions for entering the diagnostic test mode.
Its a short cycle that runs all of the components so the operation of each can be checked.
I hope this helps but an intermittent C1 error can be hard to pin down.
http://media.fotki.com/1_p,wbrrkqqwkwbqsdgxgtqsskgwtqkq,vi/kdkftbfkwxkfsqdgqsg/1/1303472/5961857/image5668img-or.jpg
From the service manual....
"C1 = Average current limit Or Instantaneous current limit.
motor controller. Over-loading the unit may cause this problem."
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#$^^
Mar 31, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
I keep getting a C1 error code. What does it mean?
"C1 = Average current limit Or Instantaneous current limit."
Thank you for contacting us.Please do keep posting and do rate fixya if we could help you out with your problem.
Dec 10, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
32 people viewed this question
k24674
